Old 08-23-2014, 08:57 PM #1
1998Yota4Runner's Avatar
1998Yota4Runner 1998Yota4Runner is offline
Real Name: Kyle Seal
1998Yota4Runner is on a distinguished road
Couple of Questions After Replacing Front Brakes
1998 4Runner Limited 4WD v6.
So yesterday I replaced the front discs and rotors due to warping and warn brakes. And it wasn't too difficult, just a first timer at this.
Cleaned & bled, ect.
Now it seems my wheel is pulling to the right (passenger side) when applying the brakes somewhat heavily, and doesn't occur when lightly applying (to my knowledge)
And also now I hear a thump from underneath the car when reaching the bottom of the brakes and coming to a stop.
I read somewhere that the sway bar could possibly be an issue, as my driver side mount has rusted and busted recently.
So my questions are:
Why the pulling?
Why the thump?
Is the broken sway bar mount a factor?
How to fix?
If you need pictures just ask, as I'm sure someone will.
Thanks in advance - I'm somewhat a newbie, so go easy on me.
1998 4R v6 4x4. One owner. New engine. Good body, has some secrets though.
1998Yota4Runner is offline   Reply With QuoteReply With Quote
Old 08-23-2014, 09:11 PM #2
JRZEE2000TR4LTD's Avatar
JRZEE2000TR4LTD JRZEE2000TR4LTD is offline
Real Name: John
JRZEE2000TR4LTD will become famous soon enough JRZEE2000TR4LTD will become famous soon enough
Real Name: John
Why the pulling?
Why the thump?
How to fix?
Check those calipers. My bad caliper had messed up dust seals on the pistons and my inside pad on the passenger side was cracked right in the middle. If you have a broken sway bar link, that should be very obvious.
SILVER 2000 4runner Limited TOTALED
WHITE/SILVER 1999 4runner Limited l Rear Locker l Tundra/890 coils | 5100 Bilsteins all around | Sonoran Steel Bumpstops l 199 mm Tundra brake upgrade | SCS Matte Gray Ray10 Rims | 275 70 17 BFG KO2 tires | LR UCAs | EIMKEITH panhard brackets | LED interior upgrade l Rear LED tailights l Pioneer AVH-X5700BHS Alpine Type "R" speakers NVX JAD800.4 Class D Amp Kenwood Under seat Subwoofer l Front window tint 20% l Weathertech window visors and floormats l OutGear Solutions Full Length roofrack l Morimoto 40" LED lightbar
JRZEE2000TR4LTD is offline   Reply With QuoteReply With Quote
Old 08-23-2014, 10:21 PM #3
So if the seals are messed up should I go with a rebuild kit as those are easier than buying a whole new caliper?
Old 08-23-2014, 10:26 PM #4
a216vcti a216vcti is offline
a216vcti is on a distinguished road
I would just do the tundra upgrade at that point. But you could do the seal. Are you sure there isn't an air bubble in the right side?
a216vcti is offline   Reply With QuoteReply With Quote
Old 08-23-2014, 10:32 PM #5
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
How is/was the alignment before the brake job?
If it is pulling to the right, then more than likely it is a sticking left brake caliper. If there is a torn seal around the piston, then dirt has gotten in there. Did you notice one? If the piston is not scarred, then a rebuild kit is a good way to go. Just make sure you have the tools to do it.
If the fluid was real old, then it could also be a bad left soft brake hose.
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 08-24-2014, 10:33 PM #6
In reply to everyone, it was the broken sway bar mount on the drivers side that made it pull to the right. Replaced both mounts this morning and torqued them down to spec and no more pulling.
1998 , disc brakes , pulling , rotors , thump
Help - Brakes locking after replacing booster - 1999 4runner pendragon 3rd gen T4Rs 8 07-03-2013 12:07 AM
Brakes warping every couple thousand miles. 99 sr5 highlander 3rd gen T4Rs 8 11-26-2012 12:58 AM
Front Bilstein 5100's Finally Installed - Couple Questions Dougtoms01 4th Gen T4Rs 15 05-18-2012 09:15 PM
Replacing Brakes on R&R...Need Ideas Madskarnigan General Discussions 0 10-02-2011 01:44 AM
Replacing stock 4Runner Radio, a couple questions. polvadis 3rd gen T4Rs 13 02-07-2006 10:19 AM
