Old 02-11-2017, 01:39 AM #16
JayRolla's Avatar
JayRolla JayRolla is offline
JayRolla will become famous soon enough JayRolla will become famous soon enough
JayRolla's Avatar
Originally Posted by skiyota76 View Post
I need some info on lubricant for my TC they now make a rubbing sound and I can feel it inside with every flex.
Sent from my SM-G920V using Tapatalk
https://www.google.com/search?q=supe...UXhBeYQgTYImwQ
I believe this is what most recvommend.
JayRolla is offline   Reply With QuoteReply With Quote
Old 02-11-2017, 02:10 AM #17
JBurt's Avatar
JBurt JBurt is offline
Real Name: Jeff
JBurt has a spectacular aura about JBurt has a spectacular aura about
JBurt's Avatar
Real Name: Jeff
I've heard good things about that too. I like the tri flow because it is small enough to carry around in my glove box.
97 SR5 4runner: 2" OME Lift, rear E-Locker, 231mm Tundra Brakes, 203K, B&M 70264 Tranny Cooler, Duratracs
Build
JBurt is offline   Reply With QuoteReply With Quote
Old 02-11-2017, 02:33 AM #18
St0neWhite's Avatar
St0neWhite St0neWhite is offline
St0neWhite is on a distinguished road
St0neWhite's Avatar
I grease my upper ball joints quarterly or before/after harsh conditions, i.e. Water/sand. I have typically used lithium based because I wanted to keep them well lubed while playing in the water/sand. However; synthetic grease (Mobil 1) is hugely more robust than regular(so I have heard).
This is what I switched to. For my grease zerks and ball joints.
Hope this helps, cheers !
I see u are in CO !
I'll be Idaho this week boarding and then next weekend in Colorado. Beautiful country up there ! Probably hit up keystone while I'm there.
St0neRunner Build: http://www.toyota-4runner.org/3rd-ge...0nerunner.html
Deck plate mod, high flow filter, pulstar plugs, 3" lift w toytec coil overs, diff drop, Highflow cat, mangan flow muffler, built in cargo box, air compressor, custom built bumper, modified roof rack, Remote control gobee lights, hood scoop led light, bluetooth, gps, cb, obdII reader, new leather seat with seat heaters installed. Many hrs of maintenance and suspension part replacement
St0neWhite is offline   Reply With QuoteReply With Quote
Old 02-11-2017, 09:28 AM #19
JayRolla's Avatar
JayRolla's Avatar
Its what icon told me to use.
Old 02-11-2017, 03:33 PM #20
Scramble's Avatar
Scramble Scramble is offline
Real Name: Scramble
Scramble has a spectacular aura about Scramble has a spectacular aura about
Scramble's Avatar
Real Name: Scramble
I'm using this.
https://www.amazon.com/DuPont-Silico...lon+lube+spray
____________
'99 4Runner - 2.7L 3RZ, 5 Speed, 4.56 Gears - Lifted, Locked & Loaded - 166k Original owner - http://www.toyota-4runner.org/3rd-ge...ld-thread.html
'99 Limited - E-Locker- Stock (for now) - 233k 2nd Owner http://www.toyota-4runner.org/3rd-ge...ted-build.html
Scramble is offline   Reply With QuoteReply With Quote
Old 04-20-2017, 02:26 PM #21
stever1000 stever1000 is offline
stever1000 is on a distinguished road
At what lift height are new UCA's required? I'm trying to decide (for the future) to rebuild my UCA's or wait until I need aftermarket arms for a lift
stever1000 is offline   Reply With QuoteReply With Quote
Old 04-20-2017, 02:42 PM #22
Tyler James Inc's Avatar
Tyler James Inc Tyler James Inc is offline
Tyler James Inc will become famous soon enough
The main goal is to correct alignment. You can also use certain(SPC) arms to gain firewall clearance with bigger tires.
Plenty of guys are running 3" lifts with stock arms, but caster isn't ideal.
My 2001 SR5 Ultimate Thread
My OEM+ '97 Limited Thread *Sold*
Anti-Satoshi Member #1
Tyler James Inc is offline   Reply With QuoteReply With Quote
Old 04-20-2017, 02:58 PM #23
JayRolla's Avatar
JayRolla's Avatar
2" lift and under you can get over 2* on stock arms. Over that lift amount you can live with stock arms but to get ideal caster you need aftermarkets.
SPC are nice like stated above because they are full adjustable, strong, give more travel and have enclosed ball joint that has a grease zerk. They make noises.
