Originally Posted by Kryptoroxx
You're going to want the shaft from a 96 to 99 shaft iirc. You're not going to want to order from the states as the shipping will be crazy high to an fpo address (I'm assuming you're military) sadly it's not going to be easy to find the parts to fix it in Japan either as Japan doesn't really like older vehicles. I would recommend a new OEM as it will probably be the easiest and less prone to mistakes.
The axle shaft slides into the differential and inside the diff is where the gearing takes place. The spider gears are what's inside an open differential to distribute the torque evenly....until one wheel is in the air that is.
You can't use a shaft from a 94. I believe it is a different length.
Ok. I got the attached picture from a local auto parts place and was told I need everything in this picture (except the drum) plus the following:
Shaft Bearing Retainer - 42421-35050 - $35
Oil Seal - 90313-54001 - $3
Bearing - 90363-40068 - $30
When I searched for "1997 Toyota KZN185 Rear Axle Shaft" I came up with the following page.
http://jp-carparts.com/toyota/partli...ype=4&fig=4102
This lists every piece, both left and right. From their table I created my own and removed all the right hand pieces and the Disc, Rear (part code 42431).
I compared what I came up with vs BigFishAllDay's list. On the table on the page there are five listings for 42403A, Piece, Balance Rear Drum. I don't think I need any of those as I'm not changing out the drum.
There are also three shafts listed, 42312. I don't know what month the Surf was manufactured. There are two parts numbers for the three listed shafts. I don't know which I need.
I have attached the pdf version of the part list. Can someone please point me in the right direction? I'd rather not buy stuff I don't need but I'm happy to make smart investments in preventive maintenance. Since it's going to be apart there is no reason not to replace all the seals etc. I just don't know what is what.
I have ordered OEM parts for my Ducati from the states before. To arrange shipping usually requires a bit of conversation with the seller but it has not been a show stopper in the past. Can anyone recommend a reliable retailer with good customer service?
Thanks,
Josh
