06-16-2014, 12:53 PM
Shouldn't have cleaned my engine
OK so yesterday I decide to do a little engine cleaning. I have done this before and have never had a problem, I use a degreaser, a scrub brush, and a garden hose. Started my truck up today and the engine is puttering at idle, it's shaking the car a bit. The check engine and vsc off and Trac off lights also came on. Any ideas?
02 SR5 Limited, Toytec Ultimate 3.5'' Lift Kit, 1'' Toytec Body Lift, Total Chaos UCAs, Nitto Trail Grapplers 285/75/R17, Five Star Rims, Full Savage Offroad Skid Plates, Savage Offroad Sliders, ARB Front Bumper
06-16-2014, 01:10 PM
Banned
Banned
i'm not a mechanic but I play one on TV
did you blast rinse it or gently rinse it? access to an air compressor?
06-16-2014, 01:14 PM
Did you cover the electronics? (alternator, fuses, battery terminals, etc.?).
I would start by opening the hood and let it sit in the sun for the day, but I'm sure others will add to the recommendations.
Good luck.
2000 Highlander - 3" OME 883F 890R - ARB F&R Lockers - AOR Bumper - Savage Armor - WARN M8000 - RIGID LED Floods - TRD Wheels - TBU - HID - BFG KM2
06-16-2014, 01:18 PM
I used a little bit of pressure in the extremely dirty areas, but nothing that should have damaged it, and yes I have an air compressor
06-16-2014, 01:27 PM
you most likely have gotten water inside the spark plug wells and that water is causing a short (misfire)
so go ahead and pull all 6 or 4 of your spark plug wires and check inside the well to see if there is any water in there.
thats my bet what happened. pretty simple.
Never ask a girl if shes sick, she might not be wearing any make up. - lets just say she went storming off.
Never tell your wife she looks tired, they tend to hit and say that means she looks ugly. (weird logic i know)
06-16-2014, 01:33 PM
Banned
Banned
I agree with GVL. Open the hood. Open anything you can, like fuse box lids. Pull plug boots. Possibly water infiltrated an electric connector. Can you unplug the various connectors to look for water and let them air dry? Pay specifcic attention to those areas you scrubbed extra hard or rinsed at higher pressure.
Re compressed air, I'm now thinking it might force water deeper into wherever it has infiltrated, depending upon the velocity. I don't know.
06-16-2014, 01:48 PM
Real Name: Asa
Real Name: Asa
Did the same this a few weeks ago. I had shorted out a coil and it was misfiring. Get a obdII scanner so you can find out which cylinder is having the misfire on
96 SR5, Ghetto ISR mod, SCS Stealth 6s, 35x12.5 Toyo MTs, Bilstein 5100s/Eibach coils, B&M Transmission cooler, 1.5 Inch Fat Pat body lift, OME 851s, TJM XGS Gold series LC shocks, Satoshi grill, Rear diff breather, 167 series snorkel, Toytec rear brake line, All Pro apex Front bumper with custom hoops, Custom rear bumper with Ghetto swing out, First Gen roll bar,LED parking lights/turn signals, Hybrid model
06-16-2014, 02:59 PM
So what did you do? Just open the hood and let it dry out? I have a feeling it's either the coils or the sparks
06-16-2014, 03:04 PM
Had SAME problem about two months ago. I ended up getting water around my #6 plug. I popped off my wire and blew out from around the plug with an air compressor. A couple minutes later she was good to go. Maybe that will help out!
06-16-2014, 03:57 PM
I have never heard of this... I pressure wash my engine bay all the time and have never had an issue. I don't blast the spark plug areas or the engine block at all, but I do rinse it....
06-16-2014, 04:10 PM
just pulled off the spark plug cable on the drivers side, water was sitting at the bottom. Blew it out and I'm letting it air dry for a few. hopefully it was the only cylinder that had water at the bottom of the plug. you were right
@ Jlott9311
06-16-2014, 04:15 PM
@ Jlott9311
did my correct comment just go unnoticed?
06-16-2014, 04:42 PM
My bad
@ shootmymime
I didn't read all the comments after seeing first post. Didn't try to steal your glory haha!
Don't worry mime.i noticed. Actually thought to my self "what a great comment" lol
06-16-2014, 05:35 PM
my bad for forgetting to mention you in the last post, you hit the nail on the head on this one!!! So I did what you said and took out all the plug wires, only had water in one of them. I still let all of them air out for an hour and a half and also blew em out a bit with a compressor. I put them all back in when i saw no more water in the one well that had the water in it. turned the car on and it was still misfiring. Went back pulled the plug back out and moisture was back in it. do i need to pull the spark plug itself out as well?