Old 04-24-2017, 12:48 AM #24
Thanks for the info!
Old 04-24-2017, 07:04 AM #25
jstim's Avatar
jstim jstim is offline
Real Name: Josh
jstim is on a distinguished road
jstim's Avatar
Real Name: Josh
Nobody even gave the built right ucas a nod....damn. They are good as any of the uniballs and they are cheaper.
1999 Toyota 4Runner SR5 - Icon CDCV 2.5's, SCS Matte Black SR8 wheels, Audio overhaul (Alpine CDE-HD149BT, Kicker CS65s up front and CS5s in back
My build thread:http://www.toyota-4runner.org/3rd-ge...ack-pearl.html
2015 Toyota 4Runner Trail Premium traded for 2015 Ford F-250 Super Duty
Originally Posted by StreetCreeper View Post
And you also tell him that right before Absalom smokes them on the trail—he skins them first and fashions their dirty lifeless hides into camp-hats to keep warm at nite...
jstim is offline   Reply With QuoteReply With Quote
Old 10-21-2020, 11:22 PM #26
Spoods7.0 Spoods7.0 is offline
Spoods7.0 is on a distinguished road
Originally Posted by SL28 View Post
When I build out my t4r (soon), the front end is going to include TC UCA's. The uniball construction is the way to go for lifted and extended travel. Total Chaos UCA's cost a bit more than others, but for good reason.
I had Light Racing UCAs on my Tacoma along with extended travel Icon COs.
The ball joints failed and did so WAY too early in my opinion. The idea behind the LR construction seems good, but I had bad luck with them holding up.
a handful of year late but whatever. i take it i can run the tc's without a extended travel kit?
Spoods7.0 is offline   Reply With QuoteReply With Quote
Old 10-28-2020, 10:06 AM #27
nateboor nateboor is offline
nateboor is on a distinguished road
MCM Fab Uniball UCA's are another great option even cheaper than Camburg ($675) on SRQ's website. I think all these UCA's are essentially the same construction/strength - just my 2 cents. Camburg brake line tabs do look nice though. Uniball all the way for weekend warrior build though!
nateboor is offline   Reply With QuoteReply With Quote
Old 10-28-2020, 11:17 AM #28
G_Raw's Avatar
G_Raw G_Raw is offline
G_Raw has a spectacular aura about G_Raw has a spectacular aura about
G_Raw's Avatar
I agree that for what most of us weekend warriors do any uniball UCA will suffice. They are designed strong. There is a part of me that thinks you'll pay more for a bigger name companies product over gain in quality...but that me. I did a lot of suspension work to my rig in the last year. Here is what I can tell you...
Uni ball UCA definately a good move to make. Alignment, flex, no rub issues. What's not to like. When my uniball wear out I'd swap to SS ones.
The uniball does collect a lot of dirt especially with grease all over it. So wash it off...and regrease the ball. It rains a bunch here in winter which also causes the uniball to get dirty and grease to wash away quicker...so regrease more frequently. I now stock plenty of red and tacky at home because of this. Do I regret going to uniball UCA because of this extra maintenance? Not one bit!
With that said I'm rocking Built Right UCAs
Side note if using heim joint sway bar links like Mike puts out, you'll be in a similar boat. Tri flow dry lube is your friend. It rains the lube gets washed out so relube. You wash it the lube gets washed out so relube. I carry a small bottle of tri flow in the rig and a big bottle next to all my red and tacky.
Basic clean and lube for these types of things are done in minutes with a cold beer in hand. Not some thing that should be considered a reason to not make these upgrades since the performance gains out weigh my time spent lubricating joints.
99 Limited: 4wd conversion, OME 883/891, Built Right UCAs, Armored and winch up front, 285's with 4.88s and dual locked.
G_Raw is offline   Reply With QuoteReply With Quote
2002 , cambur , suspension , totalchaos , uca's
Spc upper control arms kammando808 3rd gen T4Rs 87 10-12-2023 06:49 PM
Which Upper Control Arms ? xcmountain80 3rd gen T4Rs 73 06-08-2015 08:12 PM
WTB: SPC Upper Control Arms 4th Gen knightsfs4 Want to Buy/Trade 1 11-07-2013 12:41 AM
Upper Control Arms Mick1 For Sale: T4R Items 0 06-01-2012 05:50 PM
Upper Control Arms digphisher 4th Gen T4Rs 2 10-20-2010 01:37 AM
