Old 09-27-2014, 08:13 PM #1
beer-toe beer-toe is offline
beer-toe is on a distinguished road
help... skid plate mounting holes stripped
Hey guys, dont know if anyone else has had this problem but after installing my tranny cooler, i was trying to reinstall my skid plate and all the threaded inserts are stripped! the three front ones and even the two back ones. nothing is holding anymore. has anyone here had this same problem? I dont like the idea of driving around without a skid plate, so i want to do something. Help please....
Thanks guys
I need ideas or a solution
beer-toe is offline   Reply With QuoteReply With Quote
Old 09-27-2014, 08:26 PM #2
02SE 02SE is offline
02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold
Tap the stripped threads for larger bolts.
02SE is offline   Reply With QuoteReply With Quote
Old 09-27-2014, 08:30 PM #3
TBuzz's Avatar
TBuzz TBuzz is offline
TBuzz is on a distinguished road
TBuzz's Avatar
I was just faced with this yesterday and drill it out with an 11/32 bit and tapped with a 10mmx1.25 tap and it worked great. That won't work if the nut that is welded on there is gone though.
00' Highlander, no longer stock
TBuzz is offline   Reply With QuoteReply With Quote
Old 09-27-2014, 09:20 PM #4
Brique's Avatar
Brique Brique is offline
Brique is on a distinguished road
Brique's Avatar
Yeah, you'll need to tap that ass. The self-tapping bolts that came stock are terrible over time, especially with ham-handed jiffy lubers cross-threading them with impact wrenches. I had to retap my skid plate holes when I got my truck, replaced the stock bolts with conventional bolts and it's been like butta ever since. Fortunately, my holes still were tight enough that I was able to retap for the same size, but if yours are completely stripped, you may have to do as has been said above and drill em all out and retap.
Brique is offline   Reply With QuoteReply With Quote
Old 09-27-2014, 10:48 PM #5
I put my skids I'm the corner of the garage. Don't go in the woods with it. So, what's the use. Just extra bolts In the way to change the oil
Old 09-27-2014, 11:15 PM #6
Que's Avatar
Que Que is offline
Que is on a distinguished road
Que Que is offline
Que's Avatar
I did the same thing.
2002 4runner SR5 2wd
2005 Tacoma Prerunner 2wd
Que is offline   Reply With QuoteReply With Quote
Old 09-27-2014, 11:16 PM #7
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
Just drill it out use a longer bolt and put a lock nut on top for the the front crossmember bolts. THere's plenty of room to get your hand and a wrench on top. I had 1 hole that completely stripped out and that what I did.
For the others, you will need to get a 10x1.25 tap. Odds are the threads can be cleaned up with a tap no problem. Try that before you even bother drilling it out.
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 09-28-2014, 12:10 AM #8
AZ4Running's Avatar
AZ4Running AZ4Running is offline
Real Name: Neal
AZ4Running is on a distinguished road
AZ4Running's Avatar
Real Name: Neal
Yeah pretty common isssue. Retap them or better yet helicoil them. Just keep in mind that there is not much ther to tap just a nut wielded in place.
AZ4Running is offline   Reply With QuoteReply With Quote
Old 09-28-2014, 10:58 AM #9
xcmtb83 xcmtb83 is offline
xcmtb83 is on a distinguished road
I think the threads are only M8 from the factory, aren't they? He may not have very good luck trying to tap without enlarging the hole first with the proper size tap drill. I ended up drilling mine out and then tapping them M10.
OP - I wouldn't bother with a helicoil as you will have to enlarge the hole anyway to install one. At that point you might as well install larger fasteners.
xcmtb83 is offline   Reply With QuoteReply With Quote
Old 10-09-2014, 09:29 AM #10
shadow247's Avatar
shadow247's Avatar
You are totally right, it is an M8 x 1.25 - I just had to buy an M10x1.25 for my motorcycle so that was fresh on my brain.
Yeah he would not get very far at all trying to go up 2mm in thread size without first drilling the hole.
The 4Runner Show
Stripped the bolts on the factory skid plate.... now what? audiness 4th Gen T4Rs 18 07-21-2020 12:21 AM
Front License plate holes don't line up hgill 4th Gen T4Rs 14 02-09-2014 03:37 AM
skid plate mounting problems CaptainGiggity 3rd gen T4Rs 0 07-10-2013 02:40 AM
Stripped threads on skid pan mrwebb 4th Gen T4Rs 5 05-10-2009 01:27 PM
Stripped skid plate holes - Helicoil or not? Fumbler Maintenance/Detailing 2 12-06-2008 07:02 PM
