05-07-2014, 11:19 PM
3RD Gen electric fan install
How many have done a changeout of the factory fan to an electric fan? I found a couple of entries in the forum, where the owners had installed a Flex-A-Lite #675 fan in their T4R. I have done changeouts with other vehicles and gained some Miles per gallon gains, and I am wondering if the Toyota would have the same gains.
05-07-2014, 11:49 PM
I'm running electric fans.
Cant say if it improved mpg, but it definitely runs cooler/better. While trailing, it sounds like a jet once its turns on haha
97' SR5 - OEM Hood Scoop - E Locker - Toytec Coilovers/SuperFLEX - Bilstein 5100s - 2" BL - 285/75/16 Goodyear MTR Kevlars - 16" SCS SR8 - TG 68" Sliders - Custom Rear Bumper & Tire Carrier - Murano Projector Retros - (too much accessories) - BSB GARAGE "Blood, Sweat, and Beers"
Build Thread - http://www.toyota-4runner.org/3rd-ge...ld-thread.html
05-08-2014, 12:08 AM
I've thought about electric fans... I already have a HO alternator... Is there a prewired harness including AC circuit?
97 Limited 4x2 ---> 4x4 (SOLD)
SS 1.3 | ToyTec | RadFlo | Aussie | SOR | AOR | CBI | DC Power | Rigid | Alpine | Audison | JL Audio | Second Skin
2020 TRD Off Road Premium
King | BFG | Rago | AudioControl | AudioFrog | JL Audio | Dynamat
05-08-2014, 01:52 AM
The Flex-A-Lite 675 comes with a temperature control. This control will need a 12 volt source and it can be tapped into the A/C circuit for triggering the fans when the A/C is turned on. The temperature probe is designed to fit into the radiator fins (not my first choice, but they work).
The thing about this fan setup is that it bolts to the factory fan shroud bolt holes.
05-08-2014, 05:11 AM
What fans did you go with? Been thinking about it for a while but wasn't sure which one to get, plus I know for sure it would help out a lot pretty much because I live on the shitty hot side of the island
98 limited-3" body lift, toytec/eibach, toytec superflex, bilstein5100, spc uca, 285/75/16 nitto trail-grappler, 16x8 procomp 7031, 1.5" spider trax wheel spacer, elocker, b&m transmission cooler, Isr and deck plate mod, satoshi grill, 30" led bar, plasti dip front/rear bumpers and fender/cladding,
05-08-2014, 10:05 PM
WOW! $300-400 for an electric fan is a ton!
Isn't there a E-fan mod that people have done using like a '90s Taurus or something?
The Renewal of Gaia 1999 4Runner SR5 Highlander IJM
FJ Wheels | Goodyear Wrangler Fortitude HT | TBU
Rancho Shocks & Struts | OME 880 Front | OME 906 Rear | ES Polyurethane Sway Bar Bushings Front/Rear | ES Polyurethane Steering Rack Bushings
Clear Headlight Corners | '98 Rear License Plate Frame & Emblem Delete | Stubby Antenna | Trans Cooler Bypass
05-09-2014, 09:11 AM
I used a 95 Taurus fan in my 65 Mustang. I think it's a pretty common mod on Jeeps. It will suck in small children, but it pulls 40 amps on high speed. That's a LOT of current, and to be honest, I've never seen my temps rise over 205 no matter the weather or the wheeling. I just don't think these trucks need any more cooling. If they did, I'd be the first in line (with a much larger alternator too).
2002 T4R Limited, 191K miles - OME 883 front - LC 7 wrap/2nd gen sway bar links rear - Detroit Truetrac Diff - Cooper A/T3s - Warn M8000 - ARB Bumper - homemade (er, 'custom') rear bumper w/tire & can carrier - BajaRack - Diff Breather Mod - Hayden trans cooler - Yaesu 2M, Cobra CB - Fridge, off-road trailer with Tepui RTT (real expo poser)In Africa they say: "Buy a Land Rover and it will take you anywhere. Buy a Toyota and it will take you there ... and bring you back home." jannikt on wranglerforum.com - I'm guessing he didn't make many friends there with that line.
