09-11-2014, 11:12 AM
Real Name: Adam
Real Name: Adam
Synthetic oil leak! Experience needed!
Edit: 02 4Runner with 177k miles.
Hey guys, I recently switched to mobil1 high mileage full synthetic 5w-30. I never had a leak prior to this with conventional oil, but now I'm getting a leak around my oil pan and even a bit around the oil bolt(nut whatever you'd like to call it, I'm tired after an overnight shift). So ironically I came home to look up info on the water pump/timing belt change that I plan to do in the upcoming weeks and I wanted to make sure if I had an oil cooler, which I did and then I saw the leak. I just put in the synthetic Saturday and have been driving roughly 55milew everyday since. So I was debating to change back to Dino or try an oil leak stopper. I got the Lucas oil leak stopper and was only able to put in maybe 2/3rds or 1/2 before I was pushing the max line.(the bottle says the whole thing for 4qyarts but I guess I had more than that in it and I didn't wanna flood it). So any experience with this? This Lucas oil leak stopper? I'm going to bed and am really hoping it works. Even if It stops the leak until
I switch back to regular oil at the next interval then that's fine. I wasn't sure if I switched to regular oil If it would
Leak or not since I'm assuming the synthetic oil cleaned up whatever and now the leaks are present. Again, I had no prior leaks. Also, any ball park on gasket changes if it comes down to it? There's a pep boys near me... I really don't wanna do gasket changes since it seems like it would be a b*tch. Thanks....
PS: I understand synthetics doesn't cause leaks, so I don't want somebody flamin me and saying I'm saying it does. I'm just saying the detergents clean the engine and then the underlining or "hiding" leaks become present.
2002 4Runner SR5(2wd)
09-11-2014, 11:21 AM
Just throwing this thought out there but... why not get the oil pan fixed (Maybe new gasket?) and continue to utilize the benefits of synthetic?
There had to be a reason you wanted to go synthetic in the first place.
Now if you are leaking oil after a pan-fix and synthetic... that's the shop (Or your) problem, and another story
09-11-2014, 11:28 AM
The synthetic oils have a different molecular make-up, so the synthetic oils will leak, where a dinosaur blood based oil may not. I agree, if the leak is repairable, then I would try to do so and live with the synthetic oil benefits.
09-11-2014, 12:27 PM
Synthetic oil didn't cause any leaks. You simply have a bad seal somewhere. Change out the seal.
09-11-2014, 12:33 PM
I'd just give what you have in there time and see if the leak begins to let up or stops altogether. If not, try a synthetic blend HM oil. Maxlife comes to mind.
Forgo using any more of the Lucas.
Real Name: Andrew
Real Name: Andrew
I always use high mileage synthetics which contain larger molecules to help with this sort of thing.
97 FZJ80 40th Anniversary Edition wife-mobile/weekend wheeler
SOLD'98 T4R 5spd, e-locker, Boss coilovers, LC 8wraps, Tokico blacks, SS extended bump stops, 255/85r16 Toyo M/T's
http://www.toyota-4runner.org/3rd-ge...ml#post1707857
09-11-2014, 12:35 PM
Fix the leak.
09-11-2014, 12:38 PM
Think of it this way, now you actually are using an oil that is obviously penetrating which is now actually lubricating your bearings, cam surfaces and seeping into places that were previously unlubricated. I'd replace your oil pan gasket and get a new bolt gasket.
All it means is your old oil sucks.
Also, high mileage oils are as bad as running dino, you might as well run the crappiest oil you can find.
I swapped my 4th gen over at 170k miles with no issues.
2003 4runner SportEdition V8 4x4: Metaltech/Radflo 2.5" w. Resi Stage 6 suspension, LT275/70/17 Cooper AT3, RCI Skids, Shrockworks sliders, K&N filter, Reinforced front diff mount
2008 Lancer Evolution GSR: Muellerized Ohlins Road & Track coilovers, Whiteline Roll Center kit, K&N filter, Road Race Engineering stealth exhaust, tune ~400hp
09-11-2014, 02:27 PM
Real Name: Andrew
Real Name: Andrew
Got anything to back that statement up?
09-11-2014, 05:29 PM
Real Name: Steve
Real Name: Steve
ya, or any of the other nonsense he spewed in his post.
and
@ T4R2014
hit the nail right on the head. Synthetic oil didn't cause any of your problems.
2003 Silver Pine Lexus GX470- Radflo extended travel/FN BFD’s/Total Chaos/33’s.
09-11-2014, 05:49 PM
official vendor
official vendor
How bout try tightening your oil pan gasket bolts to see if you can get away with that for a while? Don't crank the crap out of them.. youll either squish the seal too much or break the little 10mm bolts...
The oil drain bolt... all it needs is a new washer... if its not too much leaking from there just wait till your next oil change
Dirtcom Inc.
www.dirtcomusa.com
Current Ride \/ video link below
500k Mile V8 4runner
SOLD: 2000 4runner 4x4 5spd V6
09-11-2014, 07:36 PM
Real Name: Adam
Real Name: Adam
Sigh... I said this and I'll say it again, I was not saying this..... It's just the detergents probably cleaned up everything and now yhe hidden leak is present. This is not saying that synthetic caused the leak, more like it made it presentable.
09-11-2014, 07:41 PM
Yes, i saw that in your post, evidently some did not..
2017 Silver SR5 Premium
Vietnam 67-68
Greed and corruption are rampant.
09-11-2014, 07:44 PM
Then what were you saying? Your original post says that you were contemplating on going back to dino oil or dumping in that crap stop-leak nonsense. Your leaking oil drain bolt needs a new washer which is something that no synthetic oil would cause. Might as do another oil change now to drain out that stop-leak garbage and change the drain washer. As for the leaking seal; there is no way around it. It needs to be changed.
09-11-2014, 08:05 PM
Synthetic Oil vs Non-Synthetic Oil
Demystifying Oil: Synthetic Oil Versus Non-Synthetic Oil - The Car Connection
Some key statements:
"...They offer better high-temperature resistance and better low-temperature flow, and they leave nearly no deposits..."
"...Because synthetics flow and penetrate much better than regular oils, a change to synthetic oil will sometimes reveal leaks you didn't know existed..."
"... As you car ages and becomes a high-mileage vehicle, many experts recommend that you change to a thicker oil than is normally used. Over time, gaps between parts in the engine become larger, enabling less oil to reach critical parts..."
2006 4Runner SR5 4WD: FJC springs, Bilstein 5100s, ICON adj panhard bar, ToyTec front swaybar relocation brackets & diff drop kit, Energy Suspension swaybar bushings, SpyderTrax wheel spacers, 265/70R17 BFG A/Ts, HD adj rear swaybar links
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
