FSM sez for p1300-Igniter Circuit Malfunction
possible issues:
1) Ignition system
2) Open or short in IGF and IGT circuits from igniter to ECM (check connections)
3) Igniter
4) Ignition coil
5) ECM.
In that order of diagnosis-starts on pg 308. Lots to check-igniter sits under rt side of hood behind airfilter box. I suggest you follow the FSM procedures, you've already done #1&4, so move on to 2/3/5. Luck!
