Old 10-24-2014, 05:42 PM #1
Myrunr2010's Avatar
Myrunr2010 Myrunr2010 is offline
Real Name: Dave
Myrunr2010 is on a distinguished road
Myrunr2010's Avatar
Real Name: Dave
Rear window switch
I am getting ready to do the center console mod here in a few weeks and know that I'll need to move my rear window switch. I was wondering if there is a way to re-wire the switch so that I don't have to have the key in the ignition to roll the rear window down. Any help would be greatly appreciated.
97 4runner SR5 3.4 manual
Tundra/LC Lift with Bilstein 5100's on 285/70/17 BFG KO2
2" "Fat Pats" body lift; 1.25" All Pro wheel spacers
Turbo Build; Rear Bumper Build; Front Bumper Build
Myrunr2010 is offline   Reply With QuoteReply With Quote
Old 10-26-2014, 09:43 PM #2
Myrunr2010's Avatar
Real Name: Dave
Myrunr2010's Avatar
Real Name: Dave
80 views and no one has any advice?
Old 10-26-2014, 10:04 PM #3
AZ4Running's Avatar
AZ4Running AZ4Running is offline
Real Name: Neal
AZ4Running is on a distinguished road
AZ4Running's Avatar
Real Name: Neal
You would need to be pretty electronic savy to do that . Everything in the rear hatch is controlled buy a control unit, basically a bunch of relays. That control unit make it tricky to wire the rear window switch to constant power.
AZ4Running is offline   Reply With QuoteReply With Quote
Old 10-26-2014, 11:52 PM #4
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is just really nice TheDurk is just really nice TheDurk is just really nice TheDurk is just really nice TheDurk is just really nice
TheDurk's Avatar
You can do it, but as said above you would have to by-pass the Rear Door ECU and the Body ECU in the existing circuit, and run two new switch wires all the way to the back door. You can't use the existing wire as that is a multi-purpose 'communication bus'. It will also require a full-time heavy duty 12V+ source wire from the battery to the liftgate and tapping any existing full-time 12V+ circuit in the dash for the switch signal. (The window motor is too much load for the existing full-time supply to the liftgate.)
You then need to wire two standard Bosch relays to the red (up) and green (down) wires to the rear window motor and to the new signal wires and the new power wire (plus tap the existing window ground. This diagram shows what you have to do. Where it says Driver's think Rear, and where it says switched, think battery full-time. The two 12V circuits (switch and motor) would then be separate, not connected as in the diagram here. Likewise the grounds.
Easy Peasy. It would then be easy to piggyback a second switch to install in the back if you want to sleep back there.
Here is the existing circuit.
My Backyard Frame Swap
Old 10-27-2014, 08:03 AM #5
Myrunr2010's Avatar
Real Name: Dave
Myrunr2010's Avatar
Real Name: Dave
Originally Posted by TheDurk View Post
Easy Peasy.
Mmmm, sounds like it, lol. I might have to read/reread/reread this once I get home.
Old 10-27-2014, 05:42 PM #6
Myrunr2010's Avatar
Real Name: Dave
Myrunr2010's Avatar
Real Name: Dave
Could something like this be done and wires run all the way to the front? Curious even further if there would be a way to run essentially a 3 way switch like this. So I could have one in the rear of the truck as well as one in the front?
http://www.yotatech.com/f2/remote-re...button-218926/
I'm just starting to get the hang of doing electrical in the house, car electrical is a whole different story....
Old 10-27-2014, 08:50 PM #7
masphx's Avatar
masphx masphx is offline
Real Name: Mason
masphx is on a distinguished road
masphx's Avatar
Real Name: Mason
I relocated mine near the e-locker button. It is a little stretch but it will make it.
1998 4x4 5speed E-locked 225k - TRD 2nd Gen Charger w/ URD 7th injector - ICON 2.5 Standard Coilovers, ICON 2.5 Rear w/ Remote Res, ICON FJ Shin Guards, stock UCA, Tundra 199mm, ARB Bumper, Custom Tire Swingout bumper, Custom low profile roof rack, Lotas LC, Stubbs HD-SKO, 265/75/16 Duratrecs on OEM 5 Stars, Shockworks Combo Skids, Lightforce Genesis 210 halogens, 20% front tint, Uniden 520Xpro, 99+ Cup Holders & Headlights, Clarion CX501 deck, UG scanner, rear diff mod
2003 V8 4x4 Limited Black 156k stock for now. ICON ordered
masphx is offline   Reply With QuoteReply With Quote
2014 4runner 4x4 switch and rear window switch doesn't light up? slee05 5th gen T4Rs 5 06-28-2014 05:10 PM
1991 T4R - Rear Window Switch and Window Lock Switch ? El_Estrago Classic T4Rs 0 07-25-2011 04:03 AM
rear window switch, sunroof switch cdmasm Classic T4Rs 2 07-06-2006 04:23 PM
FS: Rear Window Switch 91-95? whodkne Classifieds - buy & sell (no commercial ads please) 0 09-13-2004 01:23 AM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
