Old 05-04-2015, 11:56 PM #16
lgc285 lgc285 is offline
lgc285 is on a distinguished road
Originally Posted by AZ4Running View Post
Loving my OME lift, did the soft shocks in the rear 881/890 springs with diff drop. Rides great in the street and takes off road dirving like a Cadi. Has good flex as well in the rear. I also installed the front trim packer. Im running 265/75R16 tires with no rubbing b issues even with the stock suspension. Mpg did not change either.
what are your center hub to fender measurements with that set up?
lgc285 is offline   Reply With QuoteReply With Quote
Old 05-08-2015, 07:45 AM #17
ridefast's Avatar
ridefast ridefast is offline
Real Name: Jesse
ridefast is on a distinguished road
ridefast's Avatar
Real Name: Jesse
Originally Posted by giovannie23 View Post
I have heard if you plan to wheel the 906 springs will become a lil loose at full droop with the rear 5100 shocks kuz there a lil to tall for a 2 inch lift and found the 4600 accommodate the 906 better
What about 5125s for the rears?
_____________________________________________
2016 Trail-P Dobinsons 302/325 DK Chromoly, 285 kO2, C4, RCI, BD Squad Sport, XD Phillips HID's, Tint, Husky liners, Crestone Rack
2020 Gx460
2000 Limited 4X4 - OME 881/890- B&M 70264
Overland Bound #10926
ridefast is offline   Reply With QuoteReply With Quote
Old 07-01-2015, 04:37 PM #18
atalarico's Avatar
atalarico atalarico is offline
atalarico will become famous soon enough
atalarico's Avatar
So, I'm resurrecting this thread because I'm really interested in how this set up is going now.
My mechanic just told me that my front Bilstein 5100s have developed a leak. I've only had them for maybe 3 years and never wheeled that hard at all. I've never been pumped about the quality of ride either, as it's felt harsh. These are actually the 5100s for the Tundra, which probably has more to do with that than the Eibach springs (see thread here). I'm open to that suggestion because I honestly don't know. I'm hoping they'll be warrantied with Bilstein's Lifetime Warranty.
Regardless, I'm thinking of replacing them with OME's and I want a softer ride. I noticed Slee has a new-ish lift kit that combines the 90004 OME strut with a 880 spring and it's a "low-lift: This 1.75" Suspension Kit delivers improved driveability and still be able to obtain proper alignment readings without any additional parts."
I still have the Bilstein 5125's in the rear with OME 890 springs. I get the same hop you describe, but I don't know if that's from still having the stock rear sway bar links installed. I keep forgetting that I need to just swap those for the simple duralast front links to get the full amount of travel out of my suspension, but it's so low on the priority list.
Thanks for the great thread, OP! It's really helped my research.
2004 Sport Edition V8. 3" OME lift. 5th Gen Brakes. 285/70 Duratracs. JBA UCAs. SCS Ray10s. DT Headers.
1997 4-Runner Limited w/ factory locker. Totaled in February 2018. Still miss it.
atalarico is offline   Reply With QuoteReply With Quote
Old 07-03-2015, 12:38 PM #19
andrewbares andrewbares is offline
andrewbares is on a distinguished road
Sounds like it's probably those Eibach springs causing your front suspension to feel harsh, like you're thinking. Because the Bilstein struts are usually a bit softer than the OME's according to most people, so I doubt it's the Bilstein's.
Regardless, I like my OME 880 spring / OME 90004 strut combo for the front. It's probably harsher than stock, but I like it. My only real complaint is washboard as in my original post. But if you get the Bilstein's for free with the warranty, I'd say you might as well use those with the OME 880 springs.
That's good to know about the rear hop... maybe it's just by design. Like I did say in my original post, when the vehicle is fully loaded, it no longer hops. So maybe it's just by design since the vehicle needs to be capable of carrying more weight.
2000 Toyota 4Runner SR5, Manual Transmission, OME 880/906 Lift, rear ARB air locker, 32" tires, stock 4.10 gear ratio
andrewbares is offline   Reply With QuoteReply With Quote
Old 07-14-2017, 01:36 AM #20
marcus clarkus's Avatar
marcus clarkus marcus clarkus is offline
marcus clarkus is on a distinguished road
Thanks for making this thread too, it's exactly the info/pics I needed. I just replaced my clutch so I'm finally caught up on maintenance and now I'm planning out my lift.
