Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 01-13-2019, 01:48 PM #391
derpiful's Avatar
derpiful derpiful is offline
Real Name: Hayden
derpiful will become famous soon enough derpiful will become famous soon enough
derpiful's Avatar
Real Name: Hayden
Originally Posted by Black798 View Post
Good to hear your finally getting gears! 5.29s are the right choice IMO for 35s. They're honestly pretty perfect with my 33s for now as long as I dont try and get over 75. I hope those body mounts are the fix for the bumper movement. And if your getting the co2 regulator I think you are (65 dollar knockoff power tank) I just got that for my co2 setup to replace the poly performance regulator it came with. Seemed like a good idea so I can run air tools at their recommended pressures.
When I did my gears I used this kit from just differentials. It had everything I needed and seemed to be the cheapest option as well, especially after a 15% off black Friday deal. The only issue I ran into was the stake ut for the front diff wasn't the type that I wanted but I just picked up one at the dealer since it was pretty cheap.
For the front diff if you have a press and some scrap chunks of metal to push the carrier shims out its no harder than the rear 8 inch. I honestly thought it was easier and it took me less time setting up the front but I did get lucky with my backlash being right on the first try so I only had to add 12 thou of shim on each side to get the carrier bearing preload right. I equated it to setting up a dana style axle but on the bench so everything is right in front of you and the carrier just bolts together rather than having to beat it all in. The only special tool I needed was a small lever arm attachment for my dial indicator. I've also got quite a few pictures on my flickr of how it all breaks down so that might be helpful. Any plans for a front locker too or just the new gears?
Lever arm attachment I got
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Thanks Phoenix, all good info. I'm sure it'll be a huge step up over my 4.10s..
That's the regulator I'm going with! We'll see how it works. I'm just excited for 250psi vs 150psi.
That's good to hear the front diff was pretty easy, I was nervous about that one. I'll definitely be looking at your photos for some reference. Right now I'm thinking no front locker, as that's just a huge chunk of money. I've looked around and it seems the cheapest option is the Harrop Elocker for $1300 (wouldn't want an auto locker). It would be nice, but I'm also worried about breaking more components in the front.
derpiful is offline   Reply With QuoteReply With Quote
Old 01-30-2019, 02:10 AM #392
derpiful's Avatar
Real Name: Hayden
derpiful's Avatar
Real Name: Hayden
A few more photos to add!
First, I recently repainted everything. It took a while, but it looks much better than it did before. Both bumpers, sliders, grill, and frame were all painted.
222.painting
Also some more snow wheeling pictures. I've been getting out a bunch recently and it's been awesome. The winch has been getting a workout, but it's been doing great and I've had zero problems with it.
223.snow
224.snow
225.fog
Old 04-07-2019, 05:31 PM #393
derpiful's Avatar
Real Name: Hayden
derpiful's Avatar
Real Name: Hayden
Another spring break in Moab!
Finally got all of my photos edited. I left Friday afternoon and rolled into Moab sometime around midnight. Met up with @Fishwerks , @EatonKyleH , @Twenman4 , @NateMob , @Flemster , @Black798 , and some others this year!
Got up early and headed into town/ towards trails early Saturday morning, where we ended up on Steel Bender. I've done this one before, but not everyone else had. It's a fun one!
IMG_8857
IMG_8897
IMG_8933
The last time we were here, the main ledge obstacle wasn't nearly as big and we went down it. Now it's much larger, and we opted for the bypass.
IMG_8978
IMG_9062
Halfway up a hill climb I heard the fan hitting the shroud again and knew what that meant- the motor mount had failed again. This time, the mount itself was gone. We walked back on the trail a bit to try and find it, but couldn't. The motor had shifted down and back, and so I broke out the ratchet straps to try and get creative and hold it down. Ended up with something that worked but wasn't great, but it let us keep going.
IMG_9092
After airing up and heading back towards town/camp, I heard a thump-thump noise that matched my wheel speed and sounded exactly like a blown diff. Once in town we came up with a plan to pull my driveshaft and CVs so I could at least drive home. That's when we found the motor mount, thought to be lost, wedged between the CV and a crossmember! Took some major effort to get it out, but after a quick test drive all crazy noises were gone. Phew! Back to camp to eat and enjoy the time.
On Sunday we decided to do Hell's Revenge. We met up with and some others.
IMG_9101
IMG_9119
IMG_9134
IMG_9249
We had a few trucks go up the gate, and @Fishwerks was heading up when....
