03-20-2015, 06:46 PM
#46
Real Name: Nick
Real Name: Nick
Also swapped out the amber bulbs in the LED tails with LED and load reistors:
http://vid1316.photobucket.com/album...psfdlttk6e.mp4
Have LED's for the front turn signals to do the same thing. But I may figure something out with strip LED DRLs when I do my projector retrofit that is sitting on my desk.
Then I rebuilt the drum brakes with new drums (Wagner), shoes (Raybestos), and components (Raybestos). Along with new bell-crank and other E-brake pieces from Amazon.
Then I put a switch for the powered antenna, and lubed it up a bunch. Fiance uses cell phone AUX input on head unit and it's always up and down and getting weather for no reason mainly, until I use it and turn the radio on.
Just wired up that switch, and drilled a little hole to put through.
Here is a pic of when we were in Breck a few weeks ago for a trip. I'm really looking forward to swapping the amber corners back in with black housings when I do the retro. The black with clear corners looks a little too 'washed out' for me.
2001 Toyota 4Runner SR5
Build Thread
03-29-2015, 09:32 PM
#47
Real Name: Nick
Real Name: Nick
Installed front LED turn signals to match the rear with resistors.
And baked my OEM headlights and corners and dremel'd some material to install my mini D2S projectors.
Got them fitted, and the shrouds modified to fit (Apollo 3.0 is huge). Now just have to paint the housings, shrouds, corners. I also got some LED switchback strips to do a strip along inside edge and bottom edge of headlight.
dremel'd
projector mounted
The apollo 3.0 shrouds are too big, and you can see them bow out when they are installed.
So I dremel'd them down. I may get some different shrouds, but for now i'm going to go this route.
with modified shrouds on.
I'll be painting the housings satin black, and the shrouds silver. Unless that looks bad, then I'll figure something else out .
Build Thread
03-31-2015, 07:18 PM
#48
Real Name: Jordan
Real Name: Jordan
Looking forward to finished pics of projector retrofit. We'll be moving to Colorado soon ... good to see other T4R's up there.
03-31-2015, 07:48 PM
#49
Real Name: James
Real Name: James
Man, it's wicked good looking. Impressive tech savvy. I envy that.
My Golden Retriever insists on front passenger's seat. I've prepared the cargo area just for her only to see her climbing over the rear seats and assuming co-pilot seating right beside me. It's perhaps the only time she's disobedient so I gave in.
I noticed you solved that issue. lol
03-31-2015, 10:34 PM
#50
Real Name: Nick
Real Name: Nick
Right on, where in? Boulder is fun. I'm finishing up grad school in May, and currently looking for jobs. Would like to get back the northwest where I'm from, but I'd also be cool settling in CO for awhile.
I need to pick up some JB weld and foil tape for the lights, and hopefully get them painted and adjusted this weekend. I am putting an LED strip in them, and I'm trying to find a short one that I can put in my corner lights to, so it'll probably be a couple weeks or so.
Thanks! Weimaraners are spazzes, so I had to rig the back up for him. If it wasn't for the window rolling down so he could look out, he'd just be panicking the whole time. 4Runners are the perfect dog trucks for that reason.
Build Thread
03-31-2015, 11:18 PM
#51
Real Name: Craig
Real Name: Craig
If you want to sell the clear corners it is on my list of things I want to buy.
96 SR5, Toytec Eibachs and Bilsteins, IPF's, Tundra brakes, SCS wheels, Half-ass satoshi, ARB front bumper, 4X4 innovations rear bumper, Sport hood, loud stereo.
2006 SR5, TRD pro suspension, Level 8 mk6, build in progress.
03-31-2015, 11:37 PM
#52
Real Name: Nick
Real Name: Nick
@ C-RAIG
Cool, I'll let you know. I want to see how the amber ones come out, if they suck, I may do something different with the clears.
Build Thread
04-01-2015, 02:17 AM
#53
Chances are around here, if you were to just blindly throw a rock, you'd hit either a Subaru, Audi, Saab, or a 4Runner.
Surprisingly my dog has zero interest in the back window, and the one or two times she's had to ride in the front seat really made her nervous. Her favourite spot is sitting behind the drivers seat like a person.
2000 SR5 Sport - 4EAT and E-locker, King 2.5s, EimKeith PCK, SPC UCAs, 33" KO2s on Black Rhino Boxer gloss gold 17x8.5, Savage/Lotus skids, 4xInnovations front bumper/sliders, Shrockworks bumper & tire carrier, Lil Skip Gas Tank Skid, Magnaflow Overland cat back
04-05-2015, 12:37 AM
#54
Real Name: Nick
Real Name: Nick
Been slowly prepping and painting headlight stuff. Easy-off'd the housings and shrouds, and painted them with satin black. Wet sanded 400 grit the housings, and repainted.
