Old 06-02-2014, 07:33 PM #1
EricHartley EricHartley is offline
EricHartley is on a distinguished road
Can I drill into this part of the roof rack?
I'm wanting to mount a roof basket from a land cruiser onto the roof of my 4runner. Was going to drill through the 2 main cross beams of the oem roof rack and mount the basket with long nuts / bolts.
Yay or nay?
EricHartley is offline   Reply With QuoteReply With Quote
Old 06-02-2014, 07:38 PM #2
MyHigh's Avatar
MyHigh MyHigh is offline
Real Name: Tim
MyHigh is on a distinguished road
MyHigh's Avatar
Real Name: Tim
I don't see why not, I'd just make sure you drill into the center of the bar and not on the edges where it thins out.
What's your concern about it?, are you drilling to mount something?
Also, and I say this with experience of screwing things up. I would probably put a thin piece of wood under it, just incase while drilling, once you punch through the rail it doesn't continue on to the roof of the rig.
MyHigh is offline   Reply With QuoteReply With Quote
Old 06-02-2014, 07:45 PM #3
TCMach's Avatar
TCMach TCMach is offline
Real Name: Tyler
TCMach will become famous soon enough
TCMach's Avatar
Real Name: Tyler
Yep. Just do what @MyHigh said. Keep it centered, go slow, dont drill your roof. That basket will be mounted in no time
My build:TCMachs build
2000 4Runner:Kings, 37s, lockers
2018 TRD OR:stock and staying that way
TCMach is offline   Reply With QuoteReply With Quote
Old 06-02-2014, 07:48 PM #4
rideexileex's Avatar
rideexileex rideexileex is offline
rideexileex will become famous soon enough
I might also recommend the yakima quick clips I think they're called... adapters without having to drill.
2000 4Runner Sport - TRD&AEM SuperCharged
Solo Long Travel & KING 2.5 & bumps, 4th gen rear axle & KING 2.5 12's
F+R ARB's, 4.88 Yukon's, 295 KM3s
rideexileex is offline   Reply With QuoteReply With Quote
Old 06-02-2014, 08:18 PM #5
Thank you for the info guys!
This is the basket I plan to mount.
As you can see there is checker plate for the "bed" of the basket, and I plan to drill through it, and through the roof racks
Old 06-02-2014, 08:34 PM #6
MONTYMTB's Avatar
MONTYMTB MONTYMTB is offline
Real Name: Monty
MONTYMTB is on a distinguished road
MONTYMTB's Avatar
Real Name: Monty
How much does that thing weigh (including stuff that you plan to put in it)? I think the OEM cross bars have a stated weight limit, but I can't remember how much it is.
EDIT: just went out and looked, and it says "165 lbs, evenly distributed"
MONTYMTB is offline   Reply With QuoteReply With Quote
Old 06-02-2014, 08:43 PM #7
ARC ARC is offline
Real Name: Andrew
ARC is on a distinguished road
ARC ARC is offline
Real Name: Andrew
I would remove the factory crossbars and attach the new basket directly to the tracks for two reasons:
1) The bars are weak.
2) Mounting to the bars is going to make the basket even higher.
-More aerodynamic issues
-Needlessly raises COG slightly
-Creates more clearance issues (garages, low branches, drive throughs, etc.)
97 FZJ80 40th Anniversary Edition wife-mobile/weekend wheeler
SOLD'98 T4R 5spd, e-locker, Boss coilovers, LC 8wraps, Tokico blacks, SS extended bump stops, 255/85r16 Toyo M/T's
http://www.toyota-4runner.org/3rd-ge...ml#post1707857
ARC is offline   Reply With QuoteReply With Quote
Old 06-02-2014, 09:08 PM #8
txbonds's Avatar
txbonds txbonds is offline
txbonds is on a distinguished road
txbonds's Avatar
I agree. Lose the cross bars and mount directly to the tracks. You should be able to come up with a bolt setup using a washer that will slide into the tracks. You can space a few in each track to reach up through the new rack and attach a washer and lock nut.
17 Jayco Precept 35UP Motorhome - 18 Jeep Wrangler JLU - current
16 4Runner TEP KDSS - 15 4Runner Trail KDSS 4x4 - 06 4Runner V8 4x4 - ALL SOLD
97 4Runner Ltd. 4x4 - SOLD - http://www.toyota-4runner.org/3rd-ge...d-project.html
txbonds is offline   Reply With QuoteReply With Quote
Old 06-02-2014, 09:26 PM #9
ARC ARC is offline
Real Name: Andrew
ARC ARC is offline
Real Name: Andrew
Just use the factory nuts that come in the track. Should be 5 per side giving you a rock solid mount. I used 3 points per side to mount my RTT and am very happy. Just go to the hardware store and get the proper length bolts that match the factory thread pattern.
Old 06-02-2014, 09:41 PM #10
habanero's Avatar
habanero habanero is offline
Real Name: Throws like a girl
habanero is a glorious beacon of light habanero is a glorious beacon of light habanero is a glorious beacon of light habanero is a glorious beacon of light habanero is a glorious beacon of light
habanero's Avatar
Yes, you can, the rubber's the more annoying part:
I wasn't worried about doing that to the load bar that holds the lights, but I don't think I'd want to compromise what strength they have drilling holes and then mounting a rack to it.
The husbandio did the uni-strut route on the 99 and it came out nice and also lower than it would have if he'd mounted the rack to the factory crossbars- and seems more sturdy too. The rack's low but not in danger of touching the roof:
It's a lot like ARC's but with a 'spacer' in the form of the unistrut.
'96 4Runner SR5, assorted baubles and doodads. Stuff happened to it. Stuff is still happening to it. Okay, now the stuff is just getting ridiculous.
'99 4Runner SR5 Highlander, manual w/locker. Stuff is starting to happen to this one too...too much stuff! Too much stuff!!
http://www.yotatech.com/f200/habaner...thread-201751/
Originally Posted by PWD4R View Post
I know this is a weird ass question but do you shave your legs or something?
habanero is offline   Reply With QuoteReply With Quote
Old 06-03-2014, 12:28 AM #11
thanks guys! il most likely use the factory rails that run the length of the vehicle. il also checkout those Yakima quick clips
like TCMach said, this rack will be mounted in no time. now its just a matter of getting it home
Help - Roof rack cross bars / part question MTT77 5th gen T4Rs 8 12-10-2018 12:00 PM
WTB: 3rd gen roof rack part ugamurph Want to Buy/Trade 4 05-07-2014 07:45 PM
Part Number Help? SE Tube Roof Rack Graphite Greydog 4th Gen T4Rs 1 03-02-2013 08:06 PM
Roof Rack Part Number Help steve73 5th gen T4Rs 8 08-19-2012 08:16 PM
Roof Rack Delete Part Numbers Joaco10SR5 5th gen T4Rs 7 12-14-2010 07:49 PM
