Originally Posted by Deathorglory
So I got a 01 SR5 auto, it seems to not have a switch for the traction control.. It's pissing me off cause I wanna chuck rocks haha.. Is this not a stick option ? If not is there a way to bypass it and throw a switch in ?
All hail the t4r gods ! Thanks
Your lucky im a bit drunk... I won't do what I normally do and give you a link to "let me google that for you" its called the Andy mod i believe. It's very easy to do and turns traction, vsc and abs off. To turn it all back in flip the switch back to normal and turn the car off then back on... Before i discovered this i used to abuse my transfer case by putting it in neutral and taking the 4wd selector and going 4low N 4hi and back and forth until it finally poped up saying it got confused and gave up.
