Originally Posted by Rushthezeppelin
What I'm wondering though is what all is behind the dash, how would a go about tapping off the ducts and routing them down to the new vents. How would I close off the original vents. What do I then need to get a head unit mounted up in the higher position. I've never really done any kind of fabrication before and I'm at least trying to get an idea of what all would be involved.
It's been years since I took my center dash off, but here's a pic from a Crutchfield article...
I'd ask Yotanation if they have more info on the duct relocation
3rd Gen (96-02) 4Runner Center Console Modular Accessory Mount
– Yota Nation
If I were to attempt it I'd probably remove the existing ducting between the heater box and vents then run new flexible tubing directly from the box to the new vents. I'd also have to relocate the hazard switch since it's between the original vents, not concerned about losing the original clock since practically every aftermarket headunit has a clock function.
