Old 07-06-2014, 04:35 PM #1
uncleslam23 uncleslam23 is offline
uncleslam23 is on a distinguished road
Does my wheel bearing need to be replaced? (video)
Posted on here a few days ago about my situation. Replaced my LBJ's about a month ago and shortly after I started hearing a strange girding noise, that has slowly become more intense. Took it to a shop and the mechanic took it for a spin around the block, and said it was most likely a wheel bearing going bad. So before I go buy a new bearing, I wanted to see what you guys thought. Here's a video, does it sound like it needs to be replaced?Faulty wheel bearing? - YouTube
Also, heres a video before I took the caliper off. Is it normal to have that much rubbing? IMG 2749 - YouTube
As always, thanks for your help!
uncleslam23 is offline   Reply With QuoteReply With Quote
Old 07-06-2014, 06:13 PM #2
Vannnce's Avatar
Vannnce Vannnce is offline
Vannnce is on a distinguished road
Vannnce's Avatar
Definitely sounds to me that the dust shield is rubbing the rotor... I did ball joints in mine ol lady's awhile back, got it all together and had this, took the rotor back off and pounded it out until the rotor no longer touched.
Hers: '01 4runner SR5 bone stock, jet ski hauler
Mine: '89 bronco, and '02 f350. Both with some goods
Vannnce is offline   Reply With QuoteReply With Quote
Old 07-06-2014, 10:03 PM #3
Izlu's Avatar
Izlu Izlu is offline
Izlu is on a distinguished road
Izlu's Avatar
Second that, pound that dust shield out. To check your wheel bearing jack the truck grab tire at 12 and 6 clock positions and try to move it. If there's some play it's wheel bearing then
Izlu is offline   Reply With QuoteReply With Quote
Old 07-06-2014, 10:33 PM #4
Thanks for the tips guys. There wasn't any play when I rocked the tire. But, my dust shield doesn't appear to be touching anything. If the dust shield were bent and touching something, wouldn't the grinding noise be non stop? I only hear it like once every rotation, if that makes sense
Old 07-06-2014, 11:01 PM #5
98OzarksRunner's Avatar
98OzarksRunner 98OzarksRunner is offline
98OzarksRunner is on a distinguished road
I got a rock wedged between the rotor and dust shield on the trail and it sounded like that.
2002 T4R Limited, 191K miles - OME 883 front - LC 7 wrap/2nd gen sway bar links rear - Detroit Truetrac Diff - Cooper A/T3s - Warn M8000 - ARB Bumper - homemade (er, 'custom') rear bumper w/tire & can carrier - BajaRack - Diff Breather Mod - Hayden trans cooler - Yaesu 2M, Cobra CB - Fridge, off-road trailer with Tepui RTT (real expo poser)
In Africa they say: "Buy a Land Rover and it will take you anywhere. Buy a Toyota and it will take you there ... and bring you back home." jannikt on wranglerforum.com - I'm guessing he didn't make many friends there with that line.
98OzarksRunner is offline   Reply With QuoteReply With Quote
Old 07-06-2014, 11:19 PM #6
Jasonredwood's Avatar
Jasonredwood Jasonredwood is offline
Jasonredwood is on a distinguished road
My dust shields would sometimes only touch when turning. You can literally grab them and pull them towards the center of the truck.
Jason
1985 fj60
2006 4runner v8 4x4 sport
http://www.jasonredwoodart.com
Jasonredwood is offline   Reply With QuoteReply With Quote
Old 07-07-2014, 10:58 AM #7
afg10000's Avatar
afg10000 afg10000 is offline
afg10000 is on a distinguished road
afg10000's Avatar
Are all the pistons in the calipers functioning correctly. Those look like stock calipers. Might have one of them stuck a bit not allowing the pads to fully release from the rotor. I agree with everyone else on the dust shield.