IMG_9255
@Black798 and I hooked up our winches (luckily they were the same, so they were the same speed) and pulled him up so we could check plugs before starting it. It started up with zero hesitation or smoke. The damage wasn't too bad, just a door and a few scratches.
IMG_9294
IMG_9312
After that we did the rest of the trail and bypassed all of the other major obstacles.
@EatonKyleH looking huge
IMG_9351
IMG_9358
On Monday, everyone headed different ways while @Flemster and I headed south more. We went and did some hiking and found some incredible slot canyons, something which I had never experienced before. After camping Monday night, I drove back home 9 or so hours... until next year!
IMG_9489
IMG_9525
Old 04-07-2019, 11:41 PM #394
Flemster's Avatar
Flemster Flemster is offline
Real Name: Alex Fleming
Flemster is just really nice Flemster is just really nice Flemster is just really nice Flemster is just really nice
Flemster's Avatar
A trip to remember for sure! Great pics as usual, that new lens is a game changer.
00' SR5 SPORT - 35's - Weekend Toy
@a.flemster on the gram.
Owner of Sherpa Equipment Co.
Build Thread
Flemster is offline   Reply With QuoteReply With Quote
Old 04-08-2019, 01:17 PM #395
EatonKyleH's Avatar
EatonKyleH EatonKyleH is offline
Real Name: Kyle
EatonKyleH will become famous soon enough
EatonKyleH's Avatar
Real Name: Kyle
Awesome pics Hayden!
Damn you guys are killing the the photo game more than ever.
Pictures of my Junk
EatonKyleH is offline   Reply With QuoteReply With Quote
Old 04-09-2019, 01:39 PM #396
Fishwerks's Avatar
Fishwerks Fishwerks is offline
Real Name: Chris
Fishwerks will become famous soon enough Fishwerks will become famous soon enough
Fishwerks's Avatar
Real Name: Chris
Photos are looking excellent my dude!
Thanks for winching me out, and looks like the rest of your spring break was fun (I need to go on that hike!).
How was the install of the new motor mounts?
Fishwerks' Photo/Build Thread 2000 SR5 l White on White l 35s l Supercharged
2010 Trail Edition l Salsa Red Pearl l Stock
Instagram
Fishwerks is offline   Reply With QuoteReply With Quote
Old 04-10-2019, 11:46 AM #397
Joelzy's Avatar
Joelzy Joelzy is offline
Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light
Joelzy's Avatar
awesome pics and trip, looking forward to moab this year!
96 SR5 5SPD Elocker "the Barnacle"
–02 bmw 540i6
–19 Highlander SE
Joelzy is offline   Reply With QuoteReply With Quote
Old 04-12-2019, 12:20 AM #398
derpiful's Avatar
Real Name: Hayden
derpiful's Avatar
Real Name: Hayden
It's been amazing! Well worth it.
Thanks Kyle! That photo of you is probably my favorite one from this trip.
Thanks! The hike was amazing, would recommend.
Next post is the motor mounts...!
Thank you! Moab is always a good time (except maybe when it's 115 degrees)
Old 04-12-2019, 12:48 AM #399
derpiful's Avatar
Real Name: Hayden
derpiful's Avatar
Real Name: Hayden
Lots of good maintenance happened recently. Took forever, but it was worth it!
226.maintenance
First thing was the motor mounts. I finally realized it wasn't just the frame side mount that was broken, but the mount itself also.
227.mounts
As you can see, it was missing the main bolt that connected the mount to the engine.
I opted to go with OEM mounts, as the old ones were proven to last quite a while and had taken plenty of abuse. 35s and being undergeared really doesn't help.
Taking the old mounts out was surprisingly easy, but did take some time. I had the engine lifted by the oil pan- not my favorite method, but it worked.
For the frame side of the mount being broken, I quickly made some new brackets to weld on that were about twice as thick as the factory ones. I had to grind off as much of the old mount as I could, which was near impossible given the space constraints.
228.mount
Once the new mounts were ready to go in, I bolted them up to the engine first, then dropped it in place and lined up the motor-to-frame bolt holes. Welding the new mounts on was the biggest problem of this project. There wasn't a great angle to get the mig gun in, but I did the best I could and laid some ugly beads. After that, the rest of the mount bolted up easily!
I replaced my brake pads, which were much more worn that I thought.
229.brakes
I also replaced the rubber intake tubes. The old ones were cracked and had some minor holes, which couldn't have been too good in dusty conditions.
