Old 08-21-2014, 01:23 PM #1
97 _SR5 97 _SR5 is offline
97 _SR5 is on a distinguished road
Adjustable Rear Upper Control Arms
So i have installed my Frankenstein lift with Rancho shocks and OME 891 rear coils with spacers. I added the spacers because front lift ended up being about 3.75" and with 891 in the rears, it did not look good, so I added a 1.5" rear spacers. Now truck measures 24" in front from center hub to bottom of fender and 24.5" in rear. I have installed an adjustable rear trac bar with drop bracket, but I have researched quite a bit about about the change of the rear pinion angle... I have not measured anything in regards to angle yet, however I have found out that the adjustable rear upper controls adjusted about 1/4" longer will help return the pinion angle closer to stock geometry. With that being said how do i correctly adjust the arms to know I am actually improving things. I have no experience with adjustable rear components. Thanks for your help
Rafal
1997 4Runner SR5 V6 Auto
97 _SR5 is offline   Reply With QuoteReply With Quote
Old 08-21-2014, 01:47 PM #2
csp csp is offline
csp is on a distinguished road
csp csp is offline
Unless you're experiencing driveline vibrations you really don't need to mess with pinion angle.
You would adjust the arms so that the pinion is moving the direction, either up or down, that it needs to go to be in the correct alignment with the output of the transfer case.
To bring it up you make the upper arms longer and vice versa to pull the pinion down.
csp is offline   Reply With QuoteReply With Quote
Old 08-21-2014, 01:54 PM #3
No vibrations yet... put 250 miles on the new lift so far. As far as what you have said about the adjustment is pretty much exactly what I have read when researched, I was looking for something more specific as to maybe what angle the pinion/driveshaft should really be at... I don't want to start going through u-joints too often and I'm trying to make the suspension dependable for years to come. Thanks for the response.
Ok so I have found this that is closest to answering my question :
http://www.toyota-4runner.org/1699516-post4.html
But am I correct in thinking that as long as I keep the driveshaft/pinion in a straight line, the actual angle doesn't matter?
Old 08-21-2014, 02:20 PM #4
MStudt's Avatar
MStudt MStudt is offline
official vendor
Real Name: Mike & Penny
MStudt has a spectacular aura about MStudt has a spectacular aura about MStudt has a spectacular aura about
official vendor
MStudt's Avatar
Why are you wanting to adjust the pinion? If you don't have drive line vibrations I won't touch it. You're going to spend money on something that you claim isn't an issue.
We've got DC joints on the rear shafts. There is no simpler shaft to set-up than these. You can run a straight line from the pinion up the shaft and that is considered a perfect angle. However, I'd allow for around 1-2 degrees of the pinion pointing down to help with the springs settling over time.
As stated before. I won't go messing with it if you don't have issues. So many people try to fix things that need to be fixed.
MStudt is offline   Reply With QuoteReply With Quote
Old 08-21-2014, 02:34 PM #5
I understand what you are saying. But since the lift is relatively new, and if down the road vibrations develop (truck has 390,000 miles on it) and the bushings on about everything in the suspension are getting pretty worn. I'm just trying to figure out what is involved if this need to be done down the road really. I'm not going to mess with it right now, but at the same time, I would like to be more proactive about this.
Old 08-21-2014, 02:38 PM #6
MStudt's Avatar
official vendor
official vendor
MStudt's Avatar
If you're feeling it not you won't in the future. I would say your lift is at it highest point right now. This would put your pinion in the worse angle it's going to see. Once your springs settle down, your pinion will also come back down.
Old 08-21-2014, 03:40 PM #7
Flatulento's Avatar
Flatulento Flatulento is offline
Real Name: Dan
Flatulento is on a distinguished road
MY GARAGE
Flatulento's Avatar
Real Name: Dan
MY GARAGE
The original question posted is a good one. Also the image in Mstudts post is from a very good write-up on driveline angle.
Tom Wood's Custom Drive Shafts - Driveline 101
However, something this article doesn't address is how the angle of the pinion changes as the suspension compresses or extends. The 3rd gen rear suspension set-up is basically a 4-link mechanism. Depending on the difference in the length of the arms (top vs. bottom) and the difference in the spacing between the pivot points (front vs. rear), the pinion angle will change as the rear end travel through its arc. So, with that being said if the factory difference in arm length and pivot spacing is designed to keep the pinion in line with the driveshaft through the full arc of travel, then no adjustment should be necessary. The question is: was the suspension set-up to do this? Has anyone observed the degree to which the angle between the pinon and the driveshaft changes as the suspension cycles between compression and extension?
