Old 01-09-2020, 04:24 AM #1
Yoter's Avatar
Yoter Yoter is offline
Yoter will become famous soon enough
Yoter's Avatar
Gasket Advice Needed for Early 7-Piece TRD Headers
I picked up a used set of the early 7 piece TRD headers. While I am super stoked to get them mounted on my 4runner, I don't have any idea where to buy the gaskets. I need not only the gaskets that go against the heads, but also all the gaskets that sit between the 7-sections of the headers!
Are these parts even available?
I have seen this set from SCE but it seems to be for the newer TRD header design, which has fewer sections.
Also any advice on surviving the famously difficult install is greatly appreciated.
Thanks!
Gasket Advice Needed for Early 7-Piece TRD Headers-image-jpg
2000 "The Silver Legacy 2" Highlander Edition, 5speed 4x4
2000 "The Silver Legacy" Highlander Edition, 5speed 4x4 RIP
1996 Stellar Blue 5 Speed Sold
Yoter is offline   Reply With QuoteReply With Quote
Old 01-09-2020, 01:56 PM #2
raKnizek's Avatar
raKnizek raKnizek is offline
Real Name: Alex
raKnizek will become famous soon enough
raKnizek's Avatar
Real Name: Alex
I purchased my truck with these headers already installed. Thankfully I have not had gasket issues at the heads themselves so I have not messed with them or looked for the parts. You may need to get some blank gasket sheet material and make your own.
You will notice where the down pipe is connected to the cat that there are no spring bolts. its just a solid connection (fixed on later designs). Mine has always had a pinhole leak here so I searched for gaskets but was unsuccessful. When you get these installed you may want to put a flex pipe in somewhere so you dont get a crack later on.
2000 SR5 3.4, Manual, 4x4
Icon 2.5 extended coilovers & 2.0 rear, JBA UCAs
265/75R16 General Grabber X3 on LC80s
Full Skid Plates
raKnizek is offline   Reply With QuoteReply With Quote
Old 01-09-2020, 02:28 PM #3
VernySanders's Avatar
VernySanders VernySanders is offline
Real Name: Werner
VernySanders will become famous soon enough VernySanders will become famous soon enough
Real Name: Werner
Thanks!
Personally I would just use a high temp silicone RTV/ FIPG. I used it for my high flow cat and both my o2 sensors and that was a year ago and I've had zero issues with exhaust leaks. RTV is the way to go.
VernySanders is offline   Reply With QuoteReply With Quote
Old 01-09-2020, 03:03 PM #4
WeakSauz WeakSauz is offline
WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about
Wow, those look like they'd be fun to install! Not! haha
You will probably have to make your own gaskets from blanks
2000 SR5 4x4 | Geared, Locked and Fully restored OEM+ build.
Forged and Cammed 1UZ Single Turbo, Standalone ECU + Built R150 in process. Why, you ask? Because it makes no sense in this platform, and I love it!
WeakSauz is offline   Reply With QuoteReply With Quote
Old 01-09-2020, 03:11 PM #5
JAXJeremy's Avatar
JAXJeremy JAXJeremy is offline
Real Name: Jeremy
JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about
JAXJeremy's Avatar
Real Name: Jeremy
permatex ultracopper and then make some of your own gaskets with a quality gasket material..
'18 SR5 4WD, magnetic gray metallic, stock, RCI front skid, LFD cross bars, Pedal Commander, Accessorides Remote Start.
JAXJeremy is offline   Reply With QuoteReply With Quote
Old 01-09-2020, 03:14 PM #6
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
Wow. Was this a move to make it easier to install?
Old 01-09-2020, 03:16 PM #7
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire has a spectacular aura about UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
Since they're not installed it'll probably be easiest to buy gasket material and cut your own gaskets instead of trying to hunt down defuncted TRD parts.
Sent from my JSN-L23 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is offline   Reply With QuoteReply With Quote
Old 01-09-2020, 05:58 PM #8
Yoter's Avatar
Yoter's Avatar
Thank you, these were previously cracked at the Y part of the down pipe, the repair is shitty and I am having it welded up again more cleanly. I like your idea of putting a flex pipe in there to prevent issues down the road!
Old 01-09-2020, 06:15 PM #9
Yoter's Avatar
Yoter's Avatar
After the third bottle of Sake, it probably seemed like a great idea
Yeah seems like this is a route I will have to go!
Thanks I will give that a try! Just to make sure I understand I would cut gasket material to fit and then coat them and the mating surfaces in the permatex?
I will use the force
Thank you! Looks like I will have to make my own gaskets!
I am kinda worried these may end up being a leaky mess, I hope the gasket making is straight forward and reliable!
Old 01-09-2020, 06:39 PM #10
SaulG's Avatar
SaulG SaulG is offline
SaulG will become famous soon enough
SaulG's Avatar
Mr. Gasket 77, Mr Gasket 5960~5691 Ultra should come in a sheet
JBA063-2032 for heads & good sharp shears
SaulG is offline   Reply With QuoteReply With Quote
Old 01-10-2020, 01:46 PM #11
Real Name: Werner
Real Name: Werner
Well you must do it correctly. A lot of guys apply RTV and then torque their bolts down to spec but in all reality you want to apply your RTV and let it cure for however many hours and minutes the instructions state on the back and then once you've waited you tighten your bolts to spec. The reasoning behind this is you end up with an actual gasket and not just a bunch of extra silicone around the sides. If you apply it this way you wont have an issue. For added security if you're extremely paranoid it will leak then so what others have suggested and apply a layer of RTV to an actual gasket material of your choice. On exhaust this is the route I take.
Old 01-11-2020, 12:19 AM #12
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
Remflex wrongly titled the link but actual product says they're for TRD headers TOYOTA "3B" DIESEL Header/Exhaust Manifold Gasket
Old 05-13-2022, 09:21 PM #13
layifioren's Avatar
layifioren layifioren is offline
layifioren is on a distinguished road
layifioren's Avatar
Thanks!
Curious, did you ever get the gaskets? If so, where? Also, does your exhaust pipe flange have two or three bolt holes? I'm looking to buy a set with two holes but my 00 Runner has three holes at the flanges.
layifioren is offline   Reply With QuoteReply With Quote
advice , early , gaskets , headers , trd
late 4rd or early 5th gen advice? wquiles 5th gen T4Rs 9 08-30-2019 07:03 PM
Opinion needed, headers or oem? Theo85 4th Gen T4Rs 5 08-18-2015 01:31 PM
WTB: 3rd gen early model center dash piece (with vents) clemson4r Want to Buy/Trade 5 06-08-2014 06:38 PM
Blew head gasket... I think I need headers 2ndGen4runner4x4 Classic T4Rs 28 10-04-2013 11:13 AM
Need Advice on 1995 4Runner. Piece out or Swap Engine?? HungerGames Classic T4Rs 8 09-25-2013 06:06 PM
