11-18-2019, 09:12 PM
#62
Originally Posted by brillo_76
What does the super charger do to your mpg? I know Toyota has had them for years. I never bothered with them but again never drove any Toyota supercharged either . ;)
That's a loaded question. For myself...I averaged around 15-16, but I drove the piss out of it. I live in Texas and kept the speedo over 80 on the highways and interstates though. If it were driven modestly...I could see it getting 18-19. In my opinion, the stock 3.4 is underpowered given the weight of a TR4. The supercharger definitely makes up for the anemic health that the stock 3.4 puts out. The biggest question you should ask yourself is: will I be able to keep my foot out of it? I was unable to even though it was just my work truck, and one of my other vehicles is a 700 horsepower Jeep SRT8.
2000 4Runner Limited 4x4, 3" OME lift, 2nd Gen TRD supercharger. 282,000 miles - SOLD
2010 Jeep SRT8, 7.2 Arrington 440 stroker, 550 whp! - FOR SALE
2007 Jeep Wrangler Sahara...too much to list!!
2015 Ford F-250 Platinum Powerstroke 4X4
11-18-2019, 10:28 PM
#63
Real Name: Jon
Real Name: Jon
Around here with normal v6 I get between 14 to 16 mpg. That isnt even horsing it. Just hilly in my area with lots of up and downs.
Old Toyotas were always under powered due to their weight. You think the 3rd gen 4 runners were bad. You should have had a 1983 5 speed with non EFI they definitely wouldn't won any speed records. Which was livable. The major issue I had with mine was trying to stop the rig.
11-18-2019, 10:55 PM
#64
100% worth it for me. 14-16mpg depending on hwy/city mix.
TRD Gen2 SC, URD 7th and headers really wakes up an armored truck on 35s with a stock auto and 4.30's. Plus the sound
2000 4Runner 4x4 Limited - TRD Gen2 Supercharger, URD 7th Injector, Doug Thorley Headers, Shrockworks Front Bumper, Bilstein shocks, Durabumps, 315/75r16 Yokohama G003 M/T
1997 4Runner 4x4 5spd - OME 883 coilovers, 891/5100 extended travel rear, 4xInnovations Sliders, SCS Ray 10s, Falken Wildpeak AT3W 285/75r16 - SOLD
Track.n.trail on Instagram
11-18-2019, 10:57 PM
#65
If everything is bought at retail price and you're spending upwards of $5,000 dollars to get to the point where you're running 8 psi, I'm sure it isn't worth it. I'm going to be into mine closer to $1,500 running 8 psi and I'm hoping it makes a big difference like 5 psi on my turbo RZ made. If it doesn't cut it I'll spend another $500 and setup water/meth and slap the 2.0" pulley and and send a rod through the block.
Any time someone who drives even a bone stock 4runner or Tacoma brings up gas mileage I just find it laughable. People pay a premium for a vehicle you know damn well won't hit 20 MPG and fuel cost suddenly becomes a concern. A vehicle that's a third of the price would easily get 30-40MPG and save you money hand over fist, so sell your yota and buy a civic or two.
Sent from my JSN-L23 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" ( Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - ( Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
11-18-2019, 11:01 PM
#66
So true , some of these guys have never driven a vehicle that struggles to hit highway speed and it shows.
11-18-2019, 11:18 PM
#67
I wouldn’t go with one just because of the additional complexity and having to use premium fuel all the time. Sure would be nice to get more power though.
11-18-2019, 11:23 PM
#68
The only additional complexity aside from the initial install, comes from a nose cone oil change which should be done every 100k miles. The additional cost of the premium fuel can also be offset by the better fuel economy that you can see when your TR4 isn't constantly hunting for lower gears to maintain speed on the slightest of grades. Assuming you aren't always hammering on it.
11-19-2019, 01:57 AM
#69
Originally Posted by MCObray
I'm probably in the minority, but I would never go Supercharger. Flame suit on.
IMO:
Money can be better spent on other accessories, or towards trips themselves.
Premium Fuel. Always.
Less(er) MPGs.
Additional money, if you want to do it right. URD.
One more thing that can wrong. Yes, I know it's a Toyota.
Agreed, and for the price of one? Forget it.
The 180ish hp is good enough for me in this girl.
11-19-2019, 10:04 AM
#70
Real Name: Jon
Real Name: Jon
I couple of times. I was beside people because they stopped too fast. It was either beside them or hit them. I could barely hit 55 on a hill around my area. Even in 4th the old girl struggled. Yet the rides ran forever.
11-21-2019, 08:30 PM
#71
Real Name: Jerod
Real Name: Jerod
Relatively nothing. It doesn't go into boost unless you are really gunning it since it has an internal bypass valve until a certain amount of throttle applied. There's been some cases (depending on terrain & driving style) that people have gained about 1 MPG's due to having to use less throttle. Not common though.
I bought mine with it on so I don't have before & after numbers.
11-21-2019, 08:56 PM
#72
Real Name: Jon
Real Name: Jon
So similar to the vtech on some Honda engines when it kicks the extra valves and really increases HP and Torque. They also require premium gas as well. Understandable.
01-03-2020, 07:59 PM
#73
Resurrecting this thread since I can now offer an informed opinion on it- and yes! Totally worth it. Recently installed supercharger, URD 7th injector kit, and AFR calibrator. Ran it for a week with just the s/c and it was pretty good but definitely pinged a bit here and there when crowding the throttle and most of the gains came at higher RPMs. Installed the 7th injector and AFR calibrator and it is an absolute dream to drive now. For the most part the change is unnoticeable- at lower speed/throttle levels it's the same, where it shines is higher speeds and at altitude or on hills. The increase in power in 4th with the torque converter locked is exactly what these trucks need to feel modern- set the cruise control and let it run. If you need a little "oh shit" power to get out of the way of something you have it. Want to tow? No problem.
With the URD kit I don't get any pinging at any RPM, it runs smooth and powerful on the preset tune. I may get it dyno-tuned at some later time, but as of now I don't see any need to.
01-03-2020, 10:09 PM
#74
Real Name: Eddie
Real Name: Eddie
Thanks for your update OrRunner.
Did you install a TRD SC or one from Magnuson? I know they are the same, just curious how new your SC is.
I'm gnawing at the bit for this set up, but spending 4 grand on a vehicle that's worth 8-ish just does not seem like a smart thin to do.
Eddie
2001 T4R SR5 - 180k miles and counting.
01-04-2020, 11:14 AM
#75
Eddie
Magnuson supercharger, bought new with the URD kit on Black Friday sale.
It depends on how you look at things, even a cheap new car is 20k, if I can get modern car drivability for less than that I’m still doing ok. I’ve done a lot of work to my truck- touchscreen double din, backup cam, coilovers, led interior and dash lights, HID retrofits- to make it comfortable and modern. I have no intention of getting rid of it, so to me it’s worth it to spend the money.
