Old 05-03-2014, 06:13 PM #1
lewisp lewisp is offline
lewisp is on a distinguished road
Smile Need new upper control arms!
Hey guys , I've had it with my stock UCA's, I cant stand the handling and inability to have a proper alignment anymore... I also have the annoying clunking over repeated bumps, braking, and stopping, which seems to be the UCA's. I'm looking at a couple options for my 2002 4runner. I wanted some advice from those of you that run Aftermarket UCA's. I'm Running 2.5" lift up front with Bilstein 5100's and stock coils.
Here's what I'm looking at
Light Racing UCA's Light Racing UCA - Adjustable Upper Control Arm Set
Camburg Camburg Upper Control Arms - Uni-Ball
Total Chaos Total Chaos Upper Control Arms Set - Early Tacoma & 4Runner
I would love to hear what you all have to say about them, make me the best recommendation. I'd like to get a kit that has all the replacement hardwear so I don't re-use the old stuff.
Thanks
lewisp is offline   Reply With QuoteReply With Quote
Old 05-03-2014, 06:56 PM #2
kolelt kolelt is offline
kolelt will become famous soon enough kolelt will become famous soon enough
All I can say it's $$$$$$$$
From what I hear, rd are the most adjustable.
And the other ones are they say stronger , but the uni ball is exposed and can collect dirt. Just little extra maintance.
97 3.4 JDM/5 Speed swap/eLocker Swap/ICON CDC all around/+more.....
kolelt is offline   Reply With QuoteReply With Quote
Old 05-03-2014, 10:09 PM #3
C'mon, does anyone have any advice for me!?!
Old 05-03-2014, 10:17 PM #4
JDMcQ JDMcQ is offline
JDMcQ is on a distinguished road
I had the the Total Chaos UCAs on my Tacoma. They are great, really well made, got me aligned where I needed to be and helped the suspension flex a little better.
The Uniball is exposed, you have to clean and lube it regularly. I highly recommend the stainless steel uniballs. I got the regular ones and they deteriorated from road salt pretty quickly. Had to press them out and replace with the SS units.
JDMcQ is offline   Reply With QuoteReply With Quote
Old 05-04-2014, 02:31 AM #5
JBurt's Avatar
JBurt JBurt is offline
Real Name: Jeff
JBurt has a spectacular aura about JBurt has a spectacular aura about
JBurt's Avatar
Real Name: Jeff
LR usually run the cheapest and several people really like them. How much time do you spend on trails?
97 SR5 4runner: 2" OME Lift, rear E-Locker, 231mm Tundra Brakes, 203K, B&M 70264 Tranny Cooler, Duratracs
Build
JBurt is offline   Reply With QuoteReply With Quote
Old 05-04-2014, 08:37 AM #6
SL28's Avatar
SL28 SL28 is offline
SL28 is on a distinguished road
SL28's Avatar
When I build out my t4r (soon), the front end is going to include TC UCA's. The uniball construction is the way to go for lifted and extended travel. Total Chaos UCA's cost a bit more than others, but for good reason.
I had Light Racing UCAs on my Tacoma along with extended travel Icon COs.
The ball joints failed and did so WAY too early in my opinion. The idea behind the LR construction seems good, but I had bad luck with them holding up.
SL28 is offline   Reply With QuoteReply With Quote
Old 05-04-2014, 05:15 PM #7
Brilliant's Avatar
Brilliant Brilliant is offline
Brilliant is on a distinguished road
Brilliant's Avatar
Camburgs are superior to TC and cheaper.
Upper A-Arms: Camburg VS. Total Chaos - YotaTech Forums
LR/SPC if you want a ball joint in lieu of uniball
I have camburgs, because they were cheaper and more functional than any of the above.
ICON and some others have a sealed design, not sure about those. They are more money but not sure if its more function.
Brilliant is offline   Reply With QuoteReply With Quote
Old 05-04-2014, 05:29 PM #8
thebrandon's Avatar
thebrandon thebrandon is offline
thebrandon is on a distinguished road
thebrandon's Avatar
LR offers the most fixed adjustability (if that makes sense), but uses a ball joint. The way it is set up though you still get more down travel than the factory arms. Ball joints are also sealed vs open like the uniballs in TC and Camburg.
