Old 03-31-2024, 05:42 PM #1
WrenchTech's Avatar
WrenchTech WrenchTech is offline
Real Name: Matt S.
WrenchTech is on a distinguished road
WrenchTech's Avatar
Real Name: Matt S.
Transfer Case Actuator Motor Replacement - OEM or Aftermarket?
The vehicle is a 2002 runner with the four-wheel-drive/all-wheel-drive transfer case has the electric 4wd shift button on the side of the shifter knob. The vehicle is stuck in 4wd due to a bad actuator on the transfer case. The best deal that I can find on an OEM part is around $1300. I am seeing aftermarket actuators for as low as $130. I usually buy OEM parts, but the difference here is so huge that I am considering trying the aftermarket part. I would like to hear from anybody who’s had any experience with the aftermarket actuators?
1999 SR5 3.4 auto, Horizon Blue Metalic 8N1, blue cloth, steel Daytona wheels, 265/75/16 AT tires, rear heat, A/C, sunroof, electric locking rear dif.
WrenchTech is offline   Reply With QuoteReply With Quote
Old 03-31-2024, 07:22 PM #2
toverturf toverturf is offline
toverturf will become famous soon enough toverturf will become famous soon enough
I don't have experience but I assume you've tested everything else before determining it's the actuator? I know on my 99 it was a bad switch in the front diff but the 2002 is different.
1999 Limited with rear locker.
Sherpa Matterhorn | Sonoran Steel Diff Drop | SPC UCAs | DuroBumps Front and Rear | OME 890 Springs and Black Tokico Shocks | Eimkeith Reinforcements and PCK | King Coilovers | OCD Sway Bar Links | Opt Offroad Rear Arms | Lil Skips Gas Tank Skid Plate | FGP Rock Sliders | 4x Innovations Rear Plate Bumper with tire carrier
toverturf is offline   Reply With QuoteReply With Quote
Old 04-01-2024, 09:54 AM #3
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
The first pic shows the ADD actuator on the front diff.
2nd pic shows the Tcase actuator. You can try manually actuating the Tcase actuator.
Are you certain the Frt Diff Actuator is working properly. Mine was stuck in 4wd with a flashing light, ended up being the Frt Diff Actuator. The Tcase unlocks AFTER the 4wd computer sees that the Frt Diff has unlocked, so if it's stuck in a half unlocked state like mine was, it will never get the Open Circuit signal to unlock the diff.
Transfer Case Actuator Motor Replacement - OEM or Aftermarket?-frt-add-jpg  Transfer Case Actuator Motor Replacement - OEM or Aftermarket?-actuator-jpg
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 04-01-2024, 01:41 PM #4
WrenchTech's Avatar
Real Name: Matt S.
WrenchTech's Avatar
Real Name: Matt S.
Originally Posted by toverturf
toverturf
See my response to the post below. Thanks for your reply.
Old 04-01-2024, 02:02 PM #5
WrenchTech's Avatar
Real Name: Matt S.
WrenchTech's Avatar
Real Name: Matt S.
Thank you for your detailed reply. I have a 1999 runner with the familiar mechanical transfer case. This is the first time I’ve ever worked on a runner with the electrically shifted case. The diagnosis was made by an independent shop run by a certified Toyota factory technician. He supposedly used a scanner to diagnose the actuator malfunction. He did it as a favor for my friend, who is the owner of the 2002 runner. Instead of relying on his diagnosis, I should use the information that you have provided here to do a more extensive examination, ie., to make sure that the ADD is working properly before running off and buying a transfer case motor actuator.
Old 04-03-2024, 03:00 PM #6
shadow247's Avatar
shadow247's Avatar
Easiest way to tell with the vehicle on the ground is to do the following.
1. Engage Parking Brake and Block the wheels
2. Transfer Case to "N" Position.
3. Turn Front driveshaft by Hand
4. Driveshaft Turns = Front Diff ADD is Unlocked - Suspect Transfer Case Actuator
5. Driveshaft does not turn = Front Diff ADD is Locked - Suspect Front Diff Actuator
The 4Runner Show
4wd , aftermarket , case , oem , transfer
Installing used transfer case actuator motor sknightjr1 4th Gen T4Rs 11 08-29-2014 10:19 PM
Transfer Case Actuator Motor is SHOT!!! Jcamero 3rd gen T4Rs 8 04-11-2013 08:28 AM
WTB - 99-00 transfer case actuator motor Trub Want to Buy/Trade 1 09-24-2012 09:35 AM
Transfer Case Actuator Motor FAIL... MajorDan 3rd gen T4Rs 3 01-16-2012 06:03 PM
Need transfer case actuator motor Flipcanuk Classifieds - buy & sell (no commercial ads please) 0 08-30-2009 10:04 AM
