Old 08-10-2015, 04:04 PM #46
broken wrench's Avatar
broken wrench broken wrench is offline
broken wrench is on a distinguished road
Originally Posted by MTD View Post
might want to reread these last two paragraphs for grammar mistakes. They got kind of hard to follow.
I see them, with two junior techs to train. It's hard to type, look and listen without wanting to hit yourself with a blunt object when it's over 100 degrees
For sale,
97 runner 5" lift 35's with 5.29 gears
86 xcab
1st gen interior misc
broken wrench is offline   Reply With QuoteReply With Quote
Old 08-10-2015, 04:20 PM #47
Originally Posted by Doc2012 View Post
Might want to re-read all this for mistakes.
There are plenty of people here that have used an aftermarket cat, have passed inspection, and have been fine for years, if this was the route they chose to go.
If you live in Cali, I would say to stary clear, simply because Cali does the Sniffer test, and while the light might not be on, the exhaust can still cause it to fail, from my understanding (I don't live in Cali, nor whould I ever want to).
A O2 "spacer" is going to move it out of the gasses? How? Hose gasses are still going to be surrounding the O2 sensor. those gasses are going to fill every inch of that tail pipe, so by moving the sensor "out of the stream", you're really just moving the sensor up. Not doing anything at all really.....
I see it first hand, majority of cali cars do not pass with aftermarket cats.So we use a dealer cat based on vin and all is good. We do use aftermarket cats on all types of vehicles. Yes, they do pass. We do the sniffer test here.
As you stated, it is a spacer moving it out of the stream enough for the 02 to fall into calibration peram's. Most of the time it is a weak or failing sensor by a small %, so it does work. Until the sensor completely fails.
And so the great debate continues on which is the best method to fix or work around the 02 sensor codes.
For sale,
86 xcab
Old 08-10-2015, 04:32 PM #48
MTD's Avatar
MTD MTD is offline
MTD is on a distinguished road
MTD MTD is offline
MTD's Avatar
hahaha keep them in line lol
Need something 3D printed, T4R.Org members get 10% off @ my 3D Hub!
Custom 3D Printed Retro and Other Badges!!
MTD is offline   Reply With QuoteReply With Quote
Old 08-10-2015, 04:33 PM #49
MTD's Avatar
MTD MTD is offline
MTD MTD is offline
MTD's Avatar
Meh
Old 08-10-2015, 07:29 PM #50
Robb235's Avatar
Robb235 Robb235 is offline
Real Name: Robert
Robb235 is on a distinguished road
Robb235's Avatar
Real Name: Robert
I've heard of this before. People typically use spark plug non-foulers that you can find in the Help! section of Autozone. Most 3rd gen 4Runners can't use this method because we have the bolt on oxygen sensor, not the screw on type.
1999 Toyota 4Runner Limited 4x4 - Turbocharged Garrett 57-trim T3/T4 - URD AFR Sensor Calibrator - DW255 fuel pump - 7MGE Supra 315cc “lime green” fuel injectors - 231mm Tundra Brakes - B&M 70264 Transmission Cooler - Monitoring ATF Temps and AFRs With My iPhone - DIY Projector Headlight Retrofit - Cooper Discoverer AT3 - OME 906 Coils & Rancho 9000XL Shocks (Rear) - Airlift 1000 - RadioShack $5 Rear O2 Simulator
2000 Yamaha XR1800 Jet Boat - MR1 4-Stroke Engine Swap
Robb235 is offline   Reply With QuoteReply With Quote
Old 08-11-2015, 10:01 AM #51
Nelsonmd's Avatar
Nelsonmd Nelsonmd is offline
Nelsonmd is on a distinguished road
Nelsonmd's Avatar
Darn EE's and their RC circiut and time constant witchcraft!
So simple division is witchcraft you say? I think UW might want to take back your permission to use their logo as your avatar
You're right about the Cali test, though I think that the aftermarket CAT's are getting a bit better and may pass the sniffer test now. I believe that Walker CAT's are actually on the approved list. Others have said that in Cali they actually check the model/brand of CAT you installed and it has to be an officially approved one (i.e. that CAT company has donated to the campaign fund for some Cali rep...).
You're incorrect about the spacer doing nothing. The O2 sensor is designed to have the sensing element right in the middle of the exhaust flow, so if you take it out of the exhaust flow, then you are getting less gas blowing through/by the sensor, so less detection. There is a huge difference between flowing gas and stagnant gas (from a sensing standpoint). If it worked the same in stagnant gas, then believe me, they would not go through the trouble of making the sensor stick out into the middle of the ridiculously hot and corrosive exhaust gas.
