Old 09-30-2014, 11:28 PM #1
2002_thundercloud 2002_thundercloud is offline
2002_thundercloud is on a distinguished road
Spongy brake pedal - help!
Two years ago I did a tundra 231 rotor and caliper upgrade and used good stuff. I have fully bled the system at least three times and still, to get good pedal feel, have to give the pedal a light pre-pump before the pedal feels "just right". I don't buy into the caliper fluid volume difference argument I read somewhere because the piston diameter between the 4Runner and tundra calipers is the same and the diameter of the pistons and their travel during brake application is what accounts for fluid volume, right?.... Think about it for a second...The caliper switch should have no impact on pedal travel.
I believe some air has made its way up to a coupler between the MC and calipers and will not flush out down to the calipers using the old fashioned pedal bleed method OR some air has made its way up to the ABS VSC solenoid area and again, the old fashioned pedal bleed method can't remove it.
Now that you have read that, let me reiterate....VERY Consistently, a light quick primer pump of the pedal produces a PERFECT feeling brake pedal. Without that little primer, the pedal is awkward with very little feedback, as if the rears are working harder than the front.
I asked my local Toyota dealer to bleed them per the TSM and the service manager said they "don't do that" and offered no other help.
So the question: can the clever garage mechanic perform a similar bleed procedure where the ABS / VSC solenoids are activated so that air is pushed to and out of the caliper without expensive Toyota tools?
Thanks,
Todd
2002 Toyota 4Runner 4WD Limited. 89,000 miles. 880/906 OME springs. Bilstein 5100 Front Tundra / HD Rear 4Runner shocks. Wheeler steering rack bushings. Tundra 231 disc/caliper upgrade.
2002_thundercloud is offline   Reply With QuoteReply With Quote
Old 10-01-2014, 12:35 AM #2
Mynameistommy510's Avatar
Mynameistommy510 Mynameistommy510 is offline
Mynameistommy510 is on a distinguished road
Activating the abs by doing some hard braking on a dirt road or wet road safely, than bleeding all brakes as soon as possible has worked for some people. This is assuming you have a good MC, good cylinders in your calipers, both rear wheel cylinders are good, and no openings in your brake lines.
Mynameistommy510 is offline   Reply With QuoteReply With Quote
Old 10-01-2014, 09:20 AM #3
AZ4Running's Avatar
AZ4Running AZ4Running is offline
Real Name: Neal
AZ4Running is on a distinguished road
AZ4Running's Avatar
Real Name: Neal
Sounds like you either have air in the system still or a bad/bypassing master cylinder. Pedal bleeding the brakes is the best way ime to get all the air out. Have somone slowly pump the brake pedal 3-5 times and hold down while you crack open each valve on the brakes. Start at the right rear then left rear then right from lastly left front. Be sure to keep the bake res full or you wiol suck air in and have to start all over. If this does not work i wouod try a new master cylinder.
AZ4Running is offline   Reply With QuoteReply With Quote
Old 10-01-2014, 10:28 PM #4
DocW8494's Avatar
DocW8494 DocW8494 is offline
DocW8494 is on a distinguished road
DocW8494's Avatar
Replace the Master Cylinder - be sure to bench bleed prior to install. Cheap simple way to at least start the isolation of the systems.
SHEBA - My 1999 4R, 3.4L, Manual, 4WD, 2.5" EMU suspension.
BEST truck ever!!!!!!
DocW8494 is offline   Reply With QuoteReply With Quote
Old 10-02-2014, 11:32 AM #5
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
Thanks,
Todd
adjust the rear brakes properly.
if you have air in the system, it will never pump up solid. it might bring the pedal up higher, but the pedal will still be spongy.
what you are describing, sounds like rear drum brakes being out of adjustment.
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 04-23-2015, 01:29 AM #6
absalom's Avatar
absalom absalom is offline
Real Name: Jordan
absalom has a spectacular aura about absalom has a spectacular aura about
absalom's Avatar
Real Name: Jordan
Was this ever resolved?
absalom is offline   Reply With QuoteReply With Quote
4runner , abs , bleed , brake , vsc
Spongy/Long travel Brake Pedal w/ Tundra brake upgrade 2002_thundercloud 3rd gen T4Rs 9 07-23-2023 10:07 PM
Brake pedal noise Flaminghawk 5th gen T4Rs 37 02-18-2020 11:14 PM
low brake pedal billkmiami 3rd gen T4Rs 13 10-10-2017 06:00 PM
Spongy Brake after Changing Pad and Shoe hyperthread 4th Gen T4Rs 14 12-23-2011 05:24 PM
spongy brake pedal latreto 4th Gen T4Rs 3 09-19-2009 07:09 PM
