Old 10-20-2014, 06:01 PM #1
Ghostrider Ghostrider is offline
Ghostrider will become famous soon enough
Power antenna grinding - not the mast
nothing is easy... the antenna started grinding and I decided to replace the mast when I had wheels off for LBJ's. I have replaced the mast six years ago with no problems. Today was not the same. I have a new OEM mast. I first tried the easy trick of removing old and they were same length. Fed the new one in and it would only go down - still grinds on the up, Pulled the motor and opened it up - no pieces. Put it back and now it runs fine but will not pull the new mast in. The teeth are going the correct direction. Is this the one in a million case where it really is the motor? Also all I did was open it up while in fender well. There is a small feed gear that is on the side that I ignored. Plenty of lube. Has anyone totally pulled apart the motor? Also how does the antenna wire come off? I didn't look for long but it does not look like it pulls off. If I can get it off I may try to repair on workbench..
Any thoughts or suggestions? I almost never use the antenna with satellite radio but I like things to work.
Ghostrider is offline   Reply With QuoteReply With Quote
NEW antenna mast - But still a grinding noise JKnAR 3rd gen T4Rs 27 03-21-2023 06:25 PM
Retaining Nut for Power Antenna Mast - 2001 T4R tenro1 3rd gen T4Rs 1 06-23-2014 07:00 PM
01 and others antenna mast! 01thunder For Sale: T4R Items 7 09-05-2013 10:42 PM
WTB- Power Antenna Mast for 96 4Runner snopro Classifieds - buy & sell (no commercial ads please) 1 06-23-2010 11:31 AM
Removing mast antenna Johnny_Brooklyn 5th gen T4Rs 12 11-18-2009 01:09 PM
