Old 04-20-2014, 07:02 PM #1
johndavidwright johndavidwright is offline
johndavidwright is on a distinguished road
High Transmission Temps?
I'm sure this has been posted but couldn't find it after searching for a little bit.
I have a 70264 SuperCooler on my 99 SR5 2WD and I'm bypassing the stock radiator, just to prevent pink milkshake. I'm in Birmingham, Alabama and temps since I have installed the supercooler have been at max 75 degrees. I've seen my scangauge read the trans temp 185 and I've seen it that high multiple times just driving around the city. Birmingham isn't flat, but not mountainous at all. These temps seem pretty high to me.
While I'm driving on the interstate at 70-80mph, temps are more around 125-150 depending on the day.
Any ideas? Am I concerned for no reason? Do I need to buy a fan?
Help is appreciated!
johndavidwright is offline   Reply With QuoteReply With Quote
Old 04-20-2014, 07:34 PM #2
RedSled's Avatar
RedSled RedSled is offline
RedSled has a spectacular aura about RedSled has a spectacular aura about
RedSled's Avatar
You are not having high temp. problems.
RedSled is offline   Reply With QuoteReply With Quote
Old 04-20-2014, 07:44 PM #3
JBurt's Avatar
JBurt JBurt is offline
Real Name: Jeff
JBurt has a spectacular aura about JBurt has a spectacular aura about
JBurt's Avatar
Real Name: Jeff
google
ATF Temp-How hot is too hot?
97 SR5 4runner: 2" OME Lift, rear E-Locker, 231mm Tundra Brakes, 203K, B&M 70264 Tranny Cooler, Duratracs
Build
JBurt is offline   Reply With QuoteReply With Quote
Old 04-20-2014, 08:37 PM #4
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
Make sure the cooler is mounted right up against the condenser in front of the fan.....
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 04-21-2014, 07:42 AM #5
Robb235's Avatar
Robb235 Robb235 is offline
Real Name: Robert
Robb235 is on a distinguished road
Robb235's Avatar
Real Name: Robert
Your temps look fine to me.
I just got finished towing a Uhaul 6x12 enclosed trailer, filled with heavy boxes and furniture. Also had the rear seats folded down, and loaded up with heavy boxes in the back. There were a lot of rolling hills on my 330 mile trip. The first part of the trip was on a state highway, so 60mph limit, there was a lot of downshifting going up the hills. My trans temp typically got up to 220 degrees while pulling the hill. Once it got up to 230 on a particularly long hill. After I crested the hill and the torque converter locked back up, temps would drop back down to 180.
1999 Toyota 4Runner Limited 4x4 - Turbocharged Garrett 57-trim T3/T4 - URD AFR Sensor Calibrator - DW255 fuel pump - 7MGE Supra 315cc “lime green” fuel injectors - 231mm Tundra Brakes - B&M 70264 Transmission Cooler - Monitoring ATF Temps and AFRs With My iPhone - DIY Projector Headlight Retrofit - Cooper Discoverer AT3 - OME 906 Coils & Rancho 9000XL Shocks (Rear) - Airlift 1000 - RadioShack $5 Rear O2 Simulator
2000 Yamaha XR1800 Jet Boat - MR1 4-Stroke Engine Swap
Robb235 is offline   Reply With QuoteReply With Quote
Transmission and Coolant Temps both rising... THatfield 3rd gen T4Rs 0 02-18-2014 05:13 PM
Transmission Temps: Observations and Revelation OrdnanceMarine General Discussions 58 06-12-2013 07:24 PM
High unstable Idle since Cold temps set in fishrod Classic T4Rs 15 11-19-2011 12:51 AM
brake pad deposition at high temps, not warping? the great him 3rd gen T4Rs 15 07-02-2011 02:56 PM
normal transmission temps? vthokie 3rd gen T4Rs 4 05-09-2011 12:12 AM