'96 Limited - Locker - 127k- totaled out -
'01 Limited 175k - sunken and resurrected - stock, other than TBU 231mm
'98 Limited - Locker -158k-Bilstein 5100 Tacos- Toytec/Eibach 3" lift coils- diff drop-265/75/16 Duratracs -OME 890's-Bilstein 5125's, panhard bar drop, TBU 231mm, Spidertrax 1.25' spacers, Savage sliders, 2nd gen SC/URD 7th, JBA exhaust, HID retrofits -
afg10000 is offline   Reply With QuoteReply With Quote
Old 07-30-2014, 09:07 AM #8
mschein1 mschein1 is offline
mschein1 is on a distinguished road
Love the search functions on this site!! So it is the dust shield? Mine is doing the exact same. I took the brake pads out, first the outside one. It still made the noise, then I took the inside out. No more noise. I was sure it was the rotor and the brake pads. So I sprayed a ton of brake cleaner on there. I will go pound out the dust shields now. Can you do this with the rotor and wheel on?
mschein1 is offline   Reply With QuoteReply With Quote
Old 07-30-2014, 09:26 AM #9
tre9er's Avatar
tre9er tre9er is offline
Real Name: Tre
tre9er is on a distinguished road
tre9er's Avatar
Real Name: Tre
I know that @Millerad1651 didn't believe it was his dust shield, but that's because he couldn't duplicate the noise when he jacked it up to inspect, but it WAS the dust shield.
'02 Brilliant Silver SR5 4WD Auto - 13WL TBU, Trans Cooler, Trac Off Andymod 2.0, pre-99 front bumper, more to come
Totally teh kewlest build thred
tre9er is offline   Reply With QuoteReply With Quote
Old 07-30-2014, 10:17 AM #10
well I was able to pry it away just a little bit. But I am at work right now. I will take the wheel off later tonight and see if I am good to go.
Old 07-30-2014, 11:38 AM #11
wc11's Avatar
wc11 wc11 is offline
wc11 will become famous soon enough
wc11's Avatar
Had my passenger rear done .
This is what mine sounded like.
https://www.youtube.com/watch?v=Qc3tnFbCK48
wc11 is offline   Reply With QuoteReply With Quote
Old 08-01-2014, 09:19 AM #12
Well back to update you folks. It is not my dust shield. It is my brake pad scraping against the rotor. Do you recommend trying new brake pads? Or resurface the rotor? Sometimes you hear it loud and clear other times not so much.
Sorry to hijack OP's thread.
Old 08-01-2014, 09:28 AM #13
Brian757's Avatar
Brian757 Brian757 is offline
Brian757 is on a distinguished road
Brian757's Avatar
I had this exact issue and a few shops said it was my wheel bearing. I brought it to a 3rd shop and they noticed on the inside of the 13WL caliper, that a little of the dust shield was contacting the rotor.
I brought it home, yanked it all apart and dremeled that piece out. Never a sound since.
It sounded exactly like the OPs video.
2002 "Stormtrooper" 4Runner
Tacoma Bilstein 5100s | Eibach/Toytec Springs (Front) | FJ Springs (Rear) | Tundra 13WL Brake Swap | Much More...
Brian757 is offline   Reply With QuoteReply With Quote
Old 08-01-2014, 12:15 PM #14
tre9er's Avatar
Real Name: Tre
tre9er's Avatar
Real Name: Tre
Weird, because the springs should be holding the pad off the rotor. Perhaps you have them installed wrong?
Also, how did you verify it wasn't the shield? You can try lining the shield edges with something, white-out or something, sharpie, then see after a drive around town/hwy if any of it is worn off. Pretty sure @Millerad1651 was convinced it was his pads, too. It was the shield.
Old 08-01-2014, 02:52 PM #15
Well I beat the hell out of that shield. That is sort of my verification. Also when I take both brake pads out, the noise stops.
So I guess I have not actual verification. I pryed on that shield and even coated in brake cleaner, it still made the noise.
Wheel bearing replaced 3 times in less than a year??? fuel-n-fire 4th Gen T4Rs 11 04-22-2014 11:03 PM
Unknown Creak from front right wheel, not ball joints, wheel bearing?? ryanbigcheese Classic T4Rs 2 02-23-2014 12:47 PM
Wheel Bearing jmm3807 4th Gen T4Rs 15 09-09-2013 07:10 PM
Bearing and Axle replaced - what is the cost? danancltnc 3rd gen T4Rs 1 04-25-2011 05:25 PM
wheel bearing replaced-now constant scraping sound over 7mph up to 25 mph Headly 3rd gen T4Rs 3 06-11-2010 08:03 PM
