Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 08-22-2019, 05:55 PM #421
4runnerfiend's Avatar
4runnerfiend 4runnerfiend is offline
4runnerfiend has a spectacular aura about 4runnerfiend has a spectacular aura about
Nice rig! I too had a cracked head. seems to be common among the 250-300 k engines
IG: @4runnerfiend- 1999 SR5: TRD Supercharger, ELocker, Wheelers T1 Coils-tundra 5100's, Built Right UCA's, LC 8 wraps-Fox 2.0 with CD adjuster, Rokmen lower links, Savage skids, Hot Metal Fab Front Tube bumper, Savage Rear tube bumper, TruckShopSD Sliders, DuroBumps, RidgeGrapplers, Doug Thorley Headers, yellow top, XRC 12k, ARB single compressor.
4runnerfiend is offline   Reply With QuoteReply With Quote
Old 08-22-2019, 06:17 PM #422
STI_MECE's Avatar
STI_MECE STI_MECE is offline
STI_MECE will become famous soon enough
STI_MECE's Avatar
please keep us updated on this swap. That will be good to watch
STI_MECE is offline   Reply With QuoteReply With Quote
Old 09-05-2019, 08:03 PM #423
derpiful's Avatar
derpiful derpiful is offline
Real Name: Hayden
derpiful will become famous soon enough derpiful will become famous soon enough
derpiful's Avatar
Real Name: Hayden
New engine runs!
The swap took a while (being my first time pulling an engine), but overall it wasn't too bad.
I was told the "new" used engine was out of an 01 4Runner with 165k. From everything I can tell this was out of an pre-00 manual 4Runner, based on the various lines and connections with it.
MVIMG_20190822_170506
Overall the engine was pretty clean, and I was happy with my purchase.
IMG_20190822_173248
Should have just done the front diff now, would have been so much easier:
MVIMG_20190824_145645
While out and on the stand, I did the timing belt, water pump, all the various seals, and the valve cover gaskets. Incredibly easily to do when there's so much access!
IMG_20190824_185039
I ran into some issues getting the trans mounted, no matter what I tried it felt that it kept getting stuck and the bolts simply wouldn't go in all the way. After fighting it for a while, I pulled the engine back out (not too hard, since the tranny was the first thing I was working on), and found a pilot bearing where the torque converter shaft goes in. This is when I found out that this was out of a manual. After a bit, the bearing was out, and the engine went back in.
Once everything was free, the trans mounted up very easily with no issues. A few hours of bolting everything back up and routing the various wires, and the engine was ready to start!
IMG_20190830_184015
First crank made a loud BANG which made me very worried- did something fall into the engine?? After some quick troubleshooting, we found that somehow the EFI relay blew and that was the noise. I swapped the defog relay into the EFI spot (same relay), and tried to start it again.
After some struggling, it started! A bit of white smoke and then it was smooth.
Had a pretty major coolant leak from the oil cooler lines, so I swapped over the line from my old engine. I couldn't see any damage (maybe it just wasn't seated correctly), but it isn't leaking anymore.
Now I'm noticing a slow but steady oil leak from what appears to be the oil pan. My plan is to pull the engine again this weekend and reseal the pan with the Toyota FIPG and hope it fixes it. I'm also planning on inspecting the oil pump and surrounding seals while it's out to make sure it isn't one of them instead.
Regardless, it runs! I'm happy to have a running engine again. This one is smooth and quiet, and so far I've gotten 19-21mpg on the 3 tanks that have been through it. Not sure if that's just me being super easy on it or if this engine somehow gets better mileage, but I'll take it.
Now time to wheel it some more!
derpiful is offline   Reply With QuoteReply With Quote
Old 09-05-2019, 09:16 PM #424
STI_MECE's Avatar
STI_MECE's Avatar
And now your forever spoiled doing routine maintenance on a engine with the engine out of the car before you put it back in....
Very good job the swap. Hope it's a good motor. What are you doing with the old you pulled?
2000 SR5 4x2 Resto/Maintenance
Old 09-05-2019, 09:20 PM #425
derpiful's Avatar
Real Name: Hayden
derpiful's Avatar
Real Name: Hayden
Yeah, it sure was nice. Maybe I should just pull the motor to do maintenance from now on...
Thank you! I haven't figured out how to get rid of it yet. Still sitting in the shop on a pallet.
Old 09-05-2019, 10:35 PM #426
Road Bull's Avatar
Road Bull Road Bull is offline
Real Name: Ryder
Road Bull is a jewel in the rough Road Bull is a jewel in the rough Road Bull is a jewel in the rough Road Bull is a jewel in the rough
Road Bull's Avatar
Real Name: Ryder
Well done. I bet knocking that out is a huge relief. I hope all the seal swaps go well. Good on you for getting into it and making it happen. Once you have invested the amount of time, energy, parts, and money into these things, it seems like a waste to let all but the most serious catastrophes take them out of action. Glad yours lives on.
You might have told me before, but how is your light bar on your roof wired up? I am interested to find out if anyone has drilled a hole for a pass-through that you can run a disconnect through. Anyway. Keep on keeping on.
