05-25-2014, 11:55 PM
Turn signal doesn't work but clicks.
Left turn signal is fine. Right turn signal clicks, but the dash light and exterior lights stay off too. I changed the bulbs even though I thought they were good just to eliminate it. Anyone know what else could be broken here?
2001 4Runner SR5 RWD 130K Miles
05-26-2014, 12:27 AM
Fuses good?
1997 SR5 4WD 3RZ/5spd. Evergreen Pearl/Oak. Elocked. 4.56 Toyota Gearing. Full body resto/Custom 3 Stage "Tri-Coat" 751 paint job. 2.5" OME lift/w Bilstein Shocks. JAOS Spoiler. Duratracs. Custom Taco Rims. EBC Brakes. SS Braided lines. Marlin Crawler Trans & parts. Marlin HD clutch. URD short shift kit. 1st Gen Shift Knobs. MStudt's endlinks. JBA SS exhaust. LCE Headers. K&N. 140A CS144 alt. Big 3/4 wiring. Hella/PIAA Lighting. 2nd Gen Map Light Mod. Custom LED switchback DRL/Turnsignals. 32" Curved LED bar. Front Tint. A/D/S/ Stereo. SoundProofed. RangeRover seat swap. 99 Clears. A/C. PWR everthing. EastWood Frame coating. AMSOIL. Custom sleeping solution.
05-26-2014, 12:59 AM
Fuses are good too. Yes. Thanks.
05-26-2014, 01:04 AM
Also I just figured if I pull the switch back a touch, it seems to work. A bad switch maybe?
05-26-2014, 09:52 AM
If positioning the switch changes what it does, yes it has failed.
1989 FJ62 5.3 Chevy, FZJ80 Axles, 4.88's with ARB.
2000 2wd runner, 4 cylinders, yes it IS slow.
1999 4WD SR5 Desert Dune 3.4 351K and counting.
2000 4WD sport 3.4 Elocker <--My son's but I still end up paying.
2001 2WD SR5 3.4 <-- My daughter's...see preceding line.
05-26-2014, 11:08 AM
Agree. Does Hazard Switch work on that side on front and rear? If they do, a blinker failure on one side (front and rear) pretty much has to be the switch.
This is a 2002, but I'd guess 2001 is similar, if not identical:
My Backyard Frame Swap
05-26-2014, 11:14 AM
I've been having this exact problem on my 4runner for the last 6 months.
Where is this switch located?
05-26-2014, 11:22 AM
It's at the end of the stalk.
06-05-2014, 10:24 PM
Turn Signal switch purchase
I saw a couple that has fog light switches on ebay, would this work? I don't have fogs but I think it's prewired if it helps.
06-06-2014, 12:04 AM
PM'd
PM'd
06-26-2014, 12:26 PM
I finally from the local jyard! It works. Now the only problem is I don't know how to use a working signal switch properly. I still push it back a touch. Habits habits!
