Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 02-19-2019, 05:13 PM #481
TonyB66's Avatar
TonyB66 TonyB66 is offline
Real Name: Tony (no surprise)
TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light
TonyB66's Avatar
Originally Posted by infamousRNR View Post
Started to paint my lil’ skips skid Tim got me for X-mas. I cleaned it real good, primed then painted, but I’m heavy handed with the can and get to close to the item I’m painting so some weird stuff happened to the paint which caused it to crack... I wet sanded it down real good in preparation for another coat of flat black.
Damn nice X-mas gift Sean!
In this cooler weather as of late, it might not be your fault (heavy handed, too close). Anything around 50 degrees or less is often problematic with many primers and paints. I'm been more successful warming it up first in direct sunlight, if any, then after painting, hitting it with a heat gun. Also, lighter coverage coats tend to come out better than fewer heavier ones in these cooler temps...
2000 Limited, E-locker
Maintenance/Build Thread
TonyB66 is offline   Reply With QuoteReply With Quote
Old 02-26-2019, 03:40 PM #482
infamousRNR's Avatar
infamousRNR infamousRNR is offline
infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light
Being the nice guy that he is, the zigster ( @JZiggy )helped me install @4Runner4Leon hood struts and we re-made the bracket for my blue sea fuse box since the previous bracket was interfering with the strut when the hood was shut..
InfamousRNR's 2002 Limited BU!LD THREAD-c0eac954-50a1-4ba0-88ac-970e5294fc42-jpeg  InfamousRNR's 2002 Limited BU!LD THREAD-7b91fc07-c43b-4d6e-add7-44266a052e0d-jpeg
1998 Desert Dune Toyota 4runner Limited 4x4 w/ factory e-locker
2000 BLACK Toyota 4runner Limited 4x4 w/ factory e-locker Build Thread
2002 Thundercloud Metalic Toyota 4runner Limited 4x4
Build Thread
infamousRNR is offline   Reply With QuoteReply With Quote
Old 02-26-2019, 05:36 PM #483
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
Sicmods all day! I’m proud of that bracket we designed together.
JZiggy is offline   Reply With QuoteReply With Quote
Old 02-26-2019, 05:43 PM #484
norcalassassin's Avatar
norcalassassin norcalassassin is offline
Real Name: Zac
norcalassassin will become famous soon enough
Real Name: Zac
subbbed! nice build
surprised i haven't seen your rig around. i'm from the east bay
1998 SR5 5 spd 4x4 3.4L + some other stuff
1985 Tercel 4WD SR5 6spd, 4A swap
2006 Saab 9-2x Aero 5spd (saabaru)
IG: r0amerr
https://www.toyota-4runner.org/3rd-g...ce-thread.html
norcalassassin is offline   Reply With QuoteReply With Quote
Old 02-26-2019, 07:14 PM #485
4Runner4Leon's Avatar
4Runner4Leon 4Runner4Leon is offline
Real Name: Leon
4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all
Real Name: Leon
That's some nice work on the bracket by @JZiggy ! How much did you have to move the fuse box to get the struts to fit?
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
4Runner4Leon is offline   Reply With QuoteReply With Quote
Old 02-26-2019, 07:16 PM #486
JZiggy's Avatar
JZiggy's Avatar
Would have to have Sean confirm... I think we moved it inboard a couple of inches is all.
Old 03-04-2019, 05:52 PM #487
JWaldz's Avatar
JWaldz JWaldz is offline
Moderator
Real Name: Waldo
JWaldz is a jewel in the rough JWaldz is a jewel in the rough JWaldz is a jewel in the rough
Moderator
JWaldz's Avatar
Real Name: Waldo
I see you over on TW buying things
'99 Toyota 4Runner LTD - Dual Locked | Geared | Mid-Travel | 35s | Armored
Sponsors: Coastal OR | Extreme LED | SherpaEC | Overland GG
3G Build: ShowGirl | Instagram: ^Click Above^ | FB Page: JWaldz4R | T4R Mod: Contact Me
JWaldz is offline   Reply With QuoteReply With Quote
Old 03-16-2019, 12:58 PM #488
Got some Sicmods done to a couple items. Rhino-liner on the rear spoiler was one of many items that got rhino-lined.