Camburg and Total Chaos are almost identical in design. If you don't believe me go find a store that has them both, or find vehicles with them. I've looked at them in person and couldn't tell a difference really besides color and I think the Camburg arms have a brake line bracket. Camburg is cheaper and uses a different company for uniballs I think. Either would be a good choice and both now have zerk fittings for the bushings. You really can't go wrong with either option.
Icon offers a sealed uniball, but is not worth the hefty price in my opinion. Other than the sealed uniball they are comparable to TC and Camburg.
I have the TC arms and have Tundra billies and springs on the third perch and I was able to get my truck aligned to spec with these arms. I don't have issues with the springs contacting the arms or spindle either. This has been reported with every aftermarket UCA though depending on the setup you have. I like TC arms a lot and would recommend them to anyone.
thebrandon is offline   Reply With QuoteReply With Quote
Old 05-05-2014, 12:25 AM #9
Thanks for the advice so far, I'm still giving it a lot of thought! I want to make the right choice!! I'm thinking I'll probably get the camburgs, but I'll wait for more responses.
Old 05-05-2014, 12:41 AM #10
I do a couple trails a year, such as browns camp, and tons of fire roads/forestry roads. Lots of camping, mountain biking, etc, so usually all of my outdoor activities end up far off the beaten path.
Old 05-06-2014, 12:48 AM #11
Ordered the camburg UCA's, can't wait to install them!
Old 09-22-2014, 10:15 PM #12
keralite keralite is offline
keralite is on a distinguished road
how did they work out
I've run into a similar problem with my UCAs and was wondering how your install went. Are you happy with your choice of UCAs?
keralite is offline   Reply With QuoteReply With Quote
Old 10-25-2014, 04:54 PM #13
St0neWhite's Avatar
St0neWhite St0neWhite is offline
St0neWhite is on a distinguished road
St0neWhite's Avatar
have you seen SPC UCA ?
How about these ?
SPC Performance Control Arm; Left & Right Pair TOYOTA 4RUNNER
Need new upper control arms!-547d47a1-eac1-403e-922f-14f870ddc939-420-jpg
St0neRunner Build: http://www.toyota-4runner.org/3rd-ge...0nerunner.html
Deck plate mod, high flow filter, pulstar plugs, 3" lift w toytec coil overs, diff drop, Highflow cat, mangan flow muffler, built in cargo box, air compressor, custom built bumper, modified roof rack, Remote control gobee lights, hood scoop led light, bluetooth, gps, cb, obdII reader, new leather seat with seat heaters installed. Many hrs of maintenance and suspension part replacement
St0neWhite is offline   Reply With QuoteReply With Quote
Old 02-11-2017, 01:17 AM #14
skiyota76's Avatar
skiyota76 skiyota76 is offline
Real Name: Kurt
skiyota76 is on a distinguished road
skiyota76's Avatar
Real Name: Kurt
Originally Posted by St0neWhite View Post
I need some info on lubricant for my TC they now make a rubbing sound and I can feel it inside with every flex.
Sent from my SM-G920V using Tapatalk
skiyota76 is offline   Reply With QuoteReply With Quote
Old 02-11-2017, 01:34 AM #15
JBurt's Avatar
Real Name: Jeff
JBurt's Avatar
Real Name: Jeff
Tri flow dry lubricant
Everytime it rains, gets washed, or otherwise wet.
Build
2002 , cambur , suspension , totalchaos , uca's
Spc upper control arms kammando808 3rd gen T4Rs 87 10-12-2023 06:49 PM
Which Upper Control Arms ? xcmountain80 3rd gen T4Rs 73 06-08-2015 08:12 PM
WTB: SPC Upper Control Arms 4th Gen knightsfs4 Want to Buy/Trade 1 11-07-2013 12:41 AM
Upper Control Arms Mick1 For Sale: T4R Items 0 06-01-2012 05:50 PM
Upper Control Arms digphisher 4th Gen T4Rs 2 10-20-2010 01:37 AM
