Old 09-19-2014, 06:41 PM #1
4running11191's Avatar
4running11191 4running11191 is offline
4running11191 is on a distinguished road
1998 T4R Build Thread/Rear bumper build 4running11191
Im new to this forum but not new to 4runnners. This is my 2nd 4runner. Previous was a 1997 sr5(sold it to buy a diesel truck). I liked that 4runner so I bought a 1998 Limited last spring. Bought it with:
-199,998 miles
-factory E-Locker
- 3" lift,OME Springs and Shocks all around plus 1" top spacers(total of roughly 3"
-Shrockworks front bumper
-Unknown brand sliders
-Magnaflow cat-back
-other random little things
When I bought it, it also had 17" wheels w/ smaller general grabber stx tires which are more of a pavement tire in my eyes. I knew they had to go. I ended up buying a set of 07 16' TRD Tacoma snowflakes for dirt cheap and painted them gray. I also needed 1.5" hubcentric spacers for proper fitment. I wrapped them in 265/75r16 Kanati Mud Hogs which I had laying around. Which by the way are an awesome tire.
Then it was time to go try out the new tires. Went for a nice little drive 3 miles into the woods with a friend his his 94 Pickup.
Which ended like this....
Got into a soft spot and sank up to my nuts. 4 hours later and 5 gallons of bug spray it was finally out.
I have wanted the extra rear ground clearance because the trailer hitch/stock bumper always drags. I am a college student so I have zero money to buy anything like a rear bumper to match the front Shrockworks. Besides I cant justify spending so much on something so simple, with that being said I decided to make my own.
The parts list consists of:
-x1 1/4" 3"x3" square tube
-x1 3/8" 6"x30" Flat bar stock
-x1 3/16" 4'x4' sheet
-x1 1/8" 10"x36" sheet
-x1 Weld in reciever hitch
-x2 3/8" Clevis D-Rings
I first boxed the end of the frame with 3/16 and welded a 5/16"nut on the inside.
Next I figured out the frame rail mounting. Used 3/8" thick flat bar with some angle mounted which bolts to the frame as well as to the end of the frame where I welded the nut. I dont have a picture but you will sorta see in the next pic.
I mounted the 3x3 square tube in the center of the frame rail welded to the 3/8 plate. I then capped the square tube on each end after I had welded the tube to the plate. I decided I was going to make the right "wing" first and duplicate the dimensions for the left side. I made it out of cardboard.
I then took some measurements followed by drawing them out on the 3/16" plate. And here is the right wing tacked together.
I then decided to finish the center section with the square tube before I started the left wing. I welded the receiver hitch to the bottom of the square tube. Gusseted the receiver with 3/16" plate and used 1/8" plate to put and angle off the bottom of the square tube.
1998 black 4runner limited auto, 4x4, e-locker, "gray" wire mod, magnaflow cat-back, Shrockworks front bumper, sliders, OME lift front and back, diy diff. drop, boot slide mod, 265/75r16 Kanati Mud Hogs, 07 Tacoma snowflakes, 1.5" hubcentric spacers, Bosch rally driving lights, PIAA fog lights, Husky liners....
4running11191 is offline   Reply With QuoteReply With Quote
Old 09-19-2014, 06:51 PM #2
Coopsdaddy Coopsdaddy is offline
Coopsdaddy is on a distinguished road
How about some better pics .
Coopsdaddy is offline   Reply With QuoteReply With Quote
Old 09-19-2014, 07:03 PM #3
After welding the center of the bumper together I mounted it again, check dimensions and put some heavy tacks on the right wing again. Took it off and welded it together along with welding the right 3/8 Clevis ring on.
I had all the pieces cut out for the left wing already so I mounted the bumper again, measured some angles and double checked the dimensions of the plate pieces followed by tacking the left wing together.
I decided to spray the whole thing in bedliner as the road salt is absolutely horrible in my area and it will melt steel like cake in the rain.
I will be building a swing out tire carrier within the next 2 months probably as well as a lower profile roof basket for my high lift jack etc...
Old 09-19-2014, 07:07 PM #4
Sorry about the crappy pics. They are all from my phone but I figured they were better than none. I actually haven't had a camera since I bought this and I built the bumper last week. I am going out to buy a camera this weekend. I will post more of the bumper.
zacattack20's Matte Blue ‘98 to '02 Sport Edition - Not the normal build thread zacattack20 3rd gen T4Rs 398 06-22-2022 12:15 PM
CodyX36's 1998 4Runner Build-Up Thread CodyX36 3rd gen T4Rs 68 04-23-2016 02:21 PM
atra_m0rs build thread - 1998 T4R SR5 atra_m0rs 3rd gen T4Rs 4 03-01-2014 04:58 PM
1998 4WD SR5 Build Thread Calvin52 3rd gen T4Rs 5 12-10-2013 11:42 PM
Clownmeat and Yoterman87's rear bumper build thread Yoterman87 3rd gen T4Rs 46 01-03-2013 01:58 PM
