Old 08-26-2014, 04:38 AM #1
afmatt's Avatar
afmatt afmatt is offline
afmatt is on a distinguished road
afmatt's Avatar
Question LBJ/UBJ Replacement Question
I was told my a buddy who is a long-term mechanic that I should not only replace the lower ball joint and that I need to replace them in pairs. Is it true that if I am going to replace my LBJ's I need to also replace my UBJ's?
Thanks
afmatt is offline   Reply With QuoteReply With Quote
Old 08-26-2014, 08:14 AM #2
JRZEE2000TR4LTD's Avatar
JRZEE2000TR4LTD JRZEE2000TR4LTD is offline
Real Name: John
JRZEE2000TR4LTD will become famous soon enough JRZEE2000TR4LTD will become famous soon enough
Real Name: John
Thanks
Not true, especially on these 3rd gens. The lower balljoint has a lot more stress on it than the upper and generally should be replaced more (100-150K?) as failure of the lower BJ can be catastrophic. Also, OEM balljoints are the way to go, and are similarly priced to other "quality" BJs like Moog, NAPA, or others. Don't get those crappy Ebay one for $20. Get what you pay for.
SILVER 2000 4runner Limited TOTALED
WHITE/SILVER 1999 4runner Limited l Rear Locker l Tundra/890 coils | 5100 Bilsteins all around | Sonoran Steel Bumpstops l 199 mm Tundra brake upgrade | SCS Matte Gray Ray10 Rims | 275 70 17 BFG KO2 tires | LR UCAs | EIMKEITH panhard brackets | LED interior upgrade l Rear LED tailights l Pioneer AVH-X5700BHS Alpine Type "R" speakers NVX JAD800.4 Class D Amp Kenwood Under seat Subwoofer l Front window tint 20% l Weathertech window visors and floormats l OutGear Solutions Full Length roofrack l Morimoto 40" LED lightbar
JRZEE2000TR4LTD is offline   Reply With QuoteReply With Quote
Old 08-26-2014, 08:29 AM #3
MStudt's Avatar
MStudt MStudt is offline
official vendor
MStudt is a jewel in the rough MStudt is a jewel in the rough MStudt is a jewel in the rough
official vendor
MStudt's Avatar
Thanks
If I were you. I would go ahead and replace the LBJ's right away. They may not be bad yet, but it's not going to hurt. Stick with either OEM or NAPA Premiums for the LBJ's as well. That being said, everyone is going to have an opinion on this. There are a lot of people running NAPA's here, myself included. There are also a lot of people running OEM's. We all agree to stay away from eBay for these parts, and DO NOT buy Moog either.
MStudt is offline   Reply With QuoteReply With Quote
Old 08-26-2014, 10:45 PM #4
afmatt's Avatar
afmatt's Avatar
Thanks for this tip. I was going to roll with NAPA but after recently viewing a thread showing what happens when the LBJ fails I think I'm just going to go with OEM. So how often do you think (if any) should the UBJ's be replaced?
That is one of my first projects for my 4runner, going to put in some NAPA CV Axles and while I'm in there swap out the LBJ's. When you swapped your OEM ones to NAPA how long did it take you for both sides?
Old 08-26-2014, 11:50 PM #5
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar has a spectacular aura about LittleCaesar has a spectacular aura about LittleCaesar has a spectacular aura about
OEM for LBJs, no other. Also pick up some lower LBJ bolts. Need 8 total. Part number# 90080-10066.
As far as the UBJ goes, I'd replace it only if the boot were leaking, or I was to remove the knuckle for bearing work.
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 08-27-2014, 10:58 AM #6
MStudt's Avatar
official vendor
official vendor
MStudt's Avatar
Mine took me about 2 hours total, and that was the first time I've ever done it. If you don't own a pickle fork and tie rod puller. I would either buy them, and rent them from Autozone. It makes quick work if you have them.
As I stated above. Everyone is going to have an opinion on which brand of LBJ's to run. There is nothing wrong with NAPA's, and I don't think a single person on here can confirm a failure from a NAPA LBJ. I could be wrong, but I've yet to come across a thread with a failure. There have been premature failures with using the Moog LBJ's. I was able to pick up new NAPA LBJ's from a member for $30 shipped, so I used them. If I had to buy new ones, I'd go with NAPA again.
This topic has been beating like a dead horse. The main conclusion is pretty well split between NAPA and OEM.
Old 08-29-2014, 02:55 AM #7
Dee3 Dee3 is offline
Dee3 is on a distinguished road
I bought OEM LBJ and also I bought some Proforged LBJ for another 4runner. They were better quality than expected.
Dee3 is offline   Reply With QuoteReply With Quote
Old 08-29-2014, 04:56 AM #8
Kanger328 Kanger328 is offline
Kanger328 is on a distinguished road
Just a suggestion, but if you're planning on doing any other mods in the LBJ area (i.e. Tundra brake upgrade, suspension lift, tie rods), do them all at the same time. That way you only have to tear into the area only once.
1996 Limited 4x4 Anthracite Metallic (162,XXX miles)
-OME 881/890 with Tundra Bilstein Struts/Bilstein 5100 rear, 16" 5-Stars with 265/75R16 Duratracs, Savage Sliders and Skids, B&M 70268 Trans Cooler, Amsoil Fluids
Kanger328 is offline   Reply With QuoteReply With Quote
Replacement radiator question jaredking733 3rd gen T4Rs 4 09-27-2013 09:00 PM
Belt Replacement Question Andrew Larson 3rd gen T4Rs 6 04-02-2013 10:57 PM
99 T4R SR5 LED replacement Question... MikeRickerd 3rd gen T4Rs 0 09-22-2011 02:03 PM
Transmission Replacement Question gwohlfort 3rd gen T4Rs 8 01-03-2010 03:23 PM
stereo replacement question ozana Engines / Suspension / Wheels / Tires / Audio / Accessories 2 09-18-2008 12:14 PM
