Where in the pedal stroke does your clutch engage? If it's when it's just coming off the floor, I'd suspect the clutch isn't fully disengaging.
Carefully bleed the clutch (yeah, it's a PITA) and see if it helps. There should be an adjustment trunnion in the pedal linkage which will allow you to set it up so it engages near the top of the pedal stroke with about 3/4" of free play at the top of the pedal stroke to insure that it's engaging fully.
Good luck.
-Karl
-'03 V8 4WD Limited, Titanium, "Ralf"
-'05 M-B E320 CDI, 369 lb/ft: "Helga"
-'07 Porsche GT3, 415 hp, 193 mph: "Bernd"
Ex- '98 4WD V6 Ltd 4R, "Hermie"