InfamousRNR's 2002 Limited BU!LD THREAD-ea88f86f-1dd0-4cd5-a26f-7ac9d7b88b13-jpeg
Build Thread
Old 03-16-2019, 01:01 PM #489
Don’t tell my GF!!!!
The issue with my other bracket it’s that it didn’t get out enough. We didn’t take any before or after measurements but once a strut goes on you can get an idea of how much space you need to avoid the strut hitting the fuse box/bracket.
Originally Posted by norcalassassin View Post
subbbed! nice build
I’m usually in the South Bay (San Jose) doing Sicmods with Timmah. You should come to our MOD day on April 13th!
Build Thread
Old 03-16-2019, 01:03 PM #490
TonyB66's Avatar
TonyB66's Avatar
Sean, looks damn good! It can be addicting, so I hear. Curious what else you did, and what might be next...
Spray or roll-on?
Old 03-17-2019, 03:24 PM #491
Scoop'02's Avatar
Scoop'02 Scoop'02 is offline
Real Name: Colin
Scoop'02 is on a distinguished road
Scoop'02's Avatar
Real Name: Colin
Awesome pics Sean! Looks amazing!
2002 4Runner Sport Edition, Thundercloud Metallic
Scoop'02 is offline   Reply With QuoteReply With Quote
Old 05-22-2019, 11:11 AM #492
My fairing on my GOBI rack was digging into my paint after my home depot weather stripping shifted after driving on death valley’s bumpy roads. So now my fairing was digging into my paint on my roof. OUCH! So I cut up an old door jam weather strip and pushed it onto the fairing. I’m surprised on how well this worked. Just push it on, and cut the weather stripping to the length of your fairing. If any of you guys need a good solution to giving your faring to have a nice cushion on your paint this may be a consideration for you.
InfamousRNR's 2002 Limited BU!LD THREAD-54eafcaa-3968-424b-9a54-a9b647aa3e81-jpeg  InfamousRNR's 2002 Limited BU!LD THREAD-1a6952cb-cdba-4eb1-8ef6-36a63b2c258f-jpeg
Build Thread
Old 07-29-2019, 10:40 PM #493
InfamousRNR's 2002 Limited BU!LD THREAD-img_6131-jpg
Build Thread
Old 03-31-2020, 01:46 PM #494
It's been a while since I have posted on this thread...
My extended shaft bilstein 5100's got a little too extended!
Replaced those shocks a couple weekends ago.. dang things were so tired. they had been on for over 5 years.
InfamousRNR's 2002 Limited BU!LD THREAD-img_5037_jpeg-jpg  InfamousRNR's 2002 Limited BU!LD THREAD-img_9375_jpeg-jpg
Build Thread
Old 09-23-2020, 01:37 PM #495
MarkamisPrime's Avatar
MarkamisPrime MarkamisPrime is offline
MarkamisPrime will become famous soon enough MarkamisPrime will become famous soon enough
Brooooo. Those curbs at the mall are getting intense
What made you go with the different set up instead of just getting the same thing ??
2012 TRD Tacoma wheels
Grey wire mod
Toytec ultimate lift w/super flex rear coils
1.25 spidertrax coming soon
MarkamisPrime is offline   Reply With QuoteReply With Quote
3GT4R's Build Thread 2002 4Runner 3GT4R 3rd gen T4Rs 53 08-06-2017 01:17 PM
My Build Thread - 2002 Gold Runner ALBPM 3rd gen T4Rs 31 11-09-2015 05:32 PM
Chrisdowling84's 2002 Build Thread chrisdowling84 3rd gen T4Rs 35 02-16-2015 11:44 AM
2002tii's 2002 4Runner Sport Edition 4WD thread 2002tii 3rd gen T4Rs 25 03-08-2014 10:41 AM
mikebontoft's BMW 2002 build thread mikebontoft All Other Vehicles 14 03-04-2014 10:48 PM
