Old 04-01-2014, 12:30 AM #1
The4kbeast's Avatar
The4kbeast The4kbeast is offline
The4kbeast is on a distinguished road
The4kbeast's Avatar
Arrow Radflo Suspension Technologies Factory Tour + Sneak Peek @ My New Setup
For those of you that don't venture outside of the 3G section, I visited Radflo's manufacturing facility earlier this month in Fountain Valley, CA and took some pictures I thought I'd share. I posted it in the general suspension section since they sell across generations.
Link: http://www.toyota-4runner.org/engine...ml#post1666043
My 3rd gens new setup, 2.5" cans front and back, fronts are extended length:
Front Coil-Over Shock Details (copied from their website)
Body: Threaded SSID alloy steel tube
Rod: Mirror polished Nitro Steel®
Rod Guide: CNC machined bronze, Teflon® coating
Seal: Combination Quad-Ring® and lip seal, rebuildable
Piston: Radflo aluminum Freeflo™ racing piston
Valving: Self-adjusting, velocity-sensitive deflective disc, consumer or factory tunable
Oil: Radflo high-temp foam resistant suspension fluid
Pressurization: Nitrogen gas, 200 psi
Bearings: Teflon® lined spherical steel
Body Caps & Eyelets: CNC machined 6061 or 7075 aluminum, black anodizing
Springs: Eibach® 14" 650 lb/in coil springs
Coil-Over Hardware: CNC machined aluminum with Nylatron® spring slider
Finish: Mirror polished, clear cadmium plating, chrome optional
Service: Consumer or factory serviceable
2.5" rear shocks:
Rear Non-Coil Shock Details (copied from their website)
Body: Smooth SSID alloy steel tube
Build/install details will be added to my build thread soon!
-4k
2000 4Runner SR5 Highlander Edition
200k mi Member <Crazy-detailed Build Thread>
Others: 2013 Prius Plus | 1983 Toyota Starlet
The4kbeast is offline   Reply With QuoteReply With Quote
Old 04-01-2014, 12:41 AM #2
nor_cal51501 nor_cal51501 is offline
Real Name: Shane
nor_cal51501 is on a distinguished road
Real Name: Shane
That's a really clean setup. Those rear shocks look BEEFY!!! How's the ride quality? What price point are they? How much lift did you yield in front? 2.5"? 3"?
'01 Sport: E-locked, 285/70/17's, TURD S/C, 200k club
My Build: http://www.toyota-4runner.org/3rd-ge...ld-thread.html
nor_cal51501 is offline   Reply With QuoteReply With Quote
Old 04-01-2014, 01:31 AM #3
The4kbeast's Avatar
The4kbeast's Avatar
Beefy
Thanks, they are beefy. A 2.5" can holds about as much fluid as a 2.0" with an external reservoir. No external reservoir means I'm not sweating ripping it off. That said, I may get the upgrade when I get my first or second rebuild in the coming years.
Ride
Radflo used to run firmer setups based off their factory racing days, but the owner Glenn said that they softened their base tunings after they got more requests for the old Overland Warehouse tune. The new setup is much better than my old, stiff experimental Silverado Bilstein rear setup which was overly harsh, especially paired with OME 890's. Fronts feel great, and although they have less small bump compliance than the rear, some of the ride quality issues can be attributed to the spring preload I'm running. More on that below.
Compared to my brothers Icon setup, it rides nice enough on the road. The Icon setup is firmer than a typical Bilstein setup on both small bump and large hits thanks to its advanced valving. But there is a gap in mid-speed valving that I felt left too large of a gap between slow speed and high speed events on the Icons (granted, the rig I was in had suspended bump stops so the speeds achievable are much higher).
I'm trying to get the guys together to plan a wheeling trip for a true test in the off-highway.
MSRP
$1,750. 1995 ? 2002 Toyota 4Runner / Prado 90 2.5? Performance Suspension System
Ride height
I set them up for level frame height after everything settled, so I'll have to measure center hub to fender height. Before the springs settled in on a half tank of gas they were at 24". My sagged OE springs were 19.5... so figuring they were around 20.5" stock, I'm guessing with my adjustments I'll end up with around 3". I'll look and measure soon.
-4k
Old 04-01-2014, 04:26 AM #4
04desertrunner's Avatar
04desertrunner 04desertrunner is offline
04desertrunner is on a distinguished road
Nice! I been eyeing the radflo set for about a year, almost bought the high desert kit sonoran steel offered; however, the money went to getting the runner armored.
My ride- 1999 4runner 4x4 limited- rr diff, toytech ULK with super flex coils, light racing uca's 285/75/16 bfg km2 on mb razor wheels, sliders by SRD, savage offroad bumper F and R and skids.
my outdated build: http://www.toyota-4runner.org/3rd-ge...ld-thread.html
coming soon: 1 inch body lift, 35's, and 4.88 gears.
04desertrunner is offline   Reply With QuoteReply With Quote
Radflo Suspension Question 03 T4R Limited 4th Gen T4Rs 22 05-15-2014 03:26 PM
Radflo Suspension Technologies Factory Tour for the T4R Forum The4kbeast Engines / Suspension / Wheels / Tires / Audio / Accessories 0 03-31-2014 11:56 PM
Radflo Suspension Kits at Metal Tech 4x4! MT4X4 Metal-tech 4x4 2 06-18-2013 05:05 PM
Another Suspension question - Toytec Radflo vs OW CApilot78 5th gen T4Rs 1 12-16-2010 07:24 AM
Sneak peek of '06 Surf sharivan 4th Gen T4Rs 87 09-30-2005 08:19 PM
