Originally Posted by kong
Guys,
I am trying to replace the starter contacts...but to be quite honest, I'm not very mechanically savvy. As a result, I'm leaning heavily on this:
(Another) Starter Contacts Removal Thread!
and
Is your starter going??? Quick and easy repair!!!
Questions:
1) Can I use these guides for a 5 spd 1998 2.7?
2) Do I have to remove the front right tire and put the car on a jack stand?
3) Where is the "brake line?" in step 3 of the first link?
Thanks guys!
I have never pulled a starter out of a 3rz but I'd imagine it a lot simpler.
Crawl under your runner remove your skid plate and look. I could pull starters all day on my old 22re in my first gen runner. Tried removing the starter in a 3.0 runner once almost lost my hand slicing it on a exposed bolt.
But to answer your questions.
1.I don't know for sure.
2.don't know if you need to remove the tire but "if" you do please do us all a favor and use a jack stand and as added security place the wheel under the truck just in case of jackstand failure.
3. Follow the lines from the caliper.
Edit: here you go good write up
http://www.tacomaworld.com/forum/1st...fe-engine.html