2000 SR5 - 3.4L, 5spd., e-locker, savage rr bumper, homemade doggie deck/drawers, 199mm Tundra Brakes, On-board Air
Flatulento is offline   Reply With QuoteReply With Quote
Old 08-21-2014, 03:44 PM #8
T4Ryota4life's Avatar
T4Ryota4life T4Ryota4life is offline
T4Ryota4life is on a distinguished road
I had to replace both front inner cv boots after my lift. I am sitting at 23 center of hub to fender. Just a heads up.
2001 4Runner, Toytec Boss Lift, SPC UCA, SS Diff Drop, Toytec Super Flex Coils, Rear Bilstein 9602R703, SS Extended Bump stops, SS Adjustable PanHard Bar, 94-95 rear sway bar end links, Bushwacker Fender Flares, Savage Off-Road Sliders, Deck Plate Mod, ISR Mod, Goodyear Duratracs 285/75/16
T4Ryota4life is offline   Reply With QuoteReply With Quote
Old 08-21-2014, 04:32 PM #9
When I put the front spring/strut assembly on, I replaced LBJ, inner/outer tie rods, both cv shafts with new ones, and installed high angle boots on both shafts. Still have Upper Control Arms to swap up as my stock bushings are pretty much gone...
Rafal
Old 08-21-2014, 08:29 PM #10
kammando808's Avatar
kammando808 kammando808 is offline
kammando808 is on a distinguished road
MY GARAGE
MY GARAGE
Rafal
So I assume your 891 are sagging? Do you have pics with and without the rear spacers?
98 limited-3" body lift, toytec/eibach, toytec superflex, bilstein5100, spc uca, 285/75/16 nitto trail-grappler, 16x8 procomp 7031, 1.5" spider trax wheel spacer, elocker, b&m transmission cooler, Isr and deck plate mod, satoshi grill, 30" led bar, plasti dip front/rear bumpers and fender/cladding,
kammando808 is offline   Reply With QuoteReply With Quote
Old 08-22-2014, 12:17 AM #11
They sagged about 1". No pictures without the spacers, but here's a quick one currently with spacers. The 891 would have been OK with only a 3" lift in the front.
Old 08-22-2014, 12:41 AM #12
MY GARAGE
MY GARAGE
Yah I have a 3 up front but my 891 sags more then a old grandmas ass lol, hopefully soon but I'm really considering upgrading to the toytec superflex/adj panhard bar and drop bracket, don't really think I need the rear uca as much as I want it
Old 09-10-2014, 10:52 PM #13
Cree's Avatar
Cree Cree is offline
Cree is on a distinguished road
Cree's Avatar
Just installed 891's with no packers. Measured the angle tonight and it looks like there's roughly a 5 degree split between d/s and pinion. No vibration, BUT there is a little noise that I'm assuming is coming from it being slightly bound.
It seems like this is something most people ignore or write off as a non issue. I'd wager a guess that if everyone measured after a lift that their pinion angle is wrong. Maybe it's not a big deal, maybe I'm wrong. But I'm not going to bet tearing into a 3rd member to replace a worn bearing on it. I'll be ordering some Toytec upper arms next week. Wish I had looked into this a little more before I ordered everything instead of having to spring the extra spending on the CFO (aka wife).
00 Limited - Stuff!
13 Explorer Sport - No stuff, Just boost
Cree is offline   Reply With QuoteReply With Quote
Old 09-10-2014, 11:19 PM #14
csp csp is offline
csp csp is offline
As long as that five degrees is with the pinion lower than the driveshaft you're probably ok. It really isn't good to have zero degrees at the pinion as there needs to be a little angle for proper lubrication in the ujoint caps. It also helps with avoiding brinelling between the needle bearings and the cap.
The pinion will also rise a little bit under power.
Old 09-10-2014, 11:23 PM #15
Cree's Avatar
Cree's Avatar
Any guess what the factory spec is?
00 Limited - Stuff!
4th gen Adjustable Upper Control Arms inscarguy 4th Gen T4Rs 32 03-28-2018 11:33 PM
FS: 3rd gen parts 99 tall rear springs, upper control arms SoCal. KinevilsT4R For Sale: Suspension/Wheels/Tires 1 03-08-2014 01:29 PM
I want to build some Rear adjustable upper control arms. Needs parts links opie74 3rd gen T4Rs 5 08-24-2012 08:03 PM
FS: Adjustable Rear Control Arms AlexJet Classifieds - buy & sell (no commercial ads please) 1 11-19-2010 01:56 PM
Adjustable Rear Control Arms JeremyH 3rd gen T4Rs 8 01-14-2010 02:15 PM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