2000 SR5 3.4L V6 Automatic 4x4, e-locker, 175k Miles, Rust
Imp. Jade Mica with Oak Leather Interior, Field Monitor Unit - B&M Tranny Cooler - SG2 - New (to me) rear axle assembly - Goodyear Duratrac 265/75-16 - 1.8" Ironman Front Lift, OME 906/Procomp 9000 Shocks
http://www.toyota-4runner.org/3rd-ge...ld-thread.html
Nelsonmd is offline   Reply With QuoteReply With Quote
Old 08-11-2015, 10:21 AM #52
midcoma midcoma is offline
midcoma has a spectacular aura about midcoma has a spectacular aura about midcoma has a spectacular aura about
FWIW, here's my experience.
A while ago, probably 3-4yrs, I had an exhaust related engine code on my Tacoma. I don't remember exactly which code. I followed the procedure in post 1 to modify my rear O2 sensor and the CEL went off and the code cleared.
A couple months ago I got a CEL with the code of P0137 - Oxygen O2 Sensor Circuit Low Voltage (Bank 1, Sensor 2). I decided to buy a new Denso O2 sensor and the URD simulator (I gutted my CAT and welded a straight pipe through it a while ago). After switching the modified O2 sensor for a new one with URD's simulator, the CEL and engine code went away.
So does the modified O2 sensor work? Yes, but for how long.
Is a modified O2 sensor exactly the same as a URD simulator? Probably not.
midcoma is offline   Reply With QuoteReply With Quote
Old 08-11-2015, 10:27 AM #53
jeremyc74 jeremyc74 is offline
Banned
jeremyc74 is on a distinguished road
Banned
Originally Posted by Nelsonmd View Post
So simple division is witchcraft you say? .
There's a little more to it than that.
jeremyc74 is offline   Reply With QuoteReply With Quote
Old 08-11-2015, 10:30 AM #54
MTD's Avatar
MTD MTD is offline
MTD MTD is offline
MTD's Avatar
JK
Old 08-11-2015, 10:32 AM #55
MTD's Avatar
MTD MTD is offline
MTD MTD is offline
MTD's Avatar
Meh.
Old 08-11-2015, 11:18 AM #56
cashmoney cashmoney is offline
cashmoney is on a distinguished road
And that is why I quit math at Algebra 2. Math shouldn't have letters in it!!
1989 Toyota 4runner
cashmoney is offline   Reply With QuoteReply With Quote
Old 08-11-2015, 12:04 PM #57
Nelsonmd's Avatar
Nelsonmd's Avatar
Not if you reduce it by limiting the time constant to what you actually want it to be (apparently about 1s in this case) and the voltage to the fixed supply oltage of the sensor. once you do that, the equation for time constant is only related to the ratio of R and C, so if you know what ratio you need, then it really is just as easy as simple division.
Always reduce the problem to the least complex solution.
Old 08-11-2015, 08:18 PM #58
ToyTaco ToyTaco is offline
ToyTaco is on a distinguished road
Hey guys, I'm about to do this mod on my 02 taco. I need the help of some electrical gurus. I'm in Canada and radio shack is no more. I went to the local electrical store told the guy what I needed by cross referencing the radio shack part numbers the capacitor he gave me is TOPMAY 105j250v and the resistors are 1/2 watt 1m OHM 2%, the radio shack says 5%, Can you guys tell me if this will jive if all wired in properly? Thanks guys
ToyTaco is offline   Reply With QuoteReply With Quote
Old 08-11-2015, 10:32 PM #59
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
The capacitor info you gave does not include the capacitance--so it might be right or not. The resistor is fine. 2%/5% is the tolerance and either is fine for this application, and 2% is better than 5%.
My Backyard Frame Swap
Old 08-12-2015, 08:52 PM #60
Thanks Dirk. I searched 105j it says that is the code for 1uf.
Spintires (PC off-roading simulator) ShAwTWiN General Discussions 1 01-30-2014 08:55 PM
U.R.D. simulator on the way T4Rscott 3rd gen T4Rs 4 02-09-2012 12:46 PM
Rim Simulator Turn_down General Discussions 0 05-22-2011 08:42 PM
Toyota Driving Simulator IntoTheVoid General Discussions 1 03-13-2010 07:48 PM
