Old 07-12-2014, 06:13 PM #1
jhumphrey jhumphrey is offline
jhumphrey is on a distinguished road
Wiper/washer question
All,
The other day I tried to use my rear wiper and it didn't work. I had used it a few times prior and it was fine, albeit a little "slow". I figured the motor died and I'd replace it, eventually.
So, I took the runner in for an alignment. They always do an "inspection" and noted the washer fluid didn't work. It, too, had worked the previous times I had used it (only a couple of times). Is the culprit a bad wiper switch? The front wipers work fine.
Thanks
jhumphrey is offline   Reply With QuoteReply With Quote
Old 08-03-2014, 05:14 PM #2
POPSRNR POPSRNR is offline
POPSRNR is an unknown quantity at this point
Another wiper problem
I'm having the same problem with my '06 V8 4Runner. Checked the fuse that protects the rear wiper and washer but it was good. Before I tear into the wiring did you ever find out what the problem was? Or if anyone can suggest where to look I'd appreciate it. Tnx.
Edit: jhumphrey, I just discovered the problem thanks to poster jacper in another thread. Apparently there is a sensor/interlock switch associated with the rear hatch window. So that when the window is down, the wiper and washer are disabled. By lowering and raising the window the problem was "fixed". Possibly to occur again in the future. I guess the sensor/interlock switch was somehow temporarily disabled, due perhaps to corrosion. Give it a try.
Edit 2: Here is the verbiage from the shop manual related to the rear hatch window-wiper/washer interaction: "Rear wiper operation: The back door ECU initiates rear wiper intermittent or continuous operation according to rear wiper SW command from the body ECU. At this point, the position of the back door window is confirmed and, if it is not fully closed, the command will be neglected preventing the rear wiper from starting. Rear washer operation: Turning the rear washer SW ON, with the ignition SW ON and the back door window fully closed, initiates rear washer operation."
Can you imagine that, a "back door ECU". Yikes. I grew up when ignition systems consisted of points, condenser and a rotor. Life was simple back then.
Last edited by POPSRNR; 08-03-2014 at 05:51 PM. Reason: Provide a temporary solution
POPSRNR is offline   Reply With QuoteReply With Quote
rear wiper / washer not working thholr Problems & Warranty Issues 37 01-09-2020 07:34 PM
Rear Wiper & Washer Not Working AE1M 4th Gen T4Rs 6 09-22-2013 09:33 PM
Rear wiper & washer inop. stevec5000 4th Gen T4Rs 2 09-12-2012 07:35 PM
Wiper washer problem Y2KSR5 5th gen T4Rs 3 01-13-2012 12:37 PM
Rear Wiper and washer cknsls@adelphia Problems & Warranty Issues 6 01-01-2008 02:30 PM
