05-28-2022, 03:57 AM
#181
looking at the truck at co part. my suspension parts all survived, but the stock things broke. rack exploded, lower ball joint bolts sheared and the arm coming off the lower ball joint broke. lower ball joints were actually fine. my panhard axle mount extension broke.
'02 Toyota 4Runner SR5
E-Locked | Geared | Mid-Travel | 35s | Armored | 100% Chooched
05-28-2022, 03:58 AM
#182
I saved the engine, trans, wiring harness and interior for future use.
#183
took the spindles and control arms and did some gussets and sold them to connor to use on his truck.
05-28-2022, 04:00 AM
#184
After i had pulled everything and stored it in black and yellow boxes, and pulled the frame. I cut what i wanted to keep from the body and scrapped the rest. RIP goldilocks.
05-28-2022, 04:12 AM
#185
Last year I picked up a 2001 3rd gen, same color, and have been working on that recently. I did the headlights, and right now im having a friend of mine install the trail gear three link kit on the front, and the back im going to modify an 80 series axle and do some shocks and things. should be fun.
05-28-2022, 06:59 AM
#186
Real Name: Robert');DROP TABLE Students;
That’s a hell of an update, glad you weren’t hurt worse.
Post a ton of pics of your new build!
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
05-28-2022, 10:13 AM
#187
Real Name: Patrick
Real Name: Patrick
Such a casual mention of injuries occurred lol I’m glad it wasn’t worse! Best of luck with the new runner. It sounds like you’ve got a nice build in the works for it.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
