10-15-2014, 08:15 PM
Rear Bearing Puller Tool
Has anyone happened to pickup one of these?
Rear Axle Bearing Puller Tool 09521 25011 Toyota Trucks | eBay
If someone bought it and wanted to rent it out, let me know...otherwise, I'll probably snag it so I can do the wheel bearings/seals on my ride before I sell it and do my wife's LX470 whenever those start leaking.
Eric
'02 Limited
1st Gen TRD SC - 2.2" Pulley - URD 7th Injector - TRD Headers - URD 02 Sim - Hilux Surf Field Monitor Unit - Hilux Surf Power-Folding Mirrors - Hilux Surf Rear Spoiler - Tundra Brakes - TRD Tranny Cooler - OME906 - '99 Front Coils
10-16-2014, 11:18 PM
Real Name: Bryan
Real Name: Bryan
if you are replacing the seals and wheel bearing why not cut off the old ones with a grinder
2000 Toyota 4Runner Base 2wd - Sold
1999 4Runner SR5 4x4 - Tundra Brake Upgrade- 2nd Gen Supercharger - 7th Injector - 32'' BFG KM2 Mud Terrains - ELocker - 4xinnvations Front Bumper
10-16-2014, 11:27 PM
Can get a grinder into the space, you can cut the ABS rotor, but thats it.
1999 4Runner SR5, with some stuff...
OverlandNV
You can also follow us:
Facebook OverlandNV
Twitter OverlandNV
10-16-2014, 11:28 PM
You will need at least a 6 ton press to do the actual pull/press work.
OverlandNV
Facebook OverlandNV
Twitter OverlandNV
10-17-2014, 02:12 AM
Cut the old wheel bearing out? Have you ever done this job?
10-17-2014, 02:14 AM
I used a 30 ton press but it only took 1 ton to get the bearings in and out.
10-17-2014, 07:56 AM
You can make this tool with an old axle housing for cheaper than that tool. People have done that before too. Just another option.
2000 SR5 3.4L V6 Automatic 4x4, e-locker, 175k Miles, Rust
Imp. Jade Mica with Oak Leather Interior, Field Monitor Unit - B&M Tranny Cooler - SG2 - New (to me) rear axle assembly - Goodyear Duratrac 265/75-16 - 1.8" Ironman Front Lift, OME 906/Procomp 9000 Shocks
http://www.toyota-4runner.org/3rd-ge...ld-thread.html
10-17-2014, 08:57 AM
Exactly - I did this on a siezed front bearing in college on my Vega (don't judge- it never broke on me). It took a long time. The steel is very tough.
10-19-2014, 07:42 PM
Real Name: Bryan
Real Name: Bryan
Sorry for taking so long yes I've done wheel bearings before i just cut them off. Its the fastest way if you aren't reusing anything.
10-19-2014, 11:27 PM
I was asking if you have ever cut the bearing out of a 3rd Gen T4R. I don't see how this would be at all possible without destroying the surrounding casting.
10-20-2014, 12:56 PM
Real Name: John
Real Name: John
No you can't cut the bearings out. Some people cut the retainers and ABS rotor off, which you don't have to do, (and risk damaging the shaft) The bearing itself comes out once the two retainers, ABS rotor, and snap ring are removed. It is not pressed into the housing.
SILVER 2000 4runner Limited TOTALED
WHITE/SILVER 1999 4runner Limited l Rear Locker l Tundra/890 coils | 5100 Bilsteins all around | Sonoran Steel Bumpstops l 199 mm Tundra brake upgrade | SCS Matte Gray Ray10 Rims | 275 70 17 BFG KO2 tires | LR UCAs | EIMKEITH panhard brackets | LED interior upgrade l Rear LED tailights l Pioneer AVH-X5700BHS Alpine Type "R" speakers NVX JAD800.4 Class D Amp Kenwood Under seat Subwoofer l Front window tint 20% l Weathertech window visors and floormats l OutGear Solutions Full Length roofrack l Morimoto 40" LED lightbar
11-28-2016, 08:50 PM
Been looking for this.
Been messing with my rear axle for a couple days now. Axle was bent, so I bought a new one. New bearings, seals, etc. Was trying to find a shop to press everything off the old one, but if the bearing isn't pressed on, it seems that i should be able to just cut off the ABS ring and the two retainers. Then once I remove the snap ring Ill be able to slide the bearing off the axle, pop the old bearing out of the housing, put the new one on, and just have the shop press the new retainers and ABS ring into place. Much easier I think. However, it would be even easier if i could just get the housing/break backer plate assembly off without even cutting anything. Is that possible? I suppose it isn't because of the axle and hub being one piece.?
99 SR5
205k...Who knows whats stock anymore...
11-28-2016, 09:39 PM
Real Name: John
Real Name: John
The axle is separate from the hub. The only way to separate them is to first remove the retainers, snap ring and ABS rotor. Then, as I said, the bearing comes out of the hub sort of easily by pushing the axle through to the hub. I still don't advise cutting the retainers or the ABS ring. If you HAVE to do it this way then don't cut all the way through (almost all the way) and take a cold chisel and "crack" the metal and it will slide off.
