Old 07-31-2014, 05:19 PM #1
ty7466 ty7466 is offline
ty7466 is on a distinguished road
Battery or Alternator?
Hello!
So first i was having a Cylinder misfire so i changed my spark plugs, spark plug wires and my ignition coil. Non of those fixed my misfire. Then one day my battery died while i was driving so after that happened I replaced my battery. I was still getting the misfire so today I had a mechanic looking at it and they said it was my fuel injector in cylinder 3 and they quoted me at $950 to change it so i said hell no to that and i just changed it myself and I do not have a misfire anymore I fixed it for $80! but as i was driving around my rmp gauge, mph gauge and radio and windows rolled up very slow so all those stopped working and the gauges went to zero as I was driving.
Even though i replaced my battery a week ago my car still died. So it must be the alternator right?
Thank you very much ahead of time!
ty7466 is offline   Reply With QuoteReply With Quote
Old 07-31-2014, 06:20 PM #2
nissanh nissanh is offline
Depends. May be your battery is bad. But while driving everything happened, so I suspect the alternator.
Check the voltage while engine is running. It should be above 13.0 volts. I get 14.2 with AC/Headlights/wipers on.
If the problem is with your alternator, you can pull it out and inspect the brushes. These are the first thing that goes bad (wear out). You can buy replacement brushes on ebay or may be from the dealer.
Brushes look like follows: Most toyota brushes are identical and interchangeable
Alternator Brush Holder with Brushes Denso 021620-2010, -2180, -2200, -2201, -2630 - 1993 GEO STORM 1.6L NEW ALTERNATOR - 13569
for $950 + $300, you can get a low mile JDM engine installed!
Old 07-31-2014, 06:31 PM #3
ConstantFix's Avatar
ConstantFix ConstantFix is offline
ConstantFix is on a distinguished road
You can test your alternator easily. With the car running, unhook the positive on your battery. the alternator must be able to run the vehicle and all of the equipment flawlessly. The idle May drop slightly, but it should maintain the vehicles stock equipment. If it doesn't and the car dies,not here's your problem.
1997 radiant red 4x4 5spd 3rz, e-lock. 406000km (250000 miles).
Home made roof rack and side ladder. 2-50" Cree light bars, 60" High-lift jack, 5' shovel, handheld gps with separate tracking device, gazillion different tools, dual mounted batteries with cs144 upgrade and the "big 3" ,2 fire extinguishers, MAPP gas. All rolling on 285-75-16" kenda Kevlar mt's
ConstantFix is offline   Reply With QuoteReply With Quote
Old 07-31-2014, 06:33 PM #4
awesome i will go check this out right now and I will get back to you!
Old 08-01-2014, 12:23 PM #5
now I am leaking where the fuel injectors are, injector 3 and 5.. how should i fix this now ?
Old 08-01-2014, 12:33 PM #6
I replaced my my injector 3 and then my injector 5 started leaking. and now i decided to switch 3 and 5 to see if it fixed the problem and now both of those are leaking!
alternator , battery , died
Battery or Alternator? slimatic 3rd gen T4Rs 20 03-02-2019 11:07 AM
Alternator or battery? Dunngeon 4th Gen T4Rs 19 12-12-2013 09:05 AM
Battery? Alternator? Zackadeez 3rd gen T4Rs 10 11-23-2013 04:13 PM
Bad Battery and/or Alternator??? mustangaustin34 3rd gen T4Rs 6 12-14-2009 11:04 PM
Battery or Alternator? Krystle Classic T4Rs 0 11-30-2009 07:41 PM
