10-09-2014, 08:45 PM
Steering Rack Replacement
For those of you who have replaced your steering rack how difficult did you find it to be? Anything to watch out besides the lines. How long does it typically take? Did you have to remove the one long bolt on the drivers side or did you you just push it out some?
doing some reading now or it.
2018 Toyota Tacoma
2010 Toyota 4runner TE - Sold
2002 Toyota 4runner - Sold
2000 Toyota 4runner - rolled
1996 Toyota 4runner - sold a long time ago in a galaxy far far away.
10-09-2014, 09:17 PM
It can be a bit of a pooper. The bolt up on top is fun to get to. Use line wrenches to undo the pressure lines and be careful not to strip them. DO NOT turn the steering wheel round and round trying to center it when re-connecting. There's some sort of spring in there that has something to do with the airbag and it can break. Don't assume the new rack is centered. Turn the pinion and count to be sure before attaching to steering column. You can adjust the centering after the rack is installed without removing it if necessary, but it's kind of a pain.
'96 Limited - Locker - 127k- totaled out -
'01 Limited 175k - sunken and resurrected - stock, other than TBU 231mm
'98 Limited - Locker -158k-Bilstein 5100 Tacos- Toytec/Eibach 3" lift coils- diff drop-265/75/16 Duratracs -OME 890's-Bilstein 5125's, panhard bar drop, TBU 231mm, Spidertrax 1.25' spacers, Savage sliders, 2nd gen SC/URD 7th, JBA exhaust, HID retrofits -
10-09-2014, 10:04 PM
Real Name: Neal
Real Name: Neal
Very easy to do imo. Be sure you center and lock the steering wheel and be sure the new rack is centered. I habe gotten racks that have been off center by more than 1 turn on the steering wheel. Its no fun having to go back and center th e rack after install but not hard on a 4runner. Flush the ps with new atf fluid after the new rack is in and get an alignment.
Yes dont turn the sterring wheek at all with the rack out. The air bag unit in the steering wheel called the clock spring will brack and cause a srs light and no air bags.
10-10-2014, 09:47 AM
Search for threads about this. There are several recent ones that have answers to everything you are asking, along with pictures.
It's not super easy, especially if you have rust, but there is enough info out there already to get you though it just fine.
2000 SR5 3.4L V6 Automatic 4x4, e-locker, 175k Miles, Rust
Imp. Jade Mica with Oak Leather Interior, Field Monitor Unit - B&M Tranny Cooler - SG2 - New (to me) rear axle assembly - Goodyear Duratrac 265/75-16 - 1.8" Ironman Front Lift, OME 906/Procomp 9000 Shocks
http://www.toyota-4runner.org/3rd-ge...ld-thread.html
10-10-2014, 11:17 AM
Save your old OEM inner tie rod ends if they feel solid. They dont usually go bad that quick, are super expensive oem and I have torn through 3 cheap auto store ones in less than a few months. If you wheel the aftermarkets like to fail quickly.
10-10-2014, 11:27 AM
Best tip/trick I can give for this is to take your grinder and cut a slash in the center 19mm bolt. Save your knuckles from having to get 1/32 turns on a box end wrench from the top and turn it into a big flat-head screw.
-2015 SR5 Premium - 2.5 inch lift w/BFG KO2's
Bilstein 5100's
-2005 Limited V8 (sold)
-1997 4Runner LtdS/C with URD 2.2 and meth
Lifted and locked
10-10-2014, 11:31 AM
Real Name: Connor
Real Name: Connor
I've done the steering rack replacement twice now. It really isn't as bad as everyone makes it out to be, just a lot of physical labor. One tip I will give you is for the steering shaft. The joint that connects the steering rack to the shaft, you have to remove the bottom bolt completely and then slide the joint up onto the steering shaft completely. Feel free to PM me if you have any questions mid-install. I know this swap pretty well now haha
1996 Toyota 4Runner 4x4 w/ 5 speed- Lifted, Locked,Painted,Armored
Build: http://www.toyota-4runner.org/3rd-ge...ld-thread.html
Originally Posted by invisible4Runner
Highlander = minivan, purses, soccer practice
4Runner = testosterone, steak, dirt
10-10-2014, 01:48 PM
Well, maybe in san diego with no rust it isn't a big deal, but freeze every single joint, and it is a much bigger more difficult job than you'd think.
My rack/shaft joint was frozen and took an hour or 2 just to disconnect. The pressure hoses I had to cut off. The bolts I had to loosen or take off for the hoses, rack, etc. all either broke off or came out hot from friction. That's the way it is when you have rust. Every bolt tries your patience and take a little more skin off your knuckles.
10-10-2014, 10:01 PM
Real Name: taylor
Real Name: taylor
I am having issues with my 98 sr5 3.4.... Feels like loose front suspension or steering rack...how can I tell?
10-11-2014, 12:31 AM
Just take the short answer... It's not your steering rack.
Search here for your symptoms, and if you can't find a good description of your symptoms, them post more details. We can't diagnose it for you from "feels like loose front suspension or steering rack"
Seriously search here though, I am sure that your symptoms are already described here and you can figure it out from existing threads.
10-11-2014, 12:54 AM
geohil, that's ingenious. Never thought of that. But I knew Nelson would echo the same sentiment I have. If I tried that with any of my Runners, I'd be without a few screwdrivers or bits. There's a fair amount of torque on that bolt+years and any rust makes it redonculous. Thankfully, wife's '01 (which we had to put a new rack on) was born in TX and is quite clean underneath and my Canuck '98 came with a shiny new rack underneath. Cool idea, though -
10-11-2014, 01:36 AM
Real Name: Phil
Real Name: Phil
I literally just pulled my rack off this morning. Second time I have done this. Some useful tips I can give.
-Remove the sway bar. I think you probably have to, to get the rack off. But even if not it will surely make the process much easier.
-The steering shaft joint that 4running daily is talking about can be a pain if it sticks due to rust. Rust is just the worst, as I think Nelson knows better than anyone. Soak that joint with penetrating oil ahead of time.
-Unbolt all 4 bolts/nuts holding the rack on and slide it out a few inches before attempting to remove the oil lines. This will make them much easier to access.
-Make sure you have an oil pan to catch the oil when you do remove the oil lines.
-Remove the whole thing (steering rack, inner and out tie rods) together as one unit.
-So in order, remove skid plate, sway bar, pound tie rods out of lower ball joints, remove all bolts holding rack, slide it out a few inches, remove oil lines, then last pull it apart at the steering shaft that has been soaking in penetrating oil.
267/75/17 Cooper ATs - Level 8ZX wheels matte black - EBC rotors/ pads - 99 coils/ Bilstein 5100s - deckplate - Sotashi/custom emblem - Hella micro DE fogs - Kenwood/Alpine/Infinity system - sound deadened interior - color matched bumpers - LED tails - Safari LTD rack - Husky floor liners - clear corners
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
