07-01-2014, 02:52 PM
Return Fuel Line Design Flaw
Just picked up my first 4runner, 1998 SR5, Basically all stock. Just taking it easy in the forest, a branch got jammed up into the fuel lines above the crossmember and pulled off the return line (I'm assuming since its just a low pressure hose with a cheesy clamp) off, creating a really cool stream of fuel dumping right into the ground. Gonna Fab up a aluminum plate for a guard and bolt it to the cross-member bolts, left side.
Anyone else have issues with this? Coming from having two Rubicons, I was a little disappointed in the venerability of these lines.
07-01-2014, 02:54 PM
Real Name: Andrew
Real Name: Andrew
Should have kept the Jeep. Toyota's are junk. Unreliable and don't hold up well.
97 FZJ80 40th Anniversary Edition wife-mobile/weekend wheeler
SOLD'98 T4R 5spd, e-locker, Boss coilovers, LC 8wraps, Tokico blacks, SS extended bump stops, 255/85r16 Toyo M/T's
http://www.toyota-4runner.org/3rd-ge...ml#post1707857
07-01-2014, 03:01 PM
official vendor
official vendor
Stop waving at other Toyota's and pay attention to the trail. Remember, it's only a Jeep thing not a Toyota thing.
Plus you most likely would have ripped off the entire gas tank on your Rubi! Selling my old YJ and switching to a 4runner was the best thing I ever did.
07-01-2014, 03:29 PM
Asses aside, ive yet to have trouble with said problem, (slap on water?) But you fixed the problem by fabbing up your own shield so cudos to you! Keep an eye out mate, good luck.
Cheers
1997 radiant red 4x4 5spd 3rz, e-lock. 406000km (250000 miles).
Home made roof rack and side ladder. 2-50" Cree light bars, 60" High-lift jack, 5' shovel, handheld gps with separate tracking device, gazillion different tools, dual mounted batteries with cs144 upgrade and the "big 3" ,2 fire extinguishers, MAPP gas. All rolling on 285-75-16" kenda Kevlar mt's
07-02-2014, 05:08 PM
well there weren't any other Toyota's around. Just a really random thing to happen. And the Jeeps were bullet proof, years of hard core wheeling, then drive to work 300 miles away with no issues. Just have to drive smart. I just wanted the interior space and Toyota's are great vehicles. Always wanted a 4Runner, so pretty happy with the vehicle so far.
07-02-2014, 05:11 PM
Never had a problem with what you've mentioned SGT. But I have loved my 4Runner much more so then any Jeep I've owned in the past.
If you fab up something post pics as I would love to see sir!
1994 6766 Supra SOLD
2001 SR5 Sport 4WD, AR JR intake, Tundra 5100s, TRD springs, 890s, LC shocks
2005 GX470
2008 USB ISF
ARMY AVIATION
07-02-2014, 05:16 PM
Will do
07-03-2014, 10:57 PM
Wanted to mention, I was on my private property. No trails. Therefore branches kinda run wild...
Here's what I came up with for the first proto-type. If I had more material here it would be better.
This is more of a deflector than an ultimate-guard...
Lemme know what you all think
"Uncommon Valor Was A Common Virtue" (a tribute by Admiral Chester Nimitz to the fighting men on Iwo Jima)
"All Gave Some, Some Gave All". Dedicated to the men and women who have made the ultimate sacrifice for our freedom and our country.
Semper Fidelis Sgt. Russ, USMC '97-'06
07-04-2014, 12:39 PM
You're entirely right.
"Today you, tomorrow me."
07-04-2014, 01:06 PM
Nice job!
2000 SR5 3.4L 4WD
Aux-12v "always on" mod, DRL mod, 2 Tranny coolers
Rear Differential "extended" Breather mod,
ScanGuage II, 231mm Tundra Brake upgrade,
ABS mod
07-05-2014, 01:14 AM
Banned
Banned
actually, there is supposed to be a plastic shield there. prob find replacement at junkyard for couple of $.
07-05-2014, 01:58 PM
I was just about to say the same thing! Yes definitely a plastic cover there, mine rode around in the backseat for a month while I was spraying Kroil on something repeatedly... but, I think mine was brittle and I broke off part of the outer perimeter when reinstalling, so I would definitely be interested in a fabbed metal option! (Unless the Savage or BudBuilt kits cover this, do they?)
07-05-2014, 05:07 PM
Moderator
Real Name: James
Moderator
Real Name: James
My truck was 2WD before, didn't have one.
My donor 4x4 2000 SR5 also didn't have one.
Girlfriends 2WD 99 Limited doesn't have one.
Where the hell did they go? lol I never had an issue but now I'm curious
IG: @jimharb | YouTube
'99 4Runner - 2.7L 3RZ-FE - TRD S/C - 4WD Conversion + R150F 5-Speed Swap - Imperial Jade Mica on Oak
'87 4Runner Turbo - 2.4L 22R-TE - CT-26 Supra Turbo - W56 5-Speed Swap - Red on Red
'90 4Runner 2-Door - 3.0L 3VZ-E - Auto to R150F 5-Speed Swap - Red on Gray
'94 Supra Turbo Targa - 3.0L 2JZ-GTE - Marlin Crawler R154 - Imperial Jade Mica on Black
'89 Supra Turbo Targa - 3.0L 7M-GTE - Marlin Crawler R154 - White Package on Blue
'89 Pickup DLX 2WD - 2.4L 22R-E - W55 5-Speed - White on Blue
07-05-2014, 05:23 PM
I took that plastic piece off because it hung down too far. I think aftermarket belly skids cover to the second cross member where they mount so they would cover the lines adding another solution.
1999 4Runner SR5 4x4 Desert Dune
Lift- 3" Toytec/Bilstein-front, LC Coils/LC Tokico Blacks-rear
285 Maxxis Bighorns on 16" ATX Mojaves
ARB-front, CBI plate w swingout-rear
1997 LX450 Black OME 2.5" 315 ST Maxx 2016 4Runner 4x4