I replaced the rear shocks with Bilstein 5100s about a month ago after I broke a shock while offroading. There's a lot less bounce in the rear with new shocks but they still sag like crazy since the original coils are there. I'm going to go with 906 springs in the rear -- the instructions for the Bilstein 5100's said the shocks are optimized for 3rd gen 4runners with a 2" lift, so those springs should be perfect.
For the front shocks, I'll do another set of Bilstein 5100s. I've heard mixed things about Bilstein 5100s but it's hard to figure out which version people are talking about and with how much lift (lots of older comments are about the Tundra version, whereas I'm buying the 4Runner-specific version). I was thinking of doing OEM tall coils up front since I like how they are driver/passenger side specific, but after pricing it out I think I'll save myself $100+ and go with the OME 880s, like you did.
I'm a little confused about your recommendations for using trim packers. Do you think you should have used both front and rear trim packers on the driver's side since day 1? Or just rear?
Also, if you had used them since day 1, wouldn't your driver's side have sat higher for a least the 1st year/5000 miles?
1999 Toyota 4Runner SR5 V6 4x4 5spd - 317k miles as of Feb 2024
3D Printed SR5 Mudflaps
FS: 3D Printed Outlet Covers - Convert rear ashtray to 12V/USB outlets
marcus clarkus is offline   Reply With QuoteReply With Quote
Old 07-18-2017, 05:43 PM #21
DerKaiser DerKaiser is offline
DerKaiser is on a distinguished road
How much are you sagging? Do you have fender/hub measurements?
I'm looking at suspension options for my 99 with 235k mi. I'm sitting 20.5 driver side, 21 passenger side with bouncy Rancho shocks/struts and oem 99 coils. Maybe I can get away with 4600's and keep my coils?
I was thinking 4runner 5100's 880/906 combo but I don't want the reported harshness unloaded.
DerKaiser is offline   Reply With QuoteReply With Quote
Old 07-18-2017, 06:13 PM #22
I have 4600's on my 4Runner... (have for ~10 years). They are comfortable and work well with a stock setup.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 01-11-2018, 01:58 PM #23
Scramble's Avatar
Scramble Scramble is offline
Real Name: Scramble
Scramble has a spectacular aura about Scramble has a spectacular aura about
Scramble's Avatar
Real Name: Scramble
Thumbs up
Originally Posted by andrewbares View Post
When I bought my 2000 Toyota 4Runner, the shocks definitely needed replacing (160k miles, probably still original shocks!). So I decided to replace the springs while at it too. I wanted a small lift, <2". I thought about buying the Toyota '99 coils for a 1" lift, but OME was cheaper so might as well go close to 2"
Parts ordered:
  • OME 880 Front Springs
  • OME 906 Rear Springs
  • OME 90004 Front Shocks
  • OME 60028 Rear Shocks
  • OME 95PF5 Front Trim Packer (wasn't installed)
  • OME 80PF10 Rear Trim Packer (wasn't installed) (but 3 years hindsight says I should have put them in)
I did not get a diff drop or the stainless steel brake line. I got KYB strut mounts since might as well replace the strut mounts while in there.
Pics after install
I didn't get any good before pictures, so all I have is after. Here's the two side pictures...
(whoops hosting for these photos went down, I'll see if I can find them some time)
And a pic of the vehicle fully loaded with camping gear for 5 people and petrified wood...
Measurements
I measured the height from the ground to the edge of the black trim around the wheel wells. Truck was unloaded other than the stock hitch, spare tire, and just over half a tank of gas. Measurements taken about 100 miles after install. These pics and measurements are with the stock 265/70r16 tires (31", or precisely something like 30.6").
  • Front driver: 35 3/4"
  • Front passenger: 35 3/4"
  • Rear driver: 36 3/4"
  • Rear passenger: 36 1/2"
The driver side in the rear was actually a little HIGHER!
So I originally thought that my shop installed both the front and rear driver side trim packers, but apparently they didn't... I looked in the box with my old springs, and there were the trim packers in their original bag!
(Old info): Thus, my advice is: do NOT use the trim packers! The measurements above don't have the trim packers, and clearly the truck sits perfectly! With a full tank of gas, it seems like the driver side might be a bit lower (I quickly measured it again). That's as perfect as you can get.
