Old 05-26-2021, 09:17 AM #76
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Originally Posted by JBurt View Post
First off, Thanks for all the great information! This has helped immensely. My compressors clutch decided to explode on me a month or so ago, and since it's 100+ degrees every day I figured it was finally time to tackle this project.
I had a shop evacuate the system for me, and I thought that they depressurized the system, but that was not the case. When I took off the pressure lines from the compressor, a lot of air and oil came out very quickly. After I got the compressor out I was only able to drain about 1 oz. I am also going to replace the condenser and drier (preventative, there's nothing wrong with the current one other than age), but I have no idea how much oil to put into the new compressor. Any suggestions?
Most new compressors come with a sheet that says how much oil they are precharged with. Did your new compressor come with that?
Old 05-26-2021, 10:48 AM #77
T4R_2000 T4R_2000 is offline
T4R_2000 is on a distinguished road
Total oil or amount in the Compressor?
One of the things I learned on here is you have to be a little more specific than you think you are being. Are you asking about how much oil in the A/C system (Condenser, evaporator, receiver/drier and compressor) total, or just the compressor? If just the compressor, I agree with with most on here to fill it to a minimum of what came in it, but not to exceed 6-8oz total in the system. If you follow the charts I posted that gives you about 100-120cc in the compressor, and is what mine came loaded with. -With that and the other amounts it came to 7oz. The documents I got from DENSO, with the compressor, did not specifically state an amount, only to ensure I put the correct amount in the compressor and that I replaced the receiver drier or it would void any warranty.
The other part that confused me on here is when someone only replaced the compressor, vice the other components. Not sure why you would do that, since a bad compressor typically puts bad things into the rest of the system (rcv/drier, evap, cond and lines), but apparently some do and had success. If I am replacing the compressor then I am replacing everything and flushing all the lines, but I am more of a fail safe guy (32 yrs of submarines). If you are just replacing the compressor then you would measure the amount of oil that came out of the compressor and refill that amount, since, in theory, the system still has the remaining amount in it and you do not want to over fill it. If you are doing the complete replacement and flushing all the lines (I recommend if your compressor failed), which I did, so I used the Toyota FSM and the articles (there are multiple articles in that link on AC system component replacement) and charts I posted.
Here is the link to an article on here that contains a link to the FSM it is post #39. I had to download it to my desktop and then open in Acrobat to do a search for AC, Compressor, receiver, evaporator, refrigerant, to find what I needed. It is not very user friendly and takes some time but I was able to find almost everything to validate what I did. The AC section starts on pg 1767 and covers troubleshooting and repair and replacement of the various components. The fluid levels and torque specs are a bit of a treasure hunt using the word search function in ADOBE. -Good Luck and keep us posted on how everything turns out.
OOPS: forgot the link to the FSM post:
Download 1996-2002 Service repair manual here!
T4R_2000 is offline   Reply With QuoteReply With Quote
Old 05-28-2021, 06:55 PM #78
JBurt's Avatar
JBurt JBurt is offline
Real Name: Jeff
JBurt has a spectacular aura about JBurt has a spectacular aura about
JBurt's Avatar
Real Name: Jeff
This new compressor is a Denso, and it did not say how much it came prefilled with, but I was able to drain out 80cc
manual here!
Thanks for the good ideas from both of you! I don't know why, but I'm not getting email notifications for this thread.
I really appreciate the help. I've actually got a hard copy of the FSM, and it is frustratingly undetailed about ac system oil. It tells how much to put into the drier, evap, and condenser, but not the compressor. I have looked at the adventure taco post and it seems to agree with everything else I've read.
My clutch went bad on the compressor so the pulley seized. Would that be enough to damage the internals and contaminate the whole system? The old compressor still turns by hand just fine (just not the pulley).
Right not my plan is to put 110cc (~3.7 oz) in the compressor, 45cc (~1.5oz) into the new condenser, 20cc (~.7 oz) into the new drier. That should be 175cc or 5.9 oz of oil into the system.
I am also going to pull and inspect the evaporator, as they get grungy and I haven't had it out in 9 years. I can try to drain the oil out of it and replace whatever comes out. I have thought about replacing it as well, since I consider AC critical here, but it is also $300. Thoughts?
97 SR5 4runner: 2" OME Lift, rear E-Locker, 231mm Tundra Brakes, 203K, B&M 70264 Tranny Cooler, Duratracs
Build
JBurt is offline   Reply With QuoteReply With Quote
Old 05-31-2021, 09:15 AM #79
Real Name: Patrick
Real Name: Patrick
If it was my vehicle, I would go ahead and replace the evaporator since you have replaced most of the other ac components.
Old 06-11-2021, 08:49 PM #80
JBurt's Avatar
Real Name: Jeff
JBurt's Avatar
Real Name: Jeff
So I did wind up replacing the evaporator, which was good since the old one was pretty grody, and I think it was leaking around the expansion valve (also replaced). I got the system recharged today, and the compressor wouldn't engage. Turns out when your AC clutch goes out, it will blow the corresponding fuse, which is good to know.
Anyways the AC now works, but it's not as cold as it used to be. The ambient temperature when I measured today was 101*F, and the temp at the center vent was 68*. That's at idle in my driveway, which is a hell of a lot better than nothing, but it used to be low 50's high 40's. My moms highlander was putting out 51* when checked right next to the 4runner.
All said and done I added about 7oz of oil to the system replacing the compressor, evap, condenser, and drier. Too much? Anyone got any ideas how I can make it colder?
I did check for leaks, and there's no bubbles in the sight glass, and nothing showing up with the UV light. I think my manifold is leaking so I'm a little hesitant to hook it up, but I probably should hook up a manifold and see the pressures.
Build
Old 06-14-2021, 09:38 AM #81
Real Name: Patrick
Real Name: Patrick
Do yo have access to ac manifold set with gauges? If you do check your pressures at 1500 rpm. Low side should be 20-35 psi and high side should be 200-230 psi. Those are for ambient temps at 86-95 *F so if you're above that then your readings will likely be higher. Also ac on, temp set as cold as possible, fan on high, recirculate on, and all vents open.
Old 12-20-2021, 08:09 PM #82
Green994 Green994 is offline
Green994 is on a distinguished road
Compressor manifold to compressor bolts torque specs
Originally Posted by alumarine View Post
Both suction hose and discharge hose should be 7 ft lbs.
I have the same question, but are you taking about suction and discharge hose where they bolt onto the manifold is 7 ft lbs? I need manifold to compressor specs. Anyone?
99 2wd 3RZ with 10Pa17c compressor
Green994 is offline   Reply With QuoteReply With Quote
2000 limited 4runner front bumper replacement? kyleh 3rd gen T4Rs 11 02-27-2018 10:32 AM
New 10' Limited owner...complete 180 AbJimAl24 New Members 3 07-21-2013 01:56 PM
Best complete 3" budget lift for my 2000 LTD Ride_Red 3rd gen T4Rs 9 05-30-2012 03:57 PM
