Originally Posted by Neil_R
Pedal feel really shouldnt change at all on these trucks. I'd suggest removing the TB and giving it and the TPS/IACV a good cleaning. That should rule that out.
Is it throwing any codes?
Ill try removing the TB and cleaning it. There isn't a check engine light on, but unsure if its throwing a code. Now that I think about it, my z06 will throw codes and not kick on a SES light. I'll run by autozone and have them check for any codes.
Originally Posted by TheeMikeB
Sounds like fuel delivery issue. Def check the basics especially the MAF, TB, and air filter. I recently had a 'dead spot' in mine in 3rd around 2500RPM and wasn't throwing codes but turned out to be dirty MAF. Use the proper MAF cleaner and give it a shot.
Not sure about the pedal feel... maybe it just feels dead because it's not accelerating?
Fuel delivery is what I originally thought but since it doesn't happen more often/at varying rpm's, I initially ruled it out in my head. I don't have any injectors at the house, but I could throw some injector cleaner in my next tank of gas
As for the pedal feel, that's the "weirdest" part about this whole thing. When the rpm's dip/bounce like in the video, if I press on the pedal, it feels like there is a mattress behind the pedal (ie: it moves but is stiff). It's only after a few seconds that the car reacts and the easiest way to make the car react is to slow down and take my foot off the pedal
Thanks for the replies! Keep them coming!
