09-29-2014, 01:36 PM
Best Manual Trans fluid for 3rd Gen?
I live in an area where my only choices from the local Auto Parts are Mobil 1 or Lucas Oil.
Is anyone using these brands in there 4Runner?
09-29-2014, 02:01 PM
I run Mobile 1 Synthetic ATF. No problems so far.
09-29-2014, 02:05 PM
Lots of guys with manuals like MT90 Redline GL4, that seems to be the important part; GL4 75w90 or 80w90. I am not sure if Mobil 1 or Lucas offer GL4, but if they do and they're the correct weight then use them without a worry.
5th gen inbound
09-30-2014, 04:52 AM
Real Name: Keith
Real Name: Keith
The book says 75W-90/GL-4 or GL-5 for the trans. M1 is GL-5, and may work fine.
I like, and use, the Redline MT-90 for the trans.
You can order it from Summit or maybe Amazon, etc.
09-30-2014, 10:46 AM
Amsoil bro.
1997 SR5 4WD 3RZ/5spd. Evergreen Pearl/Oak. Elocked. 4.56 Toyota Gearing. Full body resto/Custom 3 Stage "Tri-Coat" 751 paint job. 2.5" OME lift/w Bilstein Shocks. JAOS Spoiler. Duratracs. Custom Taco Rims. EBC Brakes. SS Braided lines. Marlin Crawler Trans & parts. Marlin HD clutch. URD short shift kit. 1st Gen Shift Knobs. MStudt's endlinks. JBA SS exhaust. LCE Headers. K&N. 140A CS144 alt. Big 3/4 wiring. Hella/PIAA Lighting. 2nd Gen Map Light Mod. Custom LED switchback DRL/Turnsignals. 32" Curved LED bar. Front Tint. A/D/S/ Stereo. SoundProofed. RangeRover seat swap. 99 Clears. A/C. PWR everthing. EastWood Frame coating. AMSOIL. Custom sleeping solution.
09-30-2014, 10:47 AM
he is asking for a manual....
09-30-2014, 11:29 AM
Real Name: Neal
Real Name: Neal
Mobile1 or Valoline GL4 or GL5 75w90
09-30-2014, 11:56 AM
Despite the spec that says GL-4 or GL-5, a lot of smart people say the sulfur additives in GL-5 attack the yellow metal in the 5-speed synchronizers. Use GL-5 at your own risk. Mine has run MT-90 every 50k since the first change at 50k and at 165k shifts like new (after new poly seat bushings from Marlin Crawler, also recommended.)
My Backyard Frame Swap
09-30-2014, 12:05 PM
I put Amsoil in my xfer/diffs, If I had manual I'd use it there too.
85 Xtracab, 3Link Front, Marlin Dual Ultimate, Double Locked on 37s
09-30-2014, 12:40 PM
Real Name: John
Real Name: John
Mt 90 is great for our manuals. I have the w59 but it's still great fluid.
98 Toyota 4runner 3rz 5spd 4x4 - Sold Build Thread
06 4runner 2uz Build Build Thread
Instagram: @Kryptowerkz
09-30-2014, 02:23 PM
Use the Redline Mt-90, NOT Amsoil - it may be great, but not in these...
When I picked up my '97 I did a lot of preventative maintenance, and along with that changed transmission fluid. I had a jug of Amsoil so I used that. Inside 2 weeks I was draining it back out and went with the MT-90.
With Amsoil, 1st gear was difficult to get unless the truck was completely stopped. Also the 1-2 shift was stiff all the time. MT-90 changed all that.
'97 SR5 V6 4x4 | 5-speed | e-locker | 33's
10-01-2014, 01:01 AM
Real Name: Keith
Real Name: Keith
Val[v]oline makes a 75W-90 GL-4? Cool....
10-01-2014, 08:30 AM
I don't think they do. They didn't when I researched this many years ago when I did my first trans fluid change. I actually wrote Valvoline asking about their GL-5's effect on brass components and they wrote back saying their GL-5 sulfur components are somehow safe for yellow metals because of some process they use.
In any case, I subscribe to the view that GL-5 is too slippery and keeps the synchronizers from matching rpm's as well as GL-4, so I went with MT-90. I love the way it shifts.
10-01-2014, 09:27 AM
Real Name: Neal
Real Name: Neal
Yeah they do pretty sure. I use it at work a lot. Might be 75w80 need to check if so i just miss stated.
10-01-2014, 09:31 AM
Real Name: Kevin
Real Name: Kevin
I'm not one for fancy oils and usually just run whatever's cheap, but the change between parts-store GL5 and the Redline MT90 was amazing.
If you don't have a local supplier, you can buy it on Amazon.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