After like 5,000 miles, the truck is still sitting wonderfully level. Trim packers definitely not needed.
CORRECTION 7/2017: Trim packers NEEDED! 3 years later, my driver side is lower. I started noticing it being lower after 1 or 2 years. I haven't tried putting them in yet though.
Comfort of ride
I was pleasantly surprised by the ride quality. I was afraid it'd be too rough after hearing some people talk about the suspension. It's probably not as soft as stock Toyota springs and shocks (never got to experience a good stock suspension), but it isn't unpleasant or awful either! And that's coming from someone who always drove cars before this, so I still am more used to things riding like a car than "riding like a truck".
The only harsh experience about the suspension is when going a bit faster over some speedbumps... it feels like the rear jumps up off the ground when hitting the speedbump! Maybe if I went even faster (I was only going about 10 mph tops) it would actually absorb the bump.
I was wondering how Bilstein's would feel instead of the OME Nitrocharger shocks. But I'm quite happy with the full OME package.
Off road ride
I still haven't had a chance to go off roading with the new suspension. I've hopped a few curbs just to see how it feels, and it feels much more solid and strong. I'll try to update this after I go wheeling!
Update: OFF ROADING!
I finally did some wheeling. There's definitely different types of off road, so I'll break it down by the type...
Washboard dirt roads
If you're on a dirt road with tons of washboard but otherwise no bumps, the OME setup is quite rough. It doesn't do well absorbing washboard. When I rode in my friend's stock Ford Explorer, I was like "Whoa, your vehicle actually absorbs washboard" haha.
Dirt roads with potholes, big bumps
As long as you go fast, the OME suspension loves absorbing big bumps/potholes. Go slow, and it won't absorb. I like to go faster on dirt roads (where it's safe and can see ahead for oncoming cars), so the setup works well. I love that you won't feel any extra rebound when going over big bumps, it controls the bump perfectly.
Rock crawling
The OME suspension feels perfectly controlled on slower low-range obstacles. It handles drops off rocks perfectly, feels sturdy, etc. Definite improvement over stock. The extra lift has definitely helped clear some obstacles. I scratch the hitch less, and feel less worried about scratching the underside.
19 posts since 2013 but you keep this thread updated, good job OP!
____________
'99 4Runner - 2.7L 3RZ, 5 Speed, 4.56 Gears - Lifted, Locked & Loaded - 166k Original owner - http://www.toyota-4runner.org/3rd-ge...ld-thread.html
'99 Limited - E-Locker- Stock (for now) - 233k 2nd Owner http://www.toyota-4runner.org/3rd-ge...ted-build.html
Scramble is offline   Reply With QuoteReply With Quote
Old 05-23-2021, 04:23 PM #24
wsteele8974 wsteele8974 is offline
wsteele8974 is on a distinguished road
I'm looking at the 880/906 bilstein 5100 package for my 2000 2wd. Your review helped in my decision making.
wsteele8974 is offline   Reply With QuoteReply With Quote
Old 05-23-2021, 09:15 PM #25
Itchynuts Itchynuts is offline
Itchynuts is on a distinguished road
Thanks for the review, I have been considering this setup
Itchynuts is offline   Reply With QuoteReply With Quote
Old 10-12-2021, 02:54 AM #26
OffroadTwin OffroadTwin is offline
Real Name: Alec
OffroadTwin is on a distinguished road
Real Name: Alec
Thanks for the review! I picked up a full OME used setup (880/906) with shocks (90004 and 60073 I believe) for only $100!! Installing it soon along with poly swaybar bushings F/R
2001 4runner Limited 4x4 226k
OffroadTwin is offline   Reply With QuoteReply With Quote
suspension
StrongArm 4286 Gas Charged Lift Supports review buish 3rd gen T4Rs 85 05-10-2022 11:06 AM
Ironman 4x4 Lift Install and Review Tinman1985 Classic T4Rs 5 01-21-2022 12:48 PM
Review of Hi-Lift X-TREME Jack Ol'Blue General Discussions 5 09-27-2013 11:59 PM
Lift installed - my review, pics, lessons learned... audiness 3rd gen T4Rs 28 05-28-2013 04:29 PM
Fourtreks Hi Lift Mount review (pics included) Black Majik Engines / Suspension / Wheels / Tires / Audio / Accessories 3 03-12-2008 04:57 PM
