Old 04-19-2014, 01:39 PM #16
BrianSD_42's Avatar
BrianSD_42 BrianSD_42 is offline
Real Name: Instagram: briansd_97r
BrianSD_42 is a jewel in the rough BrianSD_42 is a jewel in the rough BrianSD_42 is a jewel in the rough
BrianSD_42's Avatar
Depending on the type of circuit it will make a difference where in the circuit you measure voltage.
Those he commands move only in command, Nothing in love. Now does he feel his title, Hang loose about him, like a giantís robe, Upon a dwarfish treasonous thief.
BrianSD_42 is offline   Reply With QuoteReply With Quote
Old 04-19-2014, 10:31 PM #17
19963.4lsr5 will become famous soon enough
I use this. It hasn't let me down yet. It's revealed more bad connections Han anything else.
Old 04-20-2014, 01:38 AM #18
BrianSD_42's Avatar
BrianSD_42's Avatar
I have that as well.
Also reading directly off battery isn't a bad idea .
Old 04-20-2014, 09:16 AM #19
TakeitApart TakeitApart is offline
TakeitApart is on a distinguished road
Wanna do something fun? Set your meter to DC volts. Put one lead from your meter on the hot post of the alternator, while running, and the other lead on the hot post of the battery. The voltage that shows is how much voltage you are losing through the wiring and connections.
Do the same thing from the battery negative terminal to the alternator case.
Now take what you got from the hot side and add the number you got from the negative side and report back.
TakeitApart is offline   Reply With QuoteReply With Quote
Old 04-20-2014, 09:53 AM #20
chimpy's Avatar
chimpy chimpy is offline
Real Name: Brian
chimpy is on a distinguished road
chimpy's Avatar
Real Name: Brian
Yeah, Insulated(hot) side should not see a voltage drop >.4 and the un-insulated side(negative) should not see a voltage drop > .2
Dummy me didn't remove the circuit board form inside the cell phone lighter adapter which contains a resistor that obviously reduces voltage for charging a cell phone so I would never see 12v, only 6v which would power/charge the cell phone. Sorry for the senior moment. Will also be able to flip the fluke over to AC and see if the rectifier diode leaks are over spec when I get this adapter redone.
You can't fistfight tyranny!
chimpy is offline   Reply With QuoteReply With Quote
Old 04-20-2014, 03:46 PM #21
Bumper2Bumper Auto's Avatar
Bumper2Bumper Auto Bumper2Bumper Auto is offline
Official Vendor
Real Name: Bill
Bumper2Bumper Auto is on a distinguished road
Official Vendor
Real Name: Bill
Yeah, most cell phones actually charge at 5-6 Volts (USB standard voltage) so that would explain your earlier results!
<!--4X4 and 4X2 Wheel Bearing assm, COMPLETE and bolt-in! Order here!!
You can contact us by PM, email, or phone.
Email: Marionb2bauto@gmail.com
Phone: 334-345-0422
Bumper2Bumper Auto is offline   Reply With QuoteReply With Quote
Old 04-19-2019, 11:00 AM #22
Rpreme Rpreme is offline
Real Name: The Rpreme
Rpreme is on a distinguished road
Sorry for opening an old thread. I felt it was appropriate to post it here.
Since operating charging voltage is 13.7v - 14.0v at idle, my scangauge II is reading 13.5v- 13.6v as of late at idle and under loading.
Is it time to replace my battery?
BTW, the scangauge II is an awesome gauge.
2000 SR5 "Highlander" Sport 4WD Millennium Silver Metallic
Rpreme is offline   Reply With QuoteReply With Quote
Old 04-19-2019, 11:14 AM #23
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has a spectacular aura about Bumbo has a spectacular aura about Bumbo has a spectacular aura about
Bumbo's Avatar
No, that sounds normal to me.
Old 04-19-2019, 01:29 PM #24
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk has a spectacular aura about TheDurk has a spectacular aura about
MY GARAGE
TheDurk's Avatar
MY GARAGE
Trick question, huh? Charging voltage has little to do with battery health, except that poor charging performance will likely kill a battery eventually.
If you want to check battery health, charge it up and find someone to do a load test. If you want to check your charging system, go here:
http://www.teamtoyota4x4.org/archivi.../chasy/ovi.pdf
Idle voltages are not that important. 2000 RPM values are what you want to look at. Always worth cleaning terminals and grounds and inspecting cables.
My Backyard Frame Swap
Old 04-19-2019, 03:53 PM #25
That voltage on the scangauge display is voltage read at the ECU or ignition module. It will be different than the reading at the battery posts. I have a volt meter in my cig lighter to watch the charging and system voltage.
Old 04-20-2019, 01:23 AM #26
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton is on a distinguished road
pluton's Avatar
Real Name: Keith
Charging voltage is regulated by temperature. On a cold morning, you could see 14.3 or maybe higher, on a hot day 13.5.
97 4R SR5, 4WD/Elock, 3.4, 5spd. OME881/890 springs/OME shocks, 265/70 BFG AT/KO.
pluton is offline   Reply With QuoteReply With Quote
Old 04-23-2019, 10:48 AM #27
Thanks, you're right! I see 14.0 in the morning going to work and 13.5-13.7 in the day going home in 80 degree weather.
Voltage Regulator on the Alternator Question snowbrdr033 4th Gen T4Rs 3 10-24-2011 08:38 AM
Voltage problems? dragon.burn Classic T4Rs 1 01-10-2011 09:37 PM
stray voltage in my car? bman1828 Problems & Warranty Issues 3 04-29-2008 11:29 AM
Voltage Stabilizer for our 4R Jacobzky 4th Gen T4Rs 6 03-31-2007 09:02 PM
Voltage system?? mole177 Engines / Suspension / Wheels / Tires / Audio / Accessories 2 09-08-2006 02:51 PM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
