03-25-2014, 02:59 PM
Low Compression in one cylinder
I sold my '98 a few months ago and a couple weeks ago picked up a 2000 Limited with diff locker. It has 185k on it, and the previous owner took exceptional care of it.
So when going through and doing a full tune up, I changed plugs and wires, and put a compression tester on each cylinder while I had the plugs out. All cylinders read between 185 and 205, except for the middle cylinder on the drivers side... it was at 110!
Ive driven it about 1200 miles and in that time, it doesn't use any oil or lose any coolant. Seems to have great power and runs real smooth. Also, the spark plug from that cylinder didn't look anything different from the rest.
I'm guessing I might have a valve that is too tight and stays partially opened? Is there anything else I can test to pin point it?
03-25-2014, 05:12 PM
Piston rings can seize up. With that many miles it's not odd. Did you hold the throttle fully open when checking compression? it could be a bent or burnt valve. Perform a wet compression test and see if the pressure rises.
03-25-2014, 07:33 PM
No, I didn't hold the throttle open. I can see the reason behind that, but why would that affect this one cylinder and not the others?
03-25-2014, 11:32 PM
What do you mean by a wet compression test?
Dealing with a similar issue and A friend of mine told me to put a little bit of oil down into the cylinder prior to compressing it. He didnt explain why. Is this what your referring to?
1996 Limited 4X4 Desert Dune, 140,000 miles, E-Locker
About to get a 5-Speed r150f!
03-25-2014, 11:38 PM
"wet" means using oil,
dry is just doing a regular compression test, you should always hold the throttle wide open.
If you find one or a few cyl low there are a few problems that might cause that cyl with low psi. 1. Valves bent or open. 2. piston rings worn.
so by adding a table spoon or so of oil helps seal the gaps in between the rings for a few min. so if you compression returns by adding oil you know you have worn rings. if the psi is still the same with oil added a valve is messed up.
so in conclusion by adding oil or "doing a wet cyl test" you can eliminate one or the other to help find the real problem.
Never ask a girl if shes sick, she might not be wearing any make up. - lets just say she went storming off.
Never tell your wife she looks tired, they tend to hit and say that means she looks ugly. (weird logic i know)
03-25-2014, 11:49 PM
Awesome thanks for the clarification shoot. Can the valves be corrected without pulling the heads?
03-25-2014, 11:56 PM
No, Valves can't be removed on the 3.4l without pulling the cylinder head.
03-26-2014, 01:23 AM
Real Name: Jeff
Real Name: Jeff
A leak down test could also tell you where the problem is. If you've got nothing to lose you could try this (for rings anyways):
Seafoam, Marvel Mystery oil, Methanol injection, they really work! - YotaTech Forums
I've done the seafoam and MMO and it hasn't hurt. Others haven't had the same experience though.
97 SR5 4runner: 2" OME Lift, rear E-Locker, 231mm Tundra Brakes, 203K, B&M 70264 Tranny Cooler, Duratracs
Build
03-26-2014, 01:47 AM
Well... if I do a compression test after wetting the top of the rings with oil, and the compression doesn't improve, couldn't I just put compressed air to the affected cylinder and check to see where its escaping?
If its from a damaged or partially unseated intake valve, I'll hear it escaping through the intake, similarly through the exhaust if its an exhaust valve... right?
And if its a head gasket issue, I'll either hear the compression escaping into a neighboring cylinder, or see it bubbling into the radiator?
03-26-2014, 01:54 AM
Real Name: Jeff
Real Name: Jeff
you can do that. its a leak down test. you'll lose some air, and that is normal. If you use a leak down tester it has a gauge so you can measure how fast the air is leaking.
Build
03-26-2014, 12:06 PM
shoot, quick question here.
so if your piston ring(s) are worn and can't retain oil that is being pushed to them from the oil pump, does that lost oil get incorporated with the compression stroke and combusted with the air/fuel mixture?
03-26-2014, 12:33 PM
so if your piston ring(s) are worn and can't retain oil that is being pushed to them from the oil pump, does that lost oil get incorporated with the compression stroke and combustion with the air/fuel mixture?
i dont think you quite understand how piston rings work. they are mainly gaskets to prevent any "blow by" or air escape as the piston moves up and down. on the bottom end oil lubricates the crank shaft and barrings along with other components. top side of the piston air and fuel are mixed and ignited then dispelled out, this needs suction , compression and pressure to cycle the air and fuel, and this is done by the up and down of the piston.
The piston rings help create a tighter seal between the piston and the cylinder wall. if your piston rings are worn they are letting more blow by (air pass by them when the piston moves up and down) and oil can slip from the bottom to the top and get burned. thats one way people burn oil, also why blue smoke is seen coming out of the exhaust pipes.
03-26-2014, 12:42 PM
thanks for the explanation shoot!
how is the piston ring itself lubricated then? I thought it is straight up metal? Against the cylinder wall would be metal on metal...?
03-26-2014, 02:10 PM
a little bit by oil as for the lower rings that come in contact with the oil in th bottom end, but yes you are right, metal on metal. but they are designed to be like that.
10-01-2017, 09:12 PM
I also have low compression on one cylinder and am hoping someone can help me out. My compression results were
Cyl 1: 195. Cyl 2: 175
Cyl 3: 195 Cyl 4: 190
Cyl 5: 200 Cyl 6: 145
Cylinder 6 went up to about 185 when I put some oil in there
From what I have read this probably means I have a worn piston ring in #6 - but is this the only explanation? I have read that there is a possibility that the ring could be gunked up and stuck, resulting in a bad seal. Has anyone had any luck improving compression with a sea foam treatment through the pcv hose?
