That is called the double cardan joint. You can replace bearings, but it isn't as straight forward as it should be, you will have to modify the bearings a bit an you have to buy very specific bearings. Search here for double cardan and you will find some threads on it. 1 thread I have linked to a couple time has the PN of a bearing that fits with some minor modification, but I don't have the link handy.
If you don't want to get pretty deep into this, then you should probably just pick up a used one from a junk yard.
2000 SR5 3.4L V6 Automatic 4x4, e-locker, 175k Miles, Rust
Imp. Jade Mica with Oak Leather Interior, Field Monitor Unit - B&M Tranny Cooler - SG2 - New (to me) rear axle assembly - Goodyear Duratrac 265/75-16 - 1.8" Ironman Front Lift, OME 906/Procomp 9000 Shocks
http://www.toyota-4runner.org/3rd-ge...ld-thread.html