Taped the Apollo 3.0 shrouds only on periodic sections, then painted them silver. It's a Perfect Match Toyota silver.
Tomorrow I'm going to lay some clear coat on the shrouds (black and silver).
I also didn't like that the 100mm xB LED halos didn't fill the vents in the shroud, and TRS said 110 won't fit, but I measured and I think I can stuff the 110mms in there. So I ordered those, in the meantime I'll get the projectors installed and aimed.
I also put a single coat of night shades on the amber corner amber section only, then i'm going to clear and wet sand the whole corner lens. Separated and painted the inside black to match the housings.
Testing the halo:
Taped up:
Build Thread
04-09-2015, 12:44 AM
#55
Real Name: Nick
Real Name: Nick
I didn't like how the 100mm halo was too small, so I orderd a 110 mm halo. That was a tad too big, so I stuck the too together to get a fatty 100-110mm halo. I had to sand them to get them to fit together, then put a little JB weld on them.
Fired up the projectors and tested on my wall just to make sure they looked alright and fired.
mmm ... cutoff ..
JB Weld'd the halos in, and put aluminum foil around the projector. Ran the wires (for 2 halos per headlight and brights-actuator, JB weld'd shrouds to projector.
Fired up halos again to make sure they work, and tested the light strips. Open to opinions, but I don't think I'm going to use the strips. I think it's a cool idea, if done right, and good money is spent. But the strips are different color than the halos, and they barely cutoff the bottom of the light. Also with the black housings, the white strips look tacky.
So I was thinking I would use them for foot-well lighting, or under seat lighting.
Any both strips had a "break" in the amber, not sure if the amber bulbs burn out easier, or what, but they were only $20 on amazon ..
A different configuration
Will seal glass this week, and hopefully have them done this weekend
Build Thread
04-09-2015, 12:47 AM
#56
Real Name: Nick
Real Name: Nick
Also a single coat of night shades on just the reflector, and clear coated the whole lens twice. Wet sanded, and I'm going to put on another clear then buff it out.
Painted the housings black.
Build Thread
04-09-2015, 01:22 AM
#57
Headlights look great! Once you get them in you'll find yourself distracted always looking at the cutoff haha. I like the last LED configuration the best, but I don't know if I like it more than no LED.
04-11-2015, 01:16 AM
#58
Real Name: Nick
Real Name: Nick
@ Unner
thanks! I agree, these trucks look better with less junk in the lights, maybe because they are so square and flat.
Got the lights installed, but I didn't have a long enough philips to adjust them! So that'll wait for tomorrow. I hooked my halos to the corner lights. After I was all done, I saw a tiny little butyl slop on the bottom of the housing. SON OF A. Oh well, I may pull them apart at some point in the future to fix it.
Sorry for the awful pictures ..
Build Thread
04-12-2015, 03:56 AM
#59
Real Name: Instagram: briansd_97r
Great job with the lights!
I agree, don't use those LED strips in the actual housings.
I've got a set of 12" amber strips I'm going to finally install this week. I hope you will like the unique results.
One thing that made me tense up a bit is the fact that you jb welded the shrouds onto the projector. I've taken mine apart several times and for that reason alone i suggest other methods for the shroud . I'm sure yours will be fine but it is a very perminent design.
Those he commands move only in command, Nothing in love. Now does he feel his title, Hang loose about him, like a giant’s robe, Upon a dwarfish treasonous thief.
04-12-2015, 11:15 AM
#60
Real Name: Nick
Real Name: Nick
@ BrianSD_42
I'll look for your LED strip setup. One thing I didn't like is that they are so bright and contract wit the black housings so much. I was thinking maybe you could night shade the strips, or rig something up to cover them up. Also the temperature didn't match my halos.
Ya I saw that in your retrofit thread about not welding them on. I agree, if they are 'clicked' into the holes they are pretty secure. I had to modify the shrouds to fit in the housings, adn when I did it I didn't take into account the direction pointing down and the rotation they have to be to click in. So mine wouldn't click after I modified them. So I wanted to make sure they didn't come off. I could have got some new ones, but I didn't care that much. I don't mind that they are permanent, I don't plan on taking projectors apart anytime. I'd probably just sell the whole lights and do a different projector or something next time, if there is a next time.
@ xnxh
Thanks! Ya one of these days! A sport hood and a bumper are on my list, but probably not till after I move and get a job.
Build Thread