230.intake
The passenger wheel bearing also got replaced, as a few days prior it had started making noise and developed play. It happened very quickly, which surprised me. I had replaced the driver side a few years ago when something similar happened. I opted not to do the press work myself, but found a local machine shop that did it for $40.
I also welded in some new skid plate mounting nuts (which is why the LCAs are off) and greased my UCAs. I was prepared to also replace my SPC ball joints, but after getting it all apart, it turns out the part that presses into the spindle had developed some play. I ended up welding it on, knowing that I won't be taking these SPC arms off.
Finally, I replaced both calipers (lifetime warranty) and added stainless steel lines.
After all of this, it overall drives smoother, quieter, and nicer. It was a total of about 9 hours of work for everything. I'm happy with the results even though it was a good chunk of change!
Old 04-12-2019, 03:41 AM #400
Rockdawg84's Avatar
Rockdawg84 Rockdawg84 is offline
Real Name: Sam
Rockdawg84 will become famous soon enough Rockdawg84 will become famous soon enough
Rockdawg84's Avatar
Real Name: Sam
broken Motor Mounts
it is just a suggestion but you should really chain the motor mounts. weld a chain to the frame and then bolt the other end to the top of the motor mount or vice versa. Make it tight so that the motor can't pull apart again and yet loose enough to not transfer vibration. it is a cheap insurance and you won't regret it.
this is a 22r mount that is chained but you get the idea.
Motor Mount chained by Sam Wright, on Flickr
84 Crawler Rockdawg84s Pic build thread but mostly pics
94 Fzj80 family hauler - sold
98 SR5 supercharged 5speed on 35's, dual locked, dual cased Smokey build Thread
03 SR5 V8, 4x4, 2.5" Icon's with 35's -Sold The Wife's 03 Build Sold
Rockdawg84 is offline   Reply With QuoteReply With Quote
Old 05-22-2019, 10:35 AM #401
derpiful's Avatar
Real Name: Hayden
derpiful's Avatar
Real Name: Hayden
Ran Chinaman Gulch this last weekend. Long day but a good one!
@Flemster on Whale's Tail
IMG_9834
IMG_9761
20190519-IMG_7685
FLEM3170
IMG_9883
@4-Ripcord !
IMG_9894
Old 05-22-2019, 10:45 AM #402
derpiful's Avatar
Real Name: Hayden
derpiful's Avatar
Real Name: Hayden
Also... this! Coming soon!
231.ECGS
I opted to just get the complete diffs from ECGS instead of setting them up myself, as the price difference wasn't massive and I'm sure they can do a better job than I can.
I went without a front locker. It's expensive, and I know I'll probably want it down the road.. but oh well. Not this time.
Old 05-22-2019, 10:51 AM #403
4-Ripcord's Avatar
4-Ripcord 4-Ripcord is offline
Real Name: Jim
4-Ripcord will become famous soon enough 4-Ripcord will become famous soon enough
4-Ripcord's Avatar
Real Name: Jim
Nice! I think that was a good choice, looking forward to seeing the difference it makes!
'13 Tacoma TRD-OR: The Spruce Goose. BUILD
'02 Sport Ed.- V2.0: The better build. Totaled BUILD 2.0
'02 Sport Ed.- V1.0: The college build Sold BUILD
4-Ripcord is offline   Reply With QuoteReply With Quote
Old 05-22-2019, 11:19 AM #404
TCMach's Avatar
TCMach TCMach is offline
Real Name: Tyler
TCMach will become famous soon enough
TCMach's Avatar
Real Name: Tyler
I didnt see this the first time.... BOOOOO
My build:TCMachs build
2000 4Runner:Kings, 37s, lockers
2018 TRD OR:stock and staying that way
TCMach is offline   Reply With QuoteReply With Quote
Old 05-23-2019, 10:03 AM #405
derpiful's Avatar
Real Name: Hayden
derpiful's Avatar
Real Name: Hayden
Eric's Build/Adventure Thread EHNWI 4th Gen T4Rs 98 04-05-2021 11:35 PM
Bruce's Adventure/Build Thread nismoxr34 5th gen T4Rs 18 08-12-2015 02:51 PM
Hargravey's Adventure/Build Thread hargravey 5th gen T4Rs 20 08-12-2015 11:14 AM
fatbacks Build and Adventure Thread fatbacks 5th gen T4Rs 21 04-29-2015 07:04 PM
GREENAMPHIBIOUS' Build and Adventure Thread Greenamphibious 5th gen T4Rs 65 04-21-2015 07:47 PM
