Old 08-07-2014, 03:51 PM #1
Jack08520 Jack08520 is offline
Jack08520 is on a distinguished road
Steering knuckle replacement
While replacing the rack/pinion on my '02 I grabbed the end of the steering link (where it attaches to the rack) and "wiggled it around" and found that there is also some play in that linkage. Seems that there is a short shaft on the steering wheel then a knuckle then a shaft that drops down to the rack (circled in attached) - how difficult is this sucker to replace?
Steering knuckle replacement-steering-knuckle-jpg
Jack08520 is offline   Reply With QuoteReply With Quote
Old 08-07-2014, 04:13 PM #2
badattitude's Avatar
badattitude badattitude is offline
badattitude will become famous soon enough badattitude will become famous soon enough
I'm interested in this as well. After the dealer installed a reman R&P I have just a little play in the same area. Apparently, they used the BFH and a chisel to remove the old coupler and I think damaged the same knuckle.
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
badattitude is offline   Reply With QuoteReply With Quote
Old 08-07-2014, 04:56 PM #3
LexusFTW LexusFTW is offline
LexusFTW is on a distinguished road
I replaced that piece when I replaced the steering rack a few months ago. You will have to find a way to separate the two steering linkages either by unbolting and moving the steering rack a couple of inches or pulling the steering column a couple of inches through the dash (if possible).
1997 SC400
748whp 25psi
1999 4Runner Limited 4WD
Black/Tan, E-Locker
LexusFTW is offline   Reply With QuoteReply With Quote
Steering Knuckle Replacement.. jstutz101 4th Gen T4Rs 13 03-28-2017 09:50 PM
Steering Knuckle knothead 3rd gen T4Rs 9 06-24-2013 08:42 PM
Write-up for Replacing Steering Knuckle? Fjatheart 3rd gen T4Rs 12 04-08-2013 05:31 PM
Taco steering knuckle vs. 4Runner steering knuckle ryankmasuda 3rd gen T4Rs 6 08-27-2012 09:05 AM
Steering Knuckle seal BCfish 4th Gen T4Rs 1 06-16-2012 12:53 PM
