Old 04-02-2014, 06:48 PM #1
tenro1 tenro1 is offline
tenro1 is on a distinguished road
Normal Coolant/Trans temps?
Just wanted to find out what operating temps are considered normal in stop and go traffic.
Ambient outdoor temp - mid-80's
I am seeing about 201-203 on the coolant in stop and go, and between 190-201 on trans temp. Everything seems to operate fine. The coolant temp is real steady when it gets to its range, the transmission will vary between low 180's to mid/upper 190s for a few mins depending on how heavy the traffic is. Once I get moving again, trans temp drops down to around 192-194.
I am driving a 2001 T4r 6cyl. auto trans, 2wd...240k miles.
Thoughts?
Thanks!
tenro1 is offline   Reply With QuoteReply With Quote
Old 04-02-2014, 08:32 PM #2
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
wish i had temp guages
like you. I only have the factory rad temp, its always (night/day/summer/winter/stop/go) pointing a little less than 1/2 way up (like 8:45) after warming up (which is really fast). I'm sure someone else will give you degree specific temps.
Did you add the gauges or already there? But I'd say your temps are just FINE.
Old 04-02-2014, 08:44 PM #3
Zachpins34's Avatar
Zachpins34 Zachpins34 is offline
Real Name: Zach
Zachpins34 is on a distinguished road
Zachpins34's Avatar
Real Name: Zach
My ATF is usually between 160-180 if that helps. During hot days Ive seen it go up past 200, and I continued to drive, definitely a little worried though.
My Build Thread
1999 Highlander Edition w/ Factory E-Locker: Alarm/remote start, FN 5 star wheels, 285/75/16 Duratracs, King 2.4 Ext Travel C/Os, LC shocks/8 wraps, 1" Diff drop, Airaid Intake, Dual B&M 70264's, Satoshi grille, 01 Tails, shackles, Rear diff breather extension, Blue wire mod,Taco whip antenna, Window tint, Bi-xenon Morimoto Mini Stage III projectors, 231mm Tundra Brake Upgrade, Interior LEDs.
Zachpins34 is offline   Reply With QuoteReply With Quote
Old 04-02-2014, 09:21 PM #4
Thanks for the input - I am actually using Torque app on my android, to get real time readings. I think they are pretty accurate. I am just a bit worried about the trans temp....
Old 04-02-2014, 09:23 PM #5
Me too...hoping someone can provide a range of temps so I will know if there is an issue coming up...and I can address it before it becomes one.
Old 04-02-2014, 10:14 PM #6
MCObray's Avatar
MCObray MCObray is offline
MCObray is on a distinguished road
MCObray's Avatar
Engine Temp: 193-198. I've seen as high as 204.
Transmission Temp: 140-170. My high was 210, on a steep curvy grade on HWY 101, north of Lincoln City.
^^Via Scanguage II^^
I just ordered Timing Belt/Water Pump/Misc. Seals & Belts, as well as new Radiator and B&M 70264. I have no records of previous maintenance, although PO said major maintenance performed at 90K, so i'm going to get some piece of mind by getting those parts replaced in the coming weeks.
2002 Toyota Tacoma DC TRD
MCObray is offline   Reply With QuoteReply With Quote
Old 04-03-2014, 04:42 AM #7
THatfield's Avatar
THatfield THatfield is offline
Real Name: Taylor
THatfield is on a distinguished road
THatfield's Avatar
Real Name: Taylor
When I first got my runner, engine temp was usually 193-198, and ATF was 110-150. After a TB&WP at Toyota, engine is 198-208 and ATF is 110-145. Highest engine temp was 211 and highest ATF was 201 in the Adirondacks on the NY/Mass Pike.
1999 4Runner SR5 Highlander V6 4WD ELocker
2008 Toyota 4Runner LTD V8 4WD
2000 4Runner SR5 V6 4WD- Sold
"Why do people measure life by the years, and not by how good the years were?"
THatfield is offline   Reply With QuoteReply With Quote
Old 04-03-2014, 10:35 AM #8
Robb235's Avatar
Robb235 Robb235 is offline
Real Name: Robert
Robb235 is on a distinguished road
Robb235's Avatar
Real Name: Robert
With my stock trans cooler bypassed, and using only the B&M 70264, my trans temps are usually around 120° to 145° depending on ambient temps. Highest I've seen was around 200° while going up Signal Mountain, TN.
1999 Toyota 4Runner Limited 4x4 - Turbocharged Garrett 57-trim T3/T4 - URD AFR Sensor Calibrator - DW255 fuel pump - 7MGE Supra 315cc “lime green” fuel injectors - 231mm Tundra Brakes - B&M 70264 Transmission Cooler - Monitoring ATF Temps and AFRs With My iPhone - DIY Projector Headlight Retrofit - Cooper Discoverer AT3 - OME 906 Coils & Rancho 9000XL Shocks (Rear) - Airlift 1000 - RadioShack $5 Rear O2 Simulator
2000 Yamaha XR1800 Jet Boat - MR1 4-Stroke Engine Swap
Robb235 is offline   Reply With QuoteReply With Quote
Old 04-03-2014, 10:45 AM #9
MCObray's Avatar
MCObray's Avatar
Interesting... I'll have to monitor the temps after my TB & WP is done next week. I wonder what's up with the increase? I've heard that the thermostat might need to be rotated?
Old 04-03-2014, 10:47 AM #10
Robb235's Avatar
Real Name: Robert
Robb235's Avatar
Real Name: Robert
Bingo, that's most likely it. Jiggle valve of the t-stat needs to be at the 6 o'clock position.
Old 04-03-2014, 11:54 AM #11
THatfield's Avatar
Real Name: Taylor
THatfield's Avatar
Real Name: Taylor
Yeah I need to move the valve. But from what I've read the slight increase in temps is no big deal, however if you're supercharged, it most definitely needs to be correct. I'm not super concerned, however when I replace the radiator and the coolant has been drained I'll adjust it correctly.
Normal coolant temps cj80cruiser 3rd gen T4Rs 161 08-23-2023 02:31 PM
Coolant Temps After Water Pump Change bjarratt 3rd gen T4Rs 21 03-16-2014 08:45 PM
Transmission and Coolant Temps both rising... THatfield 3rd gen T4Rs 0 02-18-2014 05:13 PM
normal transmission temps? vthokie 3rd gen T4Rs 4 05-09-2011 12:12 AM
Piston Slap V8. Is this normal in colder temps? JP4RNR Maintenance/Detailing 7 01-04-2009 11:05 PM