2002 SR-5 in Millennium Silver.
Timeline>> http://www.toyota-4runner.org/3rd-ge...-timeline.html DEAD
2002 SR5 Changeling Build https://www.toyota-4runner.org/3rd-g...ing-build.html
Road Bull is offline   Reply With QuoteReply With Quote
Old 09-05-2019, 11:02 PM #427
derpiful's Avatar
Real Name: Hayden
derpiful's Avatar
Real Name: Hayden
Huge relief, this was a bigger project than I really intended on taking on, but I'm glad I did it now! I definitely think I'm at the point where it's hard to simply move on to another vehicle.
I have the wiring going through the roof, under the headliner, down the a-pillar, and to the battery/switches from there. Under the stock roof track caps (the little ones at the ends), there's a small plug you can pull that has a hole into the headliner area. I simply unsoldered the quick disconnect plug, ran the wiring through, and soldered it back together. Now I have a plug I can disconnect and take the entire rack and lights off!
Old 09-06-2019, 03:01 AM #428
Road Bull's Avatar
Real Name: Ryder
Road Bull's Avatar
Real Name: Ryder
Cool. Thanks for the info. I think if I ever get to a roof light bar, it will probably be after other lights first. I wouldn't mind having Ditch, and bumper lights, front and rear. That would be a huge improvement. But I have to say, even adding some retrofit headlights has brightened things up a whole lot. So for now, it's an improvement.
Old 09-16-2019, 01:21 PM #429
C.Rocks C.Rocks is offline
C.Rocks is on a distinguished road
Awesome build and amazing pictures, definitely inspiring!
C.Rocks is offline   Reply With QuoteReply With Quote
Old 11-17-2019, 11:42 PM #430
derpiful's Avatar
Real Name: Hayden
derpiful's Avatar
Real Name: Hayden
Finally got around to getting my photos from Rock Therapy edited. Things have been busy recently with Sherpa Equipment Co. work, which is good! I've been working on lots of new products we're excited to unveil.
Last month I went out to Moab for Rock Therapy-- making this my 4th time out there for this event.
We ended up leaving Fort Collins about 8PM on Thursday, and got out there at about 4AM Friday morning. Woke up and ran Moab Rim, which was an awesome trail!
IMG_0567
_WPO9651
IMG_0597
FLEM8261
After the trail we headed out to the dunes and had some fun!
FLEM8485
_WPO0045
_WPO0049
The next morning we ran Metal Masher. Had a Taco blow their rear diff on the first ledge, so we took it apart, got the ring out, and reassmbled to limp it home.
IMG_0883
IMG_0893
IMG_0909_stitch
Finally, woke up Sunday, had some breakfast in town, and headed back. Quick but fun weekend trip!
Old 11-18-2019, 12:05 AM #431
heat's Avatar
heat heat is offline
heat will become famous soon enough heat will become famous soon enough
heat's Avatar
FLEM8485
amazing picture
'02 Limited 4x4 AT - Stock ~181k miles
Thundercloud aka metallic dirt
heat is offline   Reply With QuoteReply With Quote
Old 11-18-2019, 12:27 AM #432
Ryance39 Ryance39 is offline
Real Name: Ryan
Ryance39 has a spectacular aura about Ryance39 has a spectacular aura about Ryance39 has a spectacular aura about
Real Name: Ryan
Great work on the swap and the details associated. The pics from Moab look great. Looks like a fun, short trip.
1962 Mercedes 220S Heckflosse
1999 Toyota 4runner Limited - Supercharged
2001 BMW M5
1999 BMW Z3M Roadster
2020 Super White ORP
Ryance39 is offline   Reply With QuoteReply With Quote
Old 11-19-2019, 11:11 AM #433
derpiful's Avatar
Real Name: Hayden
derpiful's Avatar
Real Name: Hayden
Originally Posted by heat View Post
amazing picture
Thank you!
Thanks. Huge project, but I'm glad I did it and learned the process. It was a good time!
Old 11-19-2019, 09:14 PM #434
thezentree's Avatar
thezentree thezentree is offline
Real Name: Robert');DROP TABLE Students;
thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough
thezentree's Avatar
amazing picture
Yah can confirm. Picture is rad.
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
thezentree is offline   Reply With QuoteReply With Quote
Old 01-12-2020, 06:33 PM #435
derpiful's Avatar
Real Name: Hayden
derpiful's Avatar
Real Name: Hayden
Well, I suppose this is pretty much the end of this thread. I purchased a 2015 Tacoma TRD OR a bit ago.
IMG_0993
IMG_1000
IMG_1002
I do plan on building this very similarly to the 4Runner, just waiting on parts to start showing up!
The 4Runner is going to get listed for sale soon. I had tons of fun with this in the past few years, and it's taken me all over the country (and even Canada!), but it's time to start a new project with something a little bit newer.
Thanks to everyone who made this forum what it was, providing knowledge and advice when needed. I'll still check in every once in a while!
Eric's Build/Adventure Thread EHNWI 4th Gen T4Rs 98 04-05-2021 11:35 PM
Bruce's Adventure/Build Thread nismoxr34 5th gen T4Rs 18 08-12-2015 02:51 PM
Hargravey's Adventure/Build Thread hargravey 5th gen T4Rs 20 08-12-2015 11:14 AM
fatbacks Build and Adventure Thread fatbacks 5th gen T4Rs 21 04-29-2015 07:04 PM
GREENAMPHIBIOUS' Build and Adventure Thread Greenamphibious 5th gen T4Rs 65 04-21-2015 07:47 PM
