Originally Posted by jerbrun0515
Thanks! Looks great! I currently have an ICON Stage 2 lift which I don't think I'm getting 3" of lift from. Bought the truck as is and still have to figure that out. Tires are 255/75R17 and I've been trying to research options for a little wider tire without going too much bigger in diameter.
Sent from my SM-G965U1 using Tapatalk
according to google that lift is 0-3". so it just depends on how youve got it setup.
if it matters, my wheels are 16x8 -25 offset (3.5 backspace, the more aggressive of the two). i went with the lower offset as i liked the 'stance' and since i have a lower offset, it clears the 33s better on the inner fenderwell side.
i use this website to check tire sizes:
https://www.willtheyfit.com/index.ph...=8&offset2=-35
its for stretched tires (what i was into before i had my 4runner), but it still works out great for just general number plugging in. really helps compare setups.
