engine stumbles on cold startup
Hi all,
Need some advice here.
I recently had a P0304 code. I ended up replacing the injector on that cylinder with another good used one, just until I can get my other 6 injectors out to Witch Hunter. While the newer injector solved the p0304 code, the engine stumbles when it's started cold. It does this for only 1or 2 seconds then smooths out. Could this be a sign of a leaking injector? Any other ideas?
Thanks,
Scott
99 T4R SR5. OME 906s rear.Stock front springs with 1/4" spacers and Bilstein HDs all around. B&M trans cooler. Deck plate mod and rear diff breather mod. Blacked out bumpers and graphite wheels. Cobra CB in the ashtray. Tundra 199 brake upgrade. Pioneer MVH360BT head unit.
Necessity is the mother of invention.
Recent studies have shown that aggressive therapy combined with owning Toyotas, can be affective in breaking the cycle of Jeep addicition.