05-09-2014, 09:34 AM
official vendor
official vendor
You are correct. Using a Taurus fan is one of the best ways to go on Jeeps. I had one on my YJ and the entire set-up only ran me about $30. There are many universal kits that you can pick up on eBay for far less then $300-$400. The most important thing is to pick one up that comes with a sensor control. This will turn the fan on when the temp reaches a certain point, and back off when it's cooled down enough. Something like this fan kit is all you need. You just need to make sure to find one with the temp on/off settings to match what you need. These come with many different on/off temps. You could always pick up a junk yard fan and just buy a wiring kit to control the on/off as well. MPG increase is going to be so minimal that you'll most likely not even notice it.
05-09-2014, 10:40 AM
What temp difference did you notice using an electric fan. It's true an engine driven fan doesn't do much at low speeds, but and electric fan doesn't come close to the CFM of an engine driven fan overall. Usually an engine driven fan draws 3 times as much as an electric fan. A "good" electric draws 1800CFM, while engine driven fans draw 4000-6000CFM. So I'm always skeptical about people saying they run cooler with an electric.
1989 FJ62 5.3 Chevy, FZJ80 Axles, 4.88's with ARB.
2000 2wd runner, 4 cylinders, yes it IS slow.
1999 4WD SR5 Desert Dune 3.4 351K and counting.
2000 4WD sport 3.4 Elocker <--My son's but I still end up paying.
2001 2WD SR5 3.4 <-- My daughter's...see preceding line.
05-09-2014, 10:57 AM
The Taurus fan draws about 4000 CFM and cools very well. On my 65 Mustang (4.6L DOHC supercharged) I used a Griffin aluminum radiator. You could put your hand on the right side (input) and it was blowing hot air. Move it across and by the middle of the fan, it's blowing warm air, and by the left side it's blowing cool air. That fan REALLY works (with a tight shroud), but it pulls 40 amps on high speed (I think it's fed with 8 ga wire from the factory!), and is overkill for these 3.4 motors, even at low RPMs (which will cause battery drain since the alternator can't supply as much current to run the fan at low RPMs).
And since the stock fan is uses a thermal clutch, it doesn't use much power (if any) at highway speeds, so there's no real fuel economy advantage to an electric fan, and the extra cooling really isn't needed (in my experience). I'd spend the money on other toys.
05-09-2014, 07:41 PM
my older brother has the exact year 4runner as me so its easy to compare (nearly identical mileage and all). Neither of us are using a aftermarket temp gauge, however, looking at both our OEM needles shows the difference that mine is ALWAYS running at a lower temp.
thru my racing experiences, I know that you should NEVER trust a OEM temp gauge, but I believe in these circumstances it proves my point.
EDIT: I used to be a member on jeepforum dot com when I had a WJ. Just remembered a few guys reporting their temps going from ~240* down to the 215/220* range with the Taurus fan.
05-09-2014, 10:44 PM
So are you running the Taurus fan in your 3rd gen? I'm just getting info from you, I have NO intention of running an electric fan. Been there done that aint gonna do it again.
05-10-2014, 02:45 AM
Here's one members experience with that particular fan: Stay away from Flexalite 675 for 3rd Gens!
05-10-2014, 03:26 AM
I have other vehicles that I am running electric aftermarket fans on. Those vehicles have "Be Cool" dual 11" fan setups and those are tough fans. The fans are rated for 2850 SCFM, and they move that much air without much effort. I am glad that someone has experienced the Flex-A-Lite fans and provided a qualitative review, even though it was negative on them.
05-15-2014, 01:56 AM
Wish I could tell you which ones as the previous owner did them. Its duals with a dc electronic controller for all I know.
The Taurus fan was in my Jeep after I nearly overheated her going up to Mauna Kea summit (~13,000 ft.). Just never ran a scan gauge to get accurate readings on her (IMO too expensive just to have a digital reading).
