Old 02-22-2021, 06:06 PM #16
spartacus's Avatar
spartacus's Avatar
Originally Posted by skemp117 View Post
Sorry to bring this thread back from the dead, but I am currently having the same issues and I'd like to know how you ever fixed it. I've tried everything. I've searched every forum. I've even tried using techstream (just to discover my crappy Chinese cable was garbage.)
The last post on the following thread might help.
Video on how to program your key fob
Old 02-24-2021, 10:10 AM #17
JCruz JCruz is offline
JCruz will become famous soon enough
I had a similar problem.
For you to be able to program your keyfob all the doors have to be closed.
The problem is, if your rear hatch has broken wires, the computer will think the rear hatch is open, and prevent you from programming.
This is what happened to me. After I repaired the wiring to the rear hatch I was able to program my remote. I had to help the door locks up and down by hand, but it worked.
JCruz is offline   Reply With QuoteReply With Quote
Old 03-01-2021, 06:19 PM #18
skemp117 skemp117 is offline
skemp117 is on a distinguished road
Thanks for the replies. I checked the rear hatch wiring and confirmed all functions are working normally. I also tried performing the programming steps for the VIP RS3200, but that did not work either. I know all doors are cycling the locks properly, I know the ignition cylinder recognizes when the key is inserted and responds to the different modes correctly, I know that the door switches work for detecting open or closed, and I know I have the factory keyless entry system. The body ECU and the Backdoor ECU seem to be working just fine as well. Maybe it is because the car is Canadian? At this point, I'm not sure what to do. I may try checking the functions of every line on the ECU's
skemp117 is offline   Reply With QuoteReply With Quote
Old 03-01-2021, 09:14 PM #19
ej86923 ej86923 is offline
ej86923 is on a distinguished road
Having the same problem on a 99 SR5. I still have one original remote that is working so I know the truck is capable. I just can't get into programming mode. I must have tried 10 times on separate occasions. Is the sequence the same for an SR5 as opposed to a limited?
ej86923 is offline   Reply With QuoteReply With Quote
Old 03-03-2021, 10:52 PM #20
Hey guys, I'm wondering if there is a simple way to see if the 4runner knows it is locked without me opening up the door again and testing the sensor. Does it honk when you lock and close all the doors? Does the security light do anything different? Is there any way to tell if it knows it is locked? That could be the problem for me.
Old 03-10-2021, 04:25 PM #21
I have a lead on some info. The dealership said they couldn't program my remote because the VIN is Canadian and they don't have the licensing tools
FS: Power Door Lock Actuator with Lock Latch - rear passenger side T4RTX For Sale: T4R Items 4 06-26-2014 02:58 PM
2007 4runner driver side back seat door lock won't lock Richqwert7 4th Gen T4Rs 0 11-30-2013 06:28 PM
wireless door lock enable when started? Limited99 3rd gen T4Rs 0 10-14-2009 09:12 AM
How do I program rear window on wireless remote 2003? 4RunninMO 4th Gen T4Rs 3 09-02-2009 06:34 PM
